  3. New sketches: UV, WaterMeter for Reed sensors, Air quality ...
3 Posts 2 Posters 3.5k Views 2 Watching
  • epierreE
    epierreE
    epierre
    wrote on last edited by epierre
    Lost posts, but the sketches are still here:
    https://github.com/empierre/arduino
    • MQ135.ino : for CO2/COV ... validated
    • MQ2.ino : for ethanol... still ongoing...
    • PressureSensor.ino : validated, works well, too much temp reading given back
    • SoundSensor2.ino: not yet tested
    • UVsensor.ino : validated
    • WaterMeterPulseSensor2.ino : for use with water meter that have a reed switch, validated
    Next steps:
    • validate sound sensor
    • validate mq2 sensor (I dont smoke...hart to trigger...)
    • MQ6 sensor
    • MQ131 sensor
    • TGS2600 sensor
    z-wave - Vera -> Domoticz
    • mooM
      mooM
      moo
      Hi, I bought these MQ sensors collection from ebay and soldered them on their boards.
      Connected them this way:
      Arduino VCC ---> MQ2 VCC
      Arduino GND ---> MQ2 GND
      Arduino A0 ----> MQ2 AOUT
      not connected ---- MQ2 DOUT
      I tried AirQuality.ino, MQ2.ino, and http://sandboxelectronics.com/?p=165.
      Serial monitor outputs 0ppm on every parameter. Tried blowing cigarette smoke in MQ2 with no luck.
      MQ2 PCB SMD board has four outputs like the one on the MySensors store , and it has a pot on it. Sketch from http://sandboxelectronics.com/?p=165 after calibration outputs R0 resistance (3.65kohm). Should I tune that pot to the point when the sketch outputs ~10kohm?
      I have read on Arduino playground that MQ sensors should have burn-in period (12-24 h) to make their readings more consistent. But if there are no readings I shold not expect readings from it.
      Does someone have any advice to get this sensor reading? Cheers, Dario.
      Testing NodeJsController on Ubuntu, Linux mint, OpenWrt and Raspbian
      Experimenting with bootstrap and d3 for NodeJsController front-end
      • epierreE
        epierreE
        epierre
        first the pot is only for the digital output, it has no effect on the analog one.
        second, check your wiring, the analog should always report something, make sure the analog you use in the sketch is the one wired ... basic mistake... same for the 5V and ground.
        there is also a led on the board, if the board is correctly powered at some moment the led should turn up.
