  3. Solar Pannel and LiOn or Lipo
52 Posts 5 Posters 49.7k Views 9 Watching
  • epierreE
    epierreE
    epierre
    @AWII @ceech any advancement on this ?
    z-wave - Vera -> Domoticz
    C 1 Reply Last reply
    • epierreE epierre
      C
      C
      ceech
      @epierre Nope, sorry.
      • epierreE
        epierreE
        epierre
        wrote on last edited by epierre
        #43
        @ceech I've ordered the wrong boards so without the solar panel... what should I do to complete the missing here ?
        rq: your page https://www.mysensors.org/hardware/ceech is not present anymore in hardware @hek an error ?
        epierreE 1 Reply Last reply
          I asked @ceech to add it to the openhardware.io site instead. Guess he hasn't had time to do it yet.
          • epierreE epierre
            epierreE
            epierreE
            epierre
            @ceech would adding these on the either ext or batt do the trick enough ?
            http://www.ebay.com/itm/5pcs-5V-1A-USB-18650-Lithium-Battery-Charging-Board-Charger-Module-Protection/221533778016?_trksid=p2050601.c100085.m2372&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140211132617%26meid%3D3aab1c92f1544168b6c5a3033e5d60fc%26pid%3D100085%26rk%3D2%26rkt%3D4%26mehot%3Dpp%26sd%3D300376371464%26clkid%3D3316748233453320960&_qi=RTM2247626
            • epierreE
              epierreE
              epierre
              @ceech should I put the power on Vin / Gnd as I guess ?
              I have started graphing the solar / lipo one here:
              https://thingspeak.com/channels/89944
              • epierreE epierre
                C
                C
                ceech
                @epierre Yes, Vin is the right choice. Nice graphs :)
                • epierreE
                  epierreE
                  epierre
                  #48
                  @ceech actually the Particle Photon is doing less well than yours: https://thingspeak.com/channels/88622
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    Hello guys,
                    @ceech
                    I have a load of the 18650 charging boards with the protection circuit (from Aliexpress). I also have a few 18650 batteries and solar panels hanging around.... Can I use the code above to get readings (batt, solar, charge, pct) or do I need something else?
                    • C
                      C
                      ceech
                      The code above is for dedicated boards with on-board charger IC. Like the one from the following page:
                      http://www.ebay.com/itm/331838940273?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
                      This board uses LTC4079 and has voltage dividers on battery and solar cell connectors. They allow for voltage readings. Current is measured on one of the LTC4079 pins.
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        HI @ceech
                        The boards look great, sadly I have a ton of spares around I need to use first. I wondered if the code could be adopted, or if there was perhaps a way to get the readings off the solar input and battery using the 18650 charge module alone...
                        • C
                          C
                          ceech
                          wrote on last edited by ceech
                          #52
                          Of course you can. Use voltage dividers to scale down voltages that you would like to measure if they are above your VCC. And you can also read the current from TP4056 charger board. Tap to Prog pin (pin 2) and measure its voltage. Here is the correlation between voltage and current:
                          Ibat = (Vprog /Rprog) x 1200
                          Adapt the above code with your hardware values, current formula and measure away.
