  3. Relay sensors stop communicating with gateway after a few minutes
27 Posts 10 Posters 17.0k Views 4 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    It's a strange problem. In most of my "projects" I power the relays directly from the power supply, home built or mfg and other than adding some capacitors have not seen these problems. Now I aways use Opto-controled relays so I don't have to use any diodes...
    RJ_Make
    R 1 Reply Last reply
    • RJ_MakeR RJ_Make
      R
      R
      rafael.brasilia
      wrote on last edited by rafael.brasilia
      @ServiceXp
      What kind of power supply do you use to power the relays? I've tried several different options (iPhone charger, iPad charger, and various other 5v power supplies) but no luck. The LEDs on the relay turn on, but it doesn't click. Would you have a picture of one of your relays so I can see your setup?
      I also tried following the advice from @BulldogLowell and powered the relays from the VIN pin instead of the Arduino 5v output, but I had the same problem. The relay worked for a few hours, then stopped working.
      FYI: I am using a relay with optocoupler just like the one posted in the link above. Maybe I just got a batch of bad Arduinos from China?
      SparkmanS 1 Reply Last reply
      • R rafael.brasilia
        @ServiceXp
        SparkmanS
        SparkmanS
        Sparkman
        wrote on last edited by Sparkman
        @rafael.brasilia I'm wondering if the relays are actually 9VDC or 12VDC relays that are misprinted as 5VDC. What happens if you power them with a 9V battery as a quick test? I use old phone chargers with similar 5V relays and never had an issue with powering them that way. Do you have any other relays you can test with?
        Al
        • sundberg84S
          sundberg84S
          I thought the same, it was how i detected i had 12v relays instead of 5v. I just quickly powered with 9v bat and then the relay clicked.
          • R
            R
            rafael.brasilia
            Thanks for the heads up. But I tried 9v and 12v and no luck! They only click when powered directly from the Arduino and they stop working after a few hours.
            • NuubiN
              NuubiN
              Nuubi
              You should probably draw a circuit diagram about your connections?
              • NuubiN Nuubi
                R
                R
                rafael.brasilia
                @Nuubi
                This is how I have my connections:
                Is there anything wrong with it?
                • korttomaK
                  korttomaK
                  korttoma
                  Try adding a wire between the GND on your relay board and GND on your arduino. Even if they have seperate power source you stil need to connect GND between them.
                  • Tomas
                  • NuubiN
                    NuubiN
                    Nuubi
                    Exactly that is the reason. Yep.
                    • R
                      R
                      rafael.brasilia
                      YES!!! That was it! I got both relays powered from the external power supply now and everything seems to be working fine.
                      Thank you all very much!
                      12.5k
