  3. Vera
  4. Override Function
Override Function
8 Posts 2 Posters 3.6k Views 1 Watching
  • A
    A
    Atomfire
    I have just received my Vera Edge and did the basic setup, I was wondering if there is an override function i.e. if I create a scene which switches on the lights when it gets dark and there is movement in the room BUT I am watching a moving and want to override the basic functionality and switch the lights off. How is this handled in vera, is it built in functionality or is it something I need to create logic for, or should I try creating a plugin?
    • BulldogLowellB
      BulldogLowellB
      BulldogLowell
      look into PLEG plugin on the Vera forum... 100% worth the few dollars and can do what you want.
      A relatively steep learning curve, but the developer supports it nearly real-time.
      • A
        A
        Atomfire
        I had already decided that I will need PLEG and happy to pay for it, is this standard functionality within PLEG or I need to put together the logic myself?
        • A Atomfire
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @Atomfire
          lots of examples on the Vera Forum, so you have to use that.
          @petewill did a youtube video you can search for here, it will help. The interface can be a challenge at first.
          • A
            A
            Atomfire
            I have been finding the iOS app interface is quite slow, I tested openhab before putting the money down on Vera and it was much quicker although a bit old looking. But OpenHab looked like a bit too much to bite off for my first foray into home automation.
            • A Atomfire
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              For Vera, look into Vera Mate iOS app
              • A
                A
                Atomfire
                Thanks for the heads up with the app, it certainly seems a lot better, setup the geofencing tonight so will see how that works out. I need to have a look at PLEG next and see how it ticks, unfortunately no sign of any of my sensors yet :(
                • A
                  A
                  Atomfire
                  Where about in Scotland are you?
