  3. MQ2 Sensor w/AirQuality Sketch
15 Posts 5 Posters 12.9k Views 5 Watching
  • G gigaguy
    @robosensor What is on pin 13? In the Setup() warmup part?
    btw, I am getting a value of 1 or 2, after warmup.
    R
    R
    robosensor
    @gigaguy pin 13 connected to board's led :)
    Warm up is just 3-minute pause (with led blinking) between power up and start of main loop measurements transmission. Cold sensors shows very big measurements, so I heating them up for 3 minutes.
    • G gigaguy
      R
      R
      robosensor
      wrote on last edited by robosensor
      @gigaguy
      example response of sensors for natural gas (left) and alcohol (right):
      • epierreE
        epierreE
        epierre
        @robosensor this graph shows well the limit ofg the MQ gas sensors, they somehow all react to the same gases, and thus are not one gas specific.
        z-wave - Vera -> Domoticz
        R 1 Reply Last reply
        • epierreE epierre
          R
          R
          robosensor
          @epierre in general, you are right, but there are exceptions.
          This measurements, but one sensor per graph:
          And 6-day graph of all sensors:
          • epierreE
            epierreE
            epierre
            @robosensor sure, but people need to know not to rely for their life on these classes of sensors.
            • V
              V
              Viper_Scull
              is it normal that the reads of my MQ-2 sensor are 0ppm in fresh air?
              If I use a lighter to throw some gas, the reads skyrocket and then without gas they go back to zero.
              Should I adjust the sensitivity?
              • epierreE
                epierreE
                epierre
                @Viper_Scull If you follow my method, it considers clean air has no toxic gas so it should be 0.
                If you are able to do a calibration, you could change that, but I would recommend to keep the straight lean air way if you cannot do that.
                V 1 Reply Last reply
                • epierreE epierre
                  V
                  V
                  Viper_Scull
                  @epierre I use the AirQualitySensor example in the MySensors library that I believe is your work indeed. Happy now to know that it's ok 0ppm for clean air.
                  One thing I noticed on the sketch is that last_mq inital value is 0. If we are in clean air, no value is send to the gateway when connected because val_mq = last_mq, so the controller would have no data to display unless it sets it to zero by default or gas is present.
                  By the way, I can't get domoticz to recognize this sensor. It receives the name of the sketch and the version, but although I can see that the sensor sends the value, there's no sign of it in the log of domotic and no device is recognized.
                  • epierreE
                    epierreE
                    epierre
                    @Viper_Scull I have someone else reporting this, you should ask @GizMoCuz for him to support it
                    • V
                      V
                      Viper_Scull
                      @epierre, already asked. Turns out, domoticz doesn't support V_VARs. Changing V_VAR1 in the sketch for V_DUST_LEVEL works.
                      • V Viper_Scull
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @Viper_Scull Domoticz supports V_VARs, just not as a viewable or modifiable value on the controller. It will store and return the V_VARs values for the sketch, nothing more.
                        12.5k
