  3. Multisensor_PIR_DHT_LDR_Battery
20 Posts 5 Posters 14.2k Views 8 Watching
  • n3roN
    n3roN
    n3ro
    wrote on last edited by n3ro
    Hey Guys,
    Today I have completed my first multisensor.
    As base I used a cheap china fire detectors and the MYS PCB board.
    http://www.ebay.de/itm/like/Optisch-Feuermelder-Rauchmelder-Funkrauchmelder-Rauchdetektor-Rauchwarnmelder/141252448370?hlpht=true&ops=true&viphx=1&_trksid=p5197.c100068.m2280&_trkparms=ao%3D1%26asc%3D20140211130857%26meid%3D07bc95de38bb49768007aea7e82e859d%26pid%3D100068%26clkid%3D6724945852786999307&_qi=RTM2052467
    All components fits very well in the housing.
    Unfortunately, the modified HC-SR501 do not work well with <= 3V with the DHT (delay in the sketch). Now I use this:
    http://www.amazon.de/Niederspannung-PIR-Infrarot-Bewegungssensor-erkennt-Modul/dp/B008EGH3FM/ref=sr_1_1?ie=UTF8&qid=1433801387&sr=8-1&keywords=B008EGH3FM
    And it works very great!
    The used Sketch is this:
    https://github.com/n3roGit/MySensors_n3ro/blob/master/Multisensor_PIR_DHT_LDA_Battery/Multisensor_PIR_DHT_LDA_Battery.ino
    wiring diagram coming soon;)
    pimatic + MySensors + Homeduino + z-way
    DwaltD D 2 Replies Last reply
    • n3roN n3ro
      Hey Guys,
      DwaltD
      DwaltD
      Dwalt
      @n3ro
      I am curious to see your wiring diagram. You have a step-up booster in one of the photos, was this just for the DHT?
      • n3roN
        n3roN
        n3ro
        Yes. This is a step up with a transistor for the dht.
        I want to reduce the battery drain with the transistor.
        http://forum.mysensors.org/topic/1446/battery-sensor-with-stepup-and-on-off-transistor
        • n3roN
          n3roN
          n3ro
          Hey folks,
          I have just tried to reduce the sleep current of the nodes. With
          *a transistor to turn on and off the stepup
          *a second transistor to disconnect the ldr
          *a external pullup with 680k for the pir
          Now I have a sleep current of 220-240uA.
          Any ideas to tune it a little bit more?
          Is it possible to check if the node is wake up from the interrupt or the timer?
          Regards
          n3ro
          icebobI 1 Reply Last reply
          • F
            F
            floris
            maybe a stupid question, but can i use this sketch for the recommenced sensors ?
            it's just exactly the sketch im looking for thanks!!
            • n3roN
              n3roN
              n3ro
              What do you mean with you recommenced sensors?
              F 1 Reply Last reply
              • n3roN n3ro
                Hey folks,
                Regards
                n3ro
                icebobI
                icebobI
                icebob
                @n3ro Yes, you can. The sleep function has a return value. If it is < 0, timer is timed out. Otherwise it waked up by interrupt.
                I'm working on a same multi sensor PCB with batteries. The PIR consumes 150uA. So you can reduce consume if your search a low power PIR sensor. Like this: http://forum.mysensors.org/topic/2387/low-power-pir-breakout-board-for-mysensors-and-evaluation/6
                @scalz said it consumes only ~24uA.
                n3roN 1 Reply Last reply
                • icebobI icebob
                  n3roN
                  n3roN
                  n3ro
                  @icebob hey :) the used pir consumes ~50uA. Since my last modifications I replaced the stepup and the dht with a si7021 sensor and the external pullup with 1m ohm. Now the sleeping current is ~190uA
                  https://github.com/n3roGit/MySensors_n3ro/blob/master/Multisensor_PIR_SI7021_LDA_Battery/Multisensor_PIR_SI7021_LDA_Battery.ino
                  • n3roN n3ro
                    icebobI
                    icebobI
                    icebob
                    @n3ro ohh, it's great. Which PIR are you using?
                    • icebobI icebob
                      n3roN
                      n3roN
                      n3ro
                      @icebob
                      http://www.amazon.de/Niederspannung-PIR-Infrarot-Bewegungssensor-erkennt-Modul/dp/B008EGH3FM/ref=sr_1_1?ie=UTF8&qid=1433801387&sr=8-1&keywords=B008EGH3FM&tag=wwwmysensorso-20
                      • n3roN n3ro
                        F
                        F
                        floris
                        @n3ro I Mean the sensors advised by the Mysensors store...
                        • n3roN n3ro
                          Hey Guys,
                          D
                          D
                          Dylano
                          @n3ro
                          Great...
                          Hope this will work for a long time on a battery?
                          What battery's you are using?
                          1 problem< WHERE CAN I FIND:
                          #include <readVcc.h>
                          Domoticz, with a lot of working hardware, include mysensors :-)
                          OpenPLI, RuneAudio, Solarmeter, etc......
                          Not a great builder of software and hardware, more a user...
                          Only i try to do my best :-(
                          n3roN 2 Replies Last reply
                          • D Dylano
                            @n3ro
                            Great...
                            n3roN
                            n3roN
                            n3ro
                            @Dylano
                            Hey,
                            Yes it works very good with 2 aaa Batts.
                            You can find the read library here
                            https://github.com/sweebee/Arduino-home-automation/tree/master/libraries/readVcc
                            • D Dylano
                              @n3ro
                              Great...
                              n3roN
                              n3roN
                              n3ro
                              @Dylano
                              But I don't use the dht anymore.
                              https://github.com/n3roGit/MySensors_n3ro/tree/master/Multisensor_PIR_SI7021_LDA_Battery
                              This works much better!
                              • D
                                D
                                Dylano
                                yes i saw your better solution..the si7021 is using less power i read..
                                Where do i have to place the: long readVcc
                                And how do ik make that .H file?
                                How long is the multisensor running? on what battery?
                                • D Dylano
                                  n3roN
                                  n3roN
                                  n3ro
                                  @Dylano what do you mean with long readVcc?
                                  The battery life is different because of the frequency of triggering from the pir.
                                  Some nodes works for 2 month. Other ones for 6..
                                  • D
                                    D
                                    Dylano
                                    sorry, it is working now: what do you mean with long readVcc?
                                    I use the sketch battery pir, to test
                                    Only the report of the vcc how many times is the sketch reading this?
                                    And where can i see the status?
                                    I use Domoticz as controller.
                                    • D Dylano
                                      n3roN
                                      n3roN
                                      n3ro
                                      @Dylano the sketch send the battery percentage everytime the voltage is changed
                                      • D
                                        D
                                        Dylano
                                        great, i see in domoticz the value great!!!...[ when power is low i get an alert. ]
                                        You have a lot of sketches :-)
                                        Is het possible that you build a sketch include your pir-battery-ldr, and a light switch, or a option so i can switch a ledlight.
                                        Like a pir-battery-ldr-switch... :-)
                                        I will try to rebuild a solarpowerlight
                                        With a solar powerbank, and a:Light
                                        So i can have a Domoticz controlled solarpower light and motion/ldr [my]sensor
                                        Only i cannot make a sketch for this... [ if you want, i will pay for it..., or a donation to charity organization ]
                                        • D Dylano
                                          n3roN
                                          n3roN
                                          n3ro
                                          @Dylano
                                          you cold try to modify this sketch:
                                          https://github.com/n3roGit/MySensors_n3ro/tree/master/in_process/Multisensor_PIR_DHT_light_switch_battery
                                          its not finished but there is all you need ;)
