  3. Low Power: How much current? [Solved]
109 Posts 10 Posters 85.7k Views 11 Watching
  • B Offline
    B Offline
    brolly759
    @NeverDie I never had issues with Gammon's code on v1.6.5 . I had issues with the mysensors v1.4 library with v1.6.5 of Arduino IDE. My power problems went away when I switched to v1.5 of mysensors library. I have stopped troubleshooting for now as I am slightly burnt out but my last test on v.1.6.5 with v1.5 MySensors gave me strange results sometimes. If I edited any files in the sleep mode functions I would not be able to go back to sleep. I was draw a constant ~3mA.
    Congrats though and welcome to the club. I think I am going to just combine nRF Mesh + gammon's code to make my own mesh network setup. (When I actually know programming) ;)
    • N Offline
      N Offline
      Does everything which is turned off in Sketch J automatically get turned on again during wake-up? Or, does it remain off? I notice that Sketch J repeats turning everything off again before going to sleep, each and every time. There are some things which I may not being using, like I2C and ADC, which it would make sense to leave turned off. Likewise, no reason to wakeup SPI on every 8 second cycle unless there's a reason to use the radio.
      Furthermore, it would save valuable time at higher currents not needing to turn them off again. Anyone happen to know, or will I need to run experiments?
      • N Offline
        N Offline
        #103
        By the way, perhaps a good argument in favor of an external interrupt for waking up is that it could wakeup the arduico and the radio in parallel. If the arduino wakes itself up through WDT and subsequently wakes up the radio, then it has to waste time waiting at high currents while the radio wakes up.
        Just a thought at present, as I don't know how feasible this would be.
        • N Offline
          N Offline
          #104
          In case anyone is curious as to what happens when an Arduino is waking up from sleep, this picture tells the story:
          I powered an 8Mhz Pro Mini using a 5.1V battery (because it was convenient), and set it using "Sketch I" to wake up every 16ms and then immediately go back to sleep. The picture shows the Pro Mini draws about 500uA for about 2.1ms, then it surges up to about 6.5ma (I suppose at this point it is "awake"), and then voltage plummets back down again as it returns to sleep. When asleep it draws about 3.5uA. I measured the current using a 1ohm sense resistor, so in the picture 1mv=1ma. When measuring milliamps, I seem to get a much clearer picture (less noise) using a 1ohm sense resistor than I do using the UCurrent Gold.
          In his write-up, Gammon warns that, depending on the sleep duration, this warm-up period can be as long as 65ms!
          "Warning about wake-up times
          Various fuse settings make a big difference to the wake-up time. Some wake-up times are quite long (eg. 65 mS) because they are designed to allow the crystal clock to settle. If you are trying to save power, taking 65 mS to wake up, add 1 to a counter, and go back to sleep, is a lot. You would want to look at a "wake-up" fuse setting that is appropriate for the type of clock source you are using."
          I wish he had been more clear about how the sleep settings affect the length of the wake-up period. Perhaps he or somebody else explains that elsewhere.
          • S Offline
            wrote on last edited by scalz
            #105
            @Neverdie: hi. you are doing interesting tests. for the question about 65ms.. I am not sure. I think Gammon was referring about the CKSEL fuses, oscillator config fuses. it is described in datasheet from 8.2.2.
            • E Offline
              E Offline
              engy
              Hello guys,
              I'm reading your post, and that is amazing... you're fighting with u/nAmps.
              However, I'm concerned about mAmps :)
              The lowest what I can get with Atmega328 + NRF24 on breadboard is 1mA.
              What I've done:
              Flashed Atmega328p with ATmegaBOOT_168_atmega328_pro_8MHz.hex
              Uploaded BinarySwithchSleepSensor sketch with FDTI. Tried: API 1.4/1.5, IDE 1.0.6/1.6.5 (no difference)
              Powered the sensor directly with 2xAA
              Changed ext fuses to x07 (no BOD)
              Connected NRF24 according to MySensors instructions
              On the breadboard I have only:
              Atmega328p
              NRF24
              10k resistor on 1st/reset pin.
              With this set up minimum what I can get is:
              Atmega328p w/o NRF - 3pin con - 0.1mA /not con - 3.4mA
              Atmega328p with NRF - 3pin con - 1.09mA /not con - 1mA
              I'm using cheap multi-meter, however, with Gammon's J sketch - it shows 3uA without NRF.
              I'm struggling almost a week, and can't understand, why you guys achieving such a great results while using almost the same setup (Mini 8Mhz is based on Atmega328p).
              Your ideas and suggestions are most welcome. Thank you in advance!
              • C Offline
                C Offline
                carlierd
                Hello @engy :
                I have approximately same results as @brolly759.
                I spent some times to reproduce due to a measurement issue but I am under uA with pull-up resistor of 10Mo.
                Can you show your sketch and your design ?
                David.
                • E Offline
                  E Offline
                  engy
                  My problem was defected NRF24 radios. Had to order 3rd batch from ebay, and even though it contained a few defected modules.
                  • C Offline
                    C Offline
                    carlierd
                    @engy Hello. It's why I am using RFM69 as there is no fake :)
