  3. LEDs Blinking does not work
2 Posts 1 Posters 1.3k Views 1 Watching
  • Stephan NollerS
    Stephan NollerS
    Stephan Noller
    I did connect the three LEDs as suggested in advanced build options, included
    #define WITH_LEDS_BLINKING
    in my MyConfig.h but the LEDs don't seem to work properly (no light at all).
    Also tried to include this in the code directly:
    #define RADIO_ERROR_LED_PIN 6 // Error led pin
    #define RADIO_RX_LED_PIN 5 // Receive led pin
    #define RADIO_TX_LED_PIN 4 // the PCB, on board LED
    But same behavior.
    I am trying to get this running on a sensor node, not the gateway, but as i understand the comment under advanced build options this should not be a problem (tried gw sketch but LEDs still don't light up). Tested LEDs with a blink-sketch and they do work.
    Am i getting something wrong? Anything missing in settings or so?
    • Stephan NollerS
      Stephan NollerS
      Stephan Noller
      I have to correct myself. LEDs are indeed lighting, it's just hard to recognize, guess because i am working with 3.3 volt instead of the 5v as recommended. Nevertheless, i get a green LED even though measurement values are not reaching the controller...
