  3. Problem with Ethernet GW - W5100
5 Posts 3 Posters 2.6k Views 1 Watching
  • T
    tomkxy
    Yesterday I successfully ran my Ethernet Gateway (Ethernet Shield with Uno) with the MQTT Client from Norbert Truchsess. I was able to receive sensor data and it published it to my MQTT broker.
    Today I wanted to continue on that and I receive only 0;0;3;0;9;check wires.
    I can ping the Gateway. I also successfully ran a WebServer sketch on that setup.
    I have no idea how to proceed. Any suggestions???
    Cheers,
    Thomas
    • T
      tomkxy
      Interesting: My Fritzbox does not list the gateway as active connection.
      Is there any experience with the Ethernet shields coming from China?
      Cheers,
      Thomas
      • Q
        Q
        Qu3Uk
        I'm having the same problem but not really done enough troubleshooting myself. I built a serial gateway after starting over with the Ethernet gateway a couple of times with the same issue.
        Serial gateway works fine and I happened to notice the Ethernet gateway wiring page doesn't mention IRQ pin but the serial does.. Not sure how much that has anything to do with it but just something I noticed. I'm assuming the radio bit was at fault due to the pins differing between the serial and Ethernet gateways..
        • sundberg84S
          I remember i had the same problem and had to change some pins for the radio. This can be Changed in the softspi in the lib. I dont know why that worked but maybe i had a bad shield / UNO. I think it was from here i solved it: http://forum.mysensors.org/topic/466/ethernet-gateway-problem/21
          • T
            tomkxy
            I am a complete idiot. When I continued my work the day before yesterday, I recompiled but forgot to enable SOFT_SPI. After it failed, I checked the wiring and re-wired wrongly. So SOFT_SPI was set but indeed the wiring was wrong then.
            It seems to be solved. Let's see how stable it will be. Thanks four your support!!!
            Cheers,
            Thomas
