  3. Low Power: How much current? [Solved]
109 Posts 10 Posters 88.4k Views 11 Watching
  • B
    B
    brolly759
    Correct, I was able to use radio pin to shut it off (pin 4) manually in v1.4 library. I cant inject the code in v1.5. If I can put the code in the sleep function somewhere, it is not easy to find anymore.
      wrote on last edited by hek
      #97
      You'll find the radio sleep call for NRF24L01 in MyTransportNRF24.cpp.
      https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyTransportNRF24.cpp#L92
      • B
        B
        brolly759
        No idea why but every so often I have to uninstall Arduino, delete the libraries and basically start over. Getting frustrating and I might go back to 1.0.5 + v1.4 lib.
          #99
          Subsequent to yesterday I ran Gammon's "Sketch J" on the very same Pro Mini that I had started this thread with (the one where I had soldered on 30 headers and which was drawing 17.2uA in the previous attempt at sleep with no watchdog timer). Instant results! Sleep current dropped to 125nA. I used a uCurrent Gold in conjunction with a Fluke 87V to take the measurement. That number is in good agreement with the 150nA reported by Gammon himself for a barebones arduino build. And, by the way, yes, I am running the current Arduino IDE 1.6.5 and the current libraries.
          Ridiculously easy! As before, it's just 3 steps. For the third step, just use Gammon's sketch to put your Pro Mini into sleep powerDown. Easy! Don't bother with RocketScream or LowPowerLab sketch and library. Leave them out of it.
          More good news: you already have the library Gammon's sketch uses--it's avr/sleep.h, so if you want to replicate this measurement test for yourself you won't need to download or install anything other than Gammon's sketch itself. You can find "Sketch J" here: http://www.gammon.com.au/power
          As far as I'm concerned, this proves the Pro Mini is a perfectly viable low power platform. This particular measurement test was my due diligence before standardizing. Therefore, I'm done here.
          Good luck to each of you on your various low power pursuits.
            #100
            @Neverdie: I am so happy for you! you know what I mean now about those easy steps. it is very strange that I had difference with lowpowerlab. I have looked at the lib and saw the part about the powerdown but I am not familiar with this syntax yet. I prefer how sketch J looks. But I was so happy when I saw this <uA, lol!
            but I can't wait to see Charles' ulpnode lib. He told me that it would be Mysensors compatible. it makes more sense now with new organization of Mysensors lib. great work @Hek and mysensors team! Mysensors is so fun ahahah! I am addict!
            • B
              B
              brolly759
              @NeverDie I never had issues with Gammon's code on v1.6.5 . I had issues with the mysensors v1.4 library with v1.6.5 of Arduino IDE. My power problems went away when I switched to v1.5 of mysensors library. I have stopped troubleshooting for now as I am slightly burnt out but my last test on v.1.6.5 with v1.5 MySensors gave me strange results sometimes. If I edited any files in the sleep mode functions I would not be able to go back to sleep. I was draw a constant ~3mA.
              Congrats though and welcome to the club. I think I am going to just combine nRF Mesh + gammon's code to make my own mesh network setup. (When I actually know programming) ;)
                Does everything which is turned off in Sketch J automatically get turned on again during wake-up? Or, does it remain off? I notice that Sketch J repeats turning everything off again before going to sleep, each and every time. There are some things which I may not being using, like I2C and ADC, which it would make sense to leave turned off. Likewise, no reason to wakeup SPI on every 8 second cycle unless there's a reason to use the radio.
                Furthermore, it would save valuable time at higher currents not needing to turn them off again. Anyone happen to know, or will I need to run experiments?
                  #103
                  By the way, perhaps a good argument in favor of an external interrupt for waking up is that it could wakeup the arduico and the radio in parallel. If the arduino wakes itself up through WDT and subsequently wakes up the radio, then it has to waste time waiting at high currents while the radio wakes up.
                  Just a thought at present, as I don't know how feasible this would be.
                    #104
                    In case anyone is curious as to what happens when an Arduino is waking up from sleep, this picture tells the story:
                    I powered an 8Mhz Pro Mini using a 5.1V battery (because it was convenient), and set it using "Sketch I" to wake up every 16ms and then immediately go back to sleep. The picture shows the Pro Mini draws about 500uA for about 2.1ms, then it surges up to about 6.5ma (I suppose at this point it is "awake"), and then voltage plummets back down again as it returns to sleep. When asleep it draws about 3.5uA. I measured the current using a 1ohm sense resistor, so in the picture 1mv=1ma. When measuring milliamps, I seem to get a much clearer picture (less noise) using a 1ohm sense resistor than I do using the UCurrent Gold.
                    In his write-up, Gammon warns that, depending on the sleep duration, this warm-up period can be as long as 65ms!
                    "Warning about wake-up times
                    Various fuse settings make a big difference to the wake-up time. Some wake-up times are quite long (eg. 65 mS) because they are designed to allow the crystal clock to settle. If you are trying to save power, taking 65 mS to wake up, add 1 to a counter, and go back to sleep, is a lot. You would want to look at a "wake-up" fuse setting that is appropriate for the type of clock source you are using."
                    I wish he had been more clear about how the sleep settings affect the length of the wake-up period. Perhaps he or somebody else explains that elsewhere.
                      #105
                      @Neverdie: hi. you are doing interesting tests. for the question about 65ms.. I am not sure. I think Gammon was referring about the CKSEL fuses, oscillator config fuses. it is described in datasheet from 8.2.2.
                      • engyE
                        engyE
                        engy
                        Hello guys,
                        I'm reading your post, and that is amazing... you're fighting with u/nAmps.
                        However, I'm concerned about mAmps :)
                        The lowest what I can get with Atmega328 + NRF24 on breadboard is 1mA.
                        What I've done:
                        Flashed Atmega328p with ATmegaBOOT_168_atmega328_pro_8MHz.hex
                        Uploaded BinarySwithchSleepSensor sketch with FDTI. Tried: API 1.4/1.5, IDE 1.0.6/1.6.5 (no difference)
                        Powered the sensor directly with 2xAA
                        Changed ext fuses to x07 (no BOD)
                        Connected NRF24 according to MySensors instructions
                        On the breadboard I have only:
                        Atmega328p
                        NRF24
                        10k resistor on 1st/reset pin.
                        With this set up minimum what I can get is:
                        Atmega328p w/o NRF - 3pin con - 0.1mA /not con - 3.4mA
                        Atmega328p with NRF - 3pin con - 1.09mA /not con - 1mA
                        I'm using cheap multi-meter, however, with Gammon's J sketch - it shows 3uA without NRF.
                        I'm struggling almost a week, and can't understand, why you guys achieving such a great results while using almost the same setup (Mini 8Mhz is based on Atmega328p).
                        Your ideas and suggestions are most welcome. Thank you in advance!
                        • carlierdC
                          carlierdC
                          carlierd
                          Hello @engy :
                          I have approximately same results as @brolly759.
                          I spent some times to reproduce due to a measurement issue but I am under uA with pull-up resistor of 10Mo.
                          Can you show your sketch and your design ?
                          David.
                          • engyE
                            engyE
                            engy
                            My problem was defected NRF24 radios. Had to order 3rd batch from ebay, and even though it contained a few defected modules.
                            • carlierdC
                              carlierdC
                              carlierd
                              @engy Hello. It's why I am using RFM69 as there is no fake :)
