  3. coin-cell (CR2032) powered temperature sensor
39 Posts 10 Posters 27.1k Views 18 Watching
  • carlekiC carleki
    @fleinze said:
    @carmelo42
    The no-resistor-library can be found here:
    https://wp.josh.com/2014/06/23/no-external-pull-up-needed-for-ds18b20-temp-sensor/
    The resistors (there are two but the other one is barely visible) are for voltage-measurement. In a later version I got rid of them using this resistor-less method of measurement:
    http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    great :)
    Did you change the bootloader ? Which one did you use ?
    F
    F
    fleinze
    @carmelo42 sorry I somehow missed your post. I use the standard-bootloader as I did not get Optiboot to run on the 3.3V/8MHz pro minis. I set the extended fuse to 0x07 (BOD disabled) by editing boards.txt.
    carlekiC 1 Reply Last reply
    • F fleinze
      carlekiC
      carlekiC
      carleki
      thanks !
      is is a bit confusing for me :
      • we can burn the bootloader from the Arduino IDE : are the fuses written at this moment ?
      • we can upload a sketch with the arduino IDE : are the fuses written at this moment ?
      • with my researches, I found that for disabling BOD was possible with 0xFF value for efuse ?
      I have some lifetime issues with my CR2032 sensor .. and I suspect the fuses are not correctly set ...
      If you can light up my mind it will be perfect :)
      • F
        F
        fleinze
        @carmelo42 The fuses only are written when you burn the bootloader, not when uploading the sketch. The Arduino IDE takes the fuse bytes from the boards.txt files.
        It would also be possible to just set the fuse bytes by using the avrdude-program from a command line, but you will still need to use a programmer.
        The extended-fuse setting 0xFF is the same as 0x07 as only the last 3 bits of this bytes are used. Both values will give you BOD disabled.
        • F
          F
          fleinze
          I just added an 100uF capacitor to one of my sensors and put an old battery in. Let's see how much more life I can get out of this battery now.
          F 1 Reply Last reply
          • carlekiC
            carlekiC
            carleki
            wrote on last edited by carleki
            #25
            @fleinze
            Hi, do you think it's possible to connect de Dallas sensor to pin 7, 8 and 9 of the arduino ?
            Like this :
            #define ONE_WIRE_BUS 8 // Pin where dallase sensor is connected
            #define ONE_WIRE_GND 9
            #define ONE_WIRE_VCC 7
            I have tried, and the temperature is always 85°C ...
            Nca78N 1 Reply Last reply
            • carlekiC carleki
              @fleinze
              Like this :
              Nca78N
              Nca78N
              Hello @carmelo42, pin 9 is supposed to be connected to the NRF24 (CE / Chip Enable) so it cannot work as ground for the sensor as it will be high (and so = to Vcc) most if not all of the time.
              • F fleinze
                F
                F
                flopp
                Very interest work.
                Is it still working?
                • Moebius LutchingM
                  Moebius LutchingM
                  Moebius Lutching
                  There is a TI paper about adding a big capacitor in series with the coin-cell battery to minimize the voltage drop during high-current peaks: http://www.ti.com/lit/wp/swra349/swra349.pdf, also another interesting article related to low-power and CR2032: http://www.low-powerdesign.com/121312-article-extending-battery-life.htm
                  • F flopp
                    Very interest work.
                    F
                    F
                    fleinze
                    @flopp I added the capacitor and put the old battery in. By old battery I mean the one I had replaced a week earlier for a new one. Sensor running smooth since, so great success!
                    • F fleinze
                      F
                      F
                      flopp
                      @fleinze
                      :thumbsup:
                        mihai.aldea
                        The DS18B20+ is not a great sensor for the battery powered nodes. It has a huge conversion time comparing to others.
                        9-bit resolution | 93.75 ms | 0.5°C
                        10-bit resolution | 187.5 ms | 0.25°C
                        11-bit resolution | 375 ms | 0.125°C
                        12-bit resolution | 750 ms | 0.0625°C
                        The last column is the sensor's precision. So unless you're OK with a 0.5°C steps, the simple usage of DS18B20+ will kill your battery a lot faster.
                        Don't use DHT22, that one is very slow too. BME280 does have a barometric pressure sensor but it's not very fast either.
                        The best sensor for battery powered nodes is the the Si7021 which is rather old, but is the fastest.
                        • F
                          F
                          fleinze
                          I put the arduino to sleep during the conversion time, so this is not a big issue. But I agree that the DS18B20 is not the best, but it is widely available. For newer nodes I try to use the Si7021 where possible.
                          M T 2 Replies Last reply
                          • F fleinze
                            mihai.aldea
                            It goes without saying that the nodes are in sleep mode between reports. However, the conversion time has a great impact in the cycle math. I won't say that pulling the readings 10 times faster will give you 10 times more time on battery but if you'll get 5 times more time then it's something. Not to mention that the Si7021 works down to 1.9V unlike the DS18B20+ which works down to only 3.0V.
                            • F fleinze
                              tango156157
                              @fleinze Great work with the CR2032 coin cell temp. sensor. I am trying to do a similar exercise with Si7021 sensors but getting into issues while coding. The examples from other posts around Si7021 adapted for latest MySensor lib seem to get stuck in my IDE giving lot of errors. I have tried getting all the required Header files but still get stuck due to some random error. Is it possible for you to share your code based on CR2032 temp node running on Si7021? Thanks....
                                mihai.aldea
                                @tango156157, I sometimes get similar errors while compiling the sketches. Mostly because I am still using the MySensors 1.5 library for my legacy network, 2.1.0b for the RFM69 network (working RSSI report) and 2.1.1 for the LoRa network.
                                Mostly when dealing with MySensors 1.5 and/or older sensors libraries, I find the newer Arduino version to pop all sort of errors. But then I fire up one of the older Arduino IDE versions I have, 1.6.5, 1.6.9 and so on. Eventually one of them compiles the sketch without errors while the newer version don't work. This is far from being a solid solution for these errors, but it gets the job done.
                                You should try that too, especially if you're using older libraries for your sensors.
                                You can find them here: https://www.arduino.cc/en/Main/OldSoftwareReleases#previous
                                • F
                                  F
                                  fleinze
                                  this is my code working with 2.1 version. The code is not tidied up, please excuse.
                                     MySensors-Node for DS18B20 Temperature-Sensors.
                                     Mysensors.Library-Version 1.6
                                  #define MY_TRANSPORT_UPLINK_CHECK_DISABLED
                                  //#define MY_DEBUG
                                  #include <Wire.h>
                                  #include <SI7021.h>
                                  #define BATT_SENSOR
                                  //#define VCCGND_PINS
                                  #ifdef VCCGND_PINS
                                  const uint8_t GND = A2;
                                  const uint8_t VCC = A3;
                                  #ifdef BATT_SENSOR
                                  #define REPORT_VOLTAGE
                                  const unsigned long SLEEP_TIME = 300000; // Sleep time between reads (in milliseconds)
                                  const uint8_t TEMP_TIME = 12; //at least every nth time battery is reported
                                  const uint8_t HUM_TIME = 12;
                                  const uint8_t BATT_TIME = 12; //when also BATT-LEVEL is reportet
                                  const float BATT_100 = 3; //3.3V for CR2032, 3V for 2xAA
                                  const float BATT_0 = 2.2;
                                  SI7021 sensor;
                                  float lastTemperature, lastHum;
                                  uint8_t lastTempSent = 0;//, lastHumSent = 0;
                                  uint8_t numSensors = 0;
                                  boolean metric = true;
                                  MyMessage msgTemp(0, V_TEMP);
                                  MyMessage msgHum(0, V_HUM);
                                  #ifdef REPORT_VOLTAGE
                                  MyMessage msgBatt(1, V_VOLTAGE);
                                  #ifdef BATT_SENSOR
                                  uint8_t battReport = BATT_TIME - 1; //First report at startup
                                  long oldvalue = 0;
                                    #ifdef VCCGND_PINS
                                    pinMode(VCC, OUTPUT);
                                    digitalWrite(VCC, HIGH);
                                    pinMode(GND, OUTPUT);
                                    digitalWrite(GND, LOW);
                                    if (!sensor.begin()) {
                                      Serial.println("No Sensor found!");
                                      while (true);
                                  void presentation() {
                                    sendSketchInfo("TempHumSi7021", "0.1a");
                                    present(0, S_HUM);
                                    //present(1, S_HUM);
                                    present(1, S_MULTIMETER);
                                    //delay(2000);//for sensor to start up
                                    boolean tempsent = false;
                                    si7021_thc temphum = sensor.getTempAndRH();
                                    float temperature = (float)(temphum.celsiusHundredths) / 100.0;
                                    float humidity = (float)(temphum.humidityPercent);
                                    if ((lastTemperature != temperature) || lastHum != humidity || (++lastTempSent >= TEMP_TIME)) {
                                      lastHum = humidity;
                                      lastTemperature = temperature;
                                      lastTempSent = 0;
                                      tempsent = true;
                                  #ifdef BATT_SENSOR
                                    if (++battReport >= BATT_TIME && tempsent) {
                                      //gw.sleep(10);
                                      long value = readVcc();
                                      if (value != oldvalue) {
                                        int percent = (( (float)(value) / 1000 ) - BATT_0) / (BATT_100 - BATT_0) * 100;
                                        percent = (percent > 100) ? 100 : percent;
                                        percent = (percent < 0) ? 0 : percent;
                                        sendBatteryLevel(percent);
                                        send(msgBatt.set((float)(value) / 1000, 2));
                                      oldvalue = value;
                                      battReport = 0;
                                    sleep(SLEEP_TIME);//wake on interrupt or after sleep-time
                                  long readVcc() {
                                  #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                                    ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
                                  #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                                    ADMUX = _BV(MUX5) | _BV(MUX0);
                                  #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
                                    ADMUX = _BV(MUX3) | _BV(MUX2);
                                  #else
                                    while (bit_is_set(ADCSRA, ADSC)); // measuring
                                    long result = (high << 8) | low;
                                  T 1 Reply Last reply
                                  • F fleinze
                                    //#define MY_DEBUG
                                    #include <Wire.h>
                                    #include <SI7021.h>
                                    #define BATT_SENSOR
                                    #ifdef VCCGND_PINS
                                    #ifdef BATT_SENSOR
                                    SI7021 sensor;
                                    #ifdef BATT_SENSOR
                                    long oldvalue = 0;
                                      #ifdef VCCGND_PINS
                                        while (true);
                                      present(0, S_HUM);
                                        lastHum = humidity;
                                        lastTempSent = 0;
                                        tempsent = true;
                                    #ifdef BATT_SENSOR
                                        //gw.sleep(10);
                                        oldvalue = value;
                                        battReport = 0;
                                    long readVcc() {
                                    #else
                                    tango156157
                                    @fleinze thanks for sharing your code for Si7021 sensor. I tried compiling but getting below error. Not sure if I am using incorrect header file for Si7021 sensor. I am using MySensors ver 2.1.0 for compiling. Any view? Thanks
                                    C:\Users\abc\AppData\Local\Temp\arduino_modified_sketch_641038\sketch_may14a.ino: In function 'void loop()':
                                    sketch_may14a:91: error: 'si7021_thc' was not declared in this scope
                                    sketch_may14a:91: error: expected ';' before 'temphum'
                                    sketch_may14a:95: error: 'temphum' was not declared in this scope
                                    Multiple libraries were found for "SI7021.h"
                                     Used: C:\Users\abc\Documents\Arduino\libraries\SI7021
                                     Not used: C:\Program Files (x86)\Arduino\libraries\SI7021
                                    exit status 1
                                    Insert Code Here
                                    • T tango156157
                                      exit status 1
                                      Insert Code Here
                                      F
                                      F
                                      flopp
                                      @tango156157
                                      Look you have more than one library for si7021.
                                      Move one library and then try again.
                                      If that doesn't help.
                                      Move back the first library and move the second one, try again and see if that helped
                                      • E
                                        E
                                        Edoardo Vogna
                                        Hello fleinze,
                                        What about this project? Your sensors still working?
                                        I'm trying to build the same but I have some problem to change the efuse value:
                                        "I changed the efuse value to 0x07 (BOD off)"
                                        I' dont know how to edit the boards.txt file and how to install it in the arduino pro mini.
                                        Could you explain the procedure step by step or link me a good complete tutorial ?
                                        Thank you very much
