  3. Sensor works only connected through FTDI... Please help
6 Posts 3 Posters 2.3k Views 2 Watching
  • Moshe LivneM
    Moshe LivneM
    Moshe Livne
    I have built my first aircon monitoring sensor. Works on a 3.3v pro mini with voltage reg and led cut out. Very simple really - connected to NRF and reed switch short d3 to gnd. It is powered by CR123 battery. While connected to the computer using a 3.3v FTDI its working fine. When connected using the CR123 it does nothing. I have checked voltage on the battery and its 3.12v.
    The battery is connected to RAW and GND pins.
    As I can't see the serial monitor messages while connected to the battery, I am a bit blind. Any help will be greatly appreciated!
    SparkmanS 1 Reply Last reply
    • Moshe LivneM Moshe Livne
      SparkmanS
      SparkmanS
      Sparkman
      @Moshe-Livne The raw pin is connected to the input side of the voltage regulator. Since you don't have a voltage regulator anymore, there's no path to power the chip. You need to connect it to the Vcc pin.
      Cheers
      Al
      • SparkmanS Sparkman
        Cheers
        Al
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @Sparkman You are my hero! Thanks!!! Moved to vcc and everything works!
          SparkmanS
          SparkmanS
          Sparkman
          @Moshe-Livne :laughing: Great, glad you got it working!
          Cheers
          Al
          • A
            A
            Andreas Maurer
            Perhaps this makes clear what happend:
            https://cdn.sparkfun.com/assets/0/7/5/5/1/51eec304ce395f104c000000.png
            • A Andreas Maurer
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @Andreas-Maurer In retrospect it is very obvious....
