  3. Relay sensors stop communicating with gateway after a few minutes
27 Posts 10 Posters 16.9k Views 4 Watching
  • sundberg84S
    I thought the same, it was how i detected i had 12v relays instead of 5v. I just quickly powered with 9v bat and then the relay clicked.
    • R
      R
      rafael.brasilia
      Thanks for the heads up. But I tried 9v and 12v and no luck! They only click when powered directly from the Arduino and they stop working after a few hours.
      • NuubiN
        NuubiN
        Nuubi
        You should probably draw a circuit diagram about your connections?
        R 1 Reply Last reply
        • NuubiN Nuubi
          R
          R
          rafael.brasilia
          @Nuubi
          This is how I have my connections:
          Is there anything wrong with it?
          Thanks!
          • korttomaK
            korttomaK
            korttoma
            Try adding a wire between the GND on your relay board and GND on your arduino. Even if they have seperate power source you stil need to connect GND between them.
            • Tomas
            • NuubiN
              NuubiN
              Nuubi
              Exactly that is the reason. Yep.
              • R
                R
                rafael.brasilia
                YES!!! That was it! I got both relays powered from the external power supply now and everything seems to be working fine.
                Thank you all very much!
