  3. can't reboot a node with a certain sketch loaded
5 Posts 4 Posters 2.2k Views 1 Watching
  • joshwJ Offline
    joshwJ Offline
    joshw
    wrote on last edited by joshw
    I made an attempt at combining the DallasTemperatureSensor and RelayActuator sketches, and after a couple tries I thought I had gotten it right - everything works as intended, except for one thing. If I try to reboot the node from MYSController (either individually or as a broadcast to all nodes), it shuts down (relays click off) but never starts back up. Node has no problem rebooting with a different sketch loaded. Also, it starts working fine again after a power cycle or manual reset.
    What did I miss? It's driving me nuts.
    Thanks in advance,
    Josh
    #include <OneWire.h>
    #define ONE_WIRE_BUS 3 // Pin where dallas sensor is connected
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    unsigned long SLEEP_TIME = 10000; // Sleep time between reads (in milliseconds)
    OneWire oneWire(ONE_WIRE_BUS);
    // int node_id = 99;
    int numSensors = 0;
    boolean metric = false;
    MyMessage msg(5, V_TEMP);
      // Startup OneWire
      sensors.begin();
      // gw.begin(incomingMessage, node_id, true);
      gw.sendSketchInfo("Relay plus Temp", "1.6");
      // Fetch relay status
      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor) ? RELAY_ON : RELAY_OFF);
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        gw.present(i, S_TEMP);
      gw.process();
        float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
        if (lastTemperature[i] != temperature && temperature != -127.00) {
          gw.send(msg.setSensor(i).set(temperature, 1));
          lastTemperature[i] = temperature;
      gw.wait(SLEEP_TIME);
        // Change relay state
        digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
    hekH 1 Reply Last reply
    • G Offline
      G Offline
      gonzalonal
      Hi, I have a similar issue.
      Myabe you can post your peoblem in the following thread:
      http://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors/209
      regards.
      • Z Offline
        Z Offline
        Zeph
        How much RAM do you have left?
        I don't know if it's related, but it's one of the first things I check (nowadays, having too little remaining hair to spare) when things go weird and I have no other good hypothesis. If there's plenty of RAM left, I keep looking for another cause. (I don't currently have any theory about what really happens when you try to reboot - if it successfully gets all the way to a uC reset and hardware reboot, then memory would be reallocated from scratch so this would not apply, so an out of memory bug would probably have to happen earlier in the process).
        What matters here is the space between the stack and the heap (without tracing any freed blocks on the heap to get total free memory). I use a variant of this technique which uses very little program and data memory:
        http://forum.pololu.com/viewtopic.php?f=10&t=989&view=unread#p4218
        • joshwJ joshw
          Thanks in advance,
          Josh
          int numSensors = 0;
            // Startup OneWire
            sensors.begin();
            gw.process();
          hekH Offline
          hekH Offline
          @joshw
          Could also be a classic powering issue when using power hungry relays.
          • Z Offline
            Z Offline
            Zeph
            Could be power I suppose. You say that it reboots OK with other sketches. Do both the relay and temp sensor single-sensor sketches reboot OK?
            I was assuming so, which is why I was thinking something software rather than hardware, but assuming is what gets us stuck, debug wise.
