  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 346.1k Views 68 Watching
  • A
    A
    aproxx
    @jemish Yeah it seems like I totally forgot to add the switch in the schematic, but I do have it in place in my PCB design :)
    About adding a second relay.. I'm not sure about that yet. Maybe if I can still keep footprint of the board to a size less than 5 by 5 cm I'll add a second one. But it is certainly is a good idea though!
    @scalz I'll definitely have a closer look at your PCB design! Seems really interesting, but unfortunately I don't have the proper tools to go for SMD. Soldering a single SMD component is doable, but I'm not going to start soldering SMD Atmel chips :)
    About the resistor you mentioned: I assume the Solid State Relay which I mentioned doesn't need an external resistor between my arduino and the relay.. According to the datasheet the G3MB-202P-DC5 seems to have a build-in input resistor if I'm not mistaken.
    J 1 Reply Last reply
    • scalzS
      scalzS
      wrote on last edited by scalz
      #42
      @approx: I agree with you. first time I soldered small chips I was afraid as I am not electronician. On youtube there is lots of tutorials for smd soldering. I think maybe one day you should try with solder paste. It is magical! I don't always use it for atmel chips but it is easier.
      and of course flux, desoldering wick, and a magnifier is a must have too. and a 0.2mm tip for soldering iron..
      But your design is cool, I like it too! It could interest people.:smiley:
      S 1 Reply Last reply
      • scalzS scalz
        shabba
        @scalz (sorry OT) I am actually looking at getting a decent (aka not too expensive!) air gun and some paste - preferably with a syringe. Any recommendations on that?
        • scalzS
          scalzS
          #44
          @shabba: I have not an air solder yet, I would like to test it! I have not compared yet existing products. But I think it is useful for desoldering, soldering some chips. Not the best for res, capa...I would prefer solder iron.
          Like many people, I usually use flux and good soldering tin (0.3 with flux in it) with a 0.2 tip. And sometimes I use my solderpaste for fun and for some chips! Something i think I will try to make soon is a smd picker. and then a solder paste dispenser. another thing cool I would like to try is this http://operationalsmoke.blogspot.fr/2014/05/diy-usb-soldering-microscope.html but with a c920. Unfortunately not enough times...
          Sorry for OT too. See you soon
          • A aproxx
            J
            J
            jemish
            @aproxx when you completed the design of PCM board than please share with me as soon as possible.
            • A
              A
              aproxx
              @jemish Of course I'll share the design and all related documents.. :) I hope to have it finished in a few days, and will sure give an update when completed!
              • A
                A
                aproxx
                wrote on last edited by aproxx
                #47
                As promised: In the attachment of this post you can find all required information to build this board.
                The zip file includes all required Gerber files, bill of materials, as well as the Schematic and PCB design (drawn using DipTrace).
                One remark: I've slightly adjusted the design to optimize the reception for the NRF24L01. The antenna of this chip is now placed slightly next to the custom PCB. Hopefully this will result in a better RF reception.
                Size is approximately 47 by 42mm.
                Download (Please be aware that this board is still untested at this moment, so please doublecheck things yourself before ordering!):
                Check latest post for updated version.
                • scalzS
                  scalzS
                  #48
                  @approxx: nice board!
                  could I give you one or two tips? as I have recently designed an ac board too...
                  there is one or two trace which are 90° corner. maybe I am a little old school on this but it is preferable to have 45°. but it should work I think no problem.
                  Your board will not draw too much AC current I think, and I don't know what are your trace widths for AC. but you can check here http://circuitcalculator.com/wordpress/2006/01/31/pcb-trace-width-calculator/ if you want to know width of trace regarding current flow. Then if you can't have the right width because of space... you can use soldermask layer stop and then you will be able to add soldering on all the AC trace and give it more strength for more current drawing. Because most of china fabhouse use 1oz copper. Some 2oz but more expensive.
                  Just my 2cent tip, maybe you already know it, and have already ordered you board.
                  • A
                    A
                    aproxx
                    @scalz Yeah usually I'm going for 45 degree angles as well, but I guess I just forgot for those few. However I do have full confidence in Dirty PCBs, so I'm sure there wouldn't be any disruptions in the trace.
                    Regarding trace thickness/width: I've been doing some calculations as well, but with 1oz copper traces I would need extremely wide traces to come up with a decent copper volume. So my plan is to solder a thin wire at the bottom side of the PCB between the AC connection points. That's why I've got the AC and 5v DC circuits separated as much as possible. :)
                    But thanks for the feedback anyway! And congrats on taking the first step of ordering the board! I'll be doing the same tomorrow.
                    • OitzuO
                      OitzuO
                      Oitzu
                      Looking at your pcbs and looking the same time on my badly soldered dimmer.. i have the gut feeling i should maybe redo this with a proper pcb. :sweat_smile:
                      DrJeffD 1 Reply Last reply
                      • OitzuO Oitzu
                        DrJeffD
                        DrJeffD
                        DrJeff
                        No way that is just like mine! :) It's Perfect!
                        Just Kidding I need to get my dimmers working properly also. You got the zerocross working right? 220v 110v? share sketch? will yours work locally with gateway off?
                        • OitzuO
                          OitzuO
                          Oitzu
                          wrote on last edited by Oitzu
                          #52
                          Yes the zerocrossing is working right. Shouldn't working with gateway off only be a matter of programming? ^^
                          Built vor 220V, but should also run at 110V (with different resistors), need to check the specifications of the combonents again to verify that.
                          I got no working MySensors sketch or a drawn pcb layout yet, but i can describe how it works.
                          Left connectors are (up to down): LOAD: Phase, Neutral; Source: Neutral, Phase
                          Right connectors are (up to down): GND, PWM Output, Zero-Crossing Input, VCC
                          The Zerocrossing detection is done by the bridge rectifier and the zerocrossing detection module 4N25.
                          The Signal goes to a INT-Pin of an arduino.
                          In a test sketch i use a timer and the interrupt to do the correct pwm output.
                          The pwm output goes to the MOC3021 (Opto) that will fire the TRIAC seen left from it.
                          Little test sketch:
                          #include  <TimerOne.h>
                          //Config
                          int INTPin = 0;
                          int outputPin = 11;
                          int dimLevel = 64; // Dim level (0(on)-128(off))
                          int freqStep = 75; //50Hz, should be 65 for 60Hz
                          //Global
                          volatile int i=0; // Counter. Only fire if i >= dimLevel
                          volatile boolean zeroCross=0;
                            pinMode(outputPin, OUTPUT);
                            attachInterrupt(INTPin, zero_cross_detect, RISING);
                            Timer1.initialize(freqStep);
                            Timer1.attachInterrupt(dim_check, freqStep);
                          void zero_cross_detect() {
                            zeroCross = true;
                            i=0;
                            digitalWrite(outputPin, LOW);
                          void dim_check() {
                            if(zeroCross == true) {
                              if(i>=dimLevel) {
                                digitalWrite(outputPin, HIGH);
                                i=0;
                                zeroCross = false;
                              else {
                                i++;
                          • A aproxx
                            J
                            J
                            jemish
                            @aproxx If I want to buy this module then.........
                            If you sell this module then I am ready to buy ...
                            • A
                              A
                              aproxx
                              #54
                              @jemish I've made some minor changes to the board (nothing functional has been changed, just some updated silk screen and modified the 90 degree angles to 45 degree angles.)
                              Please be aware that at this moment the board still isn't confirmed to be working. If you want to be 100% sure everything works properly, I strongly advise to wait for another 5-7 weeks. That way I can assemble the board myself and confirm everything is working as expected.
                              • J
                                J
                                jemish
                                yes I like to wait for your responce.
                                please reply fast as possible.
                                • OitzuO Oitzu
                                  Little test sketch:
                                  //Config
                                  int INTPin = 0;
                                  int outputPin = 11;
                                  //Global
                                    zeroCross = true;
                                    i=0;
                                  void dim_check() {
                                      if(i>=dimLevel) {
                                        i=0;
                                        zeroCross = false;
                                      else {
                                        i++;
                                  DrJeffD
                                  DrJeffD
                                  DrJeff
                                  @Oitzu
                                  I seem to get all this working outside of MYSensors but I have very limited cut and paste ability in code. :) So what I was wondering do you have the sketch for controlling the dimmer and just firing the triac integrated with MYSensors yet?
                                  • A aproxx
                                    J
                                    J
                                    jemish
                                    @aproxx so now, what is the progress??
                                    we will wait for your response.
                                    • A
                                      A
                                      aproxx
                                      @jemish
                                      All components are at my desk at the moment. The only thing missing is.. The PCB itself. :)
                                      DirtyPCBs' website states that the board was shipped to me at August 24. My packets from China usually arrive about 2 or 3 weeks after they have been sent from China, so I expect it to arrive somewhere next week.
                                      After the boards have arrived I'll make sure to have it assembled in less than a week. :)
                                      • A aproxx
                                        @jemish
                                        J
                                        J
                                        jemish
                                        @aproxx please upload new design new that you make now.
                                        • A
                                          A
                                          aproxx
                                          @jemish : The design which I've posted 2 weeks ago (A few posts above this one) is the latest design I have.
