  3. MQ2 Sensor w/AirQuality Sketch
15 Posts 5 Posters 12.8k Views 5 Watching
  • G
    G
    gigaguy
    I bought a gas sensor MQ2 from ebay. trying to figure out how to connect it, and use the Air Quality Sketch.
    http://www.ebay.com/itm/371194045196?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    Ive got the analog connection on A0, not sure if i need to connect the digital pin too or not.
    I am getting a reading of 0ppm for all the measurements in the sketch.
    Any ideas? TIA.
    • R
      R
      robosensor
      I'm using similar sensors, this test sketch works fine for me, but I'm using raw readings from this sensors.
      8 sensors connected to A0-A7 pins on arduino nano directly to analog output pin on each sensor board.
      unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
      #define NODE_ID										4
      MyMessage msg(0, V_VAR1);
      int lastLightLevel[8] = {0};
      unsigned long lastRefreshTime = 0;
      	pinMode(13, OUTPUT);
      	// warm up sensors (3 minutes)
      	for (int i = 0; i < 180; i++)
      		digitalWrite(13, HIGH);
      		delay(250);
      		digitalWrite(13, LOW);
      		delay(250);
      		delay(250);
      		delay(250);
      	gw.begin(NULL, NODE_ID);
      	gw.sendSketchInfo("GasSensors", "1.5");
      	gw.present(1, S_AIR_QUALITY, false, "MQ-2");
      	gw.present(2, S_AIR_QUALITY, false, "MQ-3");
      	gw.present(3, S_AIR_QUALITY, false, "MQ-4");
      	gw.present(4, S_AIR_QUALITY, false, "MQ-6");
      	gw.present(5, S_AIR_QUALITY, false, "MQ-7");
      	gw.present(6, S_AIR_QUALITY, false, "MQ-8");
      	gw.present(7, S_AIR_QUALITY, false, "MQ-9");
      	gw.present(8, S_AIR_QUALITY, false, "MQ-135");
      	gw.wait(100);
      	boolean bNeedRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
      	if (bNeedRefresh)
      		lastRefreshTime = millis();
      	for (int i = 0; i < 8; i++)
      		int lightLevel = 0;
      		for (int j = 0; j < 32; j++)
      			lightLevel += analogRead(i);
      		lightLevel = (lightLevel / 32);
      		int nDifference = lastLightLevel[i] - lightLevel;
      		if ((abs(nDifference) > 5) || bNeedRefresh)
      			gw.send(msg.setSensor(i + 1).set(lightLevel));
      			lastLightLevel[i] = lightLevel;
      Raw ADC readings are 20-80 (differs from sensor to sensor) for fresh outdoor air.
      G 1 Reply Last reply
      • epierreE
        epierreE
        epierre
        you can find the curves for the MQ2 here: https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino
        Check the thread about gas sensors: http://forum.mysensors.org/topic/147/air-quality-sensor/83
        Regarding having 6 electolithic sensors on a nano, check ths out about powering them :
        Arduino Mega is given at : DC Current per I/O Pin 40 mA, so at 5V I have P=5*0,04=0,2w
        When I list all the gases sensors I have this:
        MQ2          5V     0,8 w
        MQ6          5V     0,75w
        MQ131      6V     1,1 w
        MQ135      5V     0,8 w
        MQ138      5V     0,85w
        MS2610    2.35V  0,09w
        TGS2600  5V     0,21w
        TGS2602  5V     0,28w
        HCHO       5V     NA
        z-wave - Vera -> Domoticz
        • R robosensor
          #define NODE_ID										4
          		delay(250);
          		delay(250);
          		delay(250);
          		delay(250);
          	gw.wait(100);
          	if (bNeedRefresh)
          		int lightLevel = 0;
          G
          G
          gigaguy
          wrote on last edited by gigaguy
          @robosensor What is on pin 13? In the Setup() warmup part?
          btw, I am getting a value of 1 or 2, after warmup.
          R 2 Replies Last reply
          • G gigaguy
            R
            R
            robosensor
            @gigaguy pin 13 connected to board's led :)
            Warm up is just 3-minute pause (with led blinking) between power up and start of main loop measurements transmission. Cold sensors shows very big measurements, so I heating them up for 3 minutes.
            • G gigaguy
              R
              R
              robosensor
              wrote on last edited by robosensor
              @gigaguy
              example response of sensors for natural gas (left) and alcohol (right):
              • epierreE
                epierreE
                epierre
                @robosensor this graph shows well the limit ofg the MQ gas sensors, they somehow all react to the same gases, and thus are not one gas specific.
                R 1 Reply Last reply
                • epierreE epierre
                  R
                  R
                  robosensor
                  @epierre in general, you are right, but there are exceptions.
                  This measurements, but one sensor per graph:
                  And 6-day graph of all sensors:
                  • epierreE
                    epierreE
                    epierre
                    @robosensor sure, but people need to know not to rely for their life on these classes of sensors.
                    • V
                      V
                      Viper_Scull
                      is it normal that the reads of my MQ-2 sensor are 0ppm in fresh air?
                      If I use a lighter to throw some gas, the reads skyrocket and then without gas they go back to zero.
                      Should I adjust the sensitivity?
                      • epierreE
                        epierreE
                        epierre
                        @Viper_Scull If you follow my method, it considers clean air has no toxic gas so it should be 0.
                        If you are able to do a calibration, you could change that, but I would recommend to keep the straight lean air way if you cannot do that.
                        V 1 Reply Last reply
                        • epierreE epierre
                          V
                          V
                          Viper_Scull
                          @epierre I use the AirQualitySensor example in the MySensors library that I believe is your work indeed. Happy now to know that it's ok 0ppm for clean air.
                          One thing I noticed on the sketch is that last_mq inital value is 0. If we are in clean air, no value is send to the gateway when connected because val_mq = last_mq, so the controller would have no data to display unless it sets it to zero by default or gas is present.
                          By the way, I can't get domoticz to recognize this sensor. It receives the name of the sketch and the version, but although I can see that the sensor sends the value, there's no sign of it in the log of domotic and no device is recognized.
                          • epierreE
                            epierreE
                            epierre
                            @Viper_Scull I have someone else reporting this, you should ask @GizMoCuz for him to support it
                            • V
                              V
                              Viper_Scull
                              @epierre, already asked. Turns out, domoticz doesn't support V_VARs. Changing V_VAR1 in the sketch for V_DUST_LEVEL works.
                              • V Viper_Scull
                                Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                @Viper_Scull Domoticz supports V_VARs, just not as a viewable or modifiable value on the controller. It will store and return the V_VARs values for the sketch, nothing more.
