  3. Low Power: How much current? [Solved]
109 Posts 10 Posters 88.4k Views 11 Watching
  • scalzS scalz
    @Neverdie: during my low power tests, I have used these http://s.click.aliexpress.com/e/feUvNFufi and it worked like I said. Arduino pro mini, I think you know it, is basically an atmel with some components. And I think most of arduino clones follow Arduino reference schematics. Just rooting and placements is different. So, in theory, it should work. but maybe bad components like capa, and I am not sure, could be the cause. but, in this case, it means that you can't be sure with all clones too and you need to find the good supplier. very strange and not cool. or maybe could it be counterfeil atmel...I don't think.
    Did you tried Sketch J from Gammon. Do you have still the problem??
    And of course like Brolly said, I removed voltage reg stuff.
    NeverDieN
    NeverDieN
    #21
    @scalz said:
    @Neverdie: ...and it worked like I said.
    @scalz To avoid confusion, I'm feeling the need for clarification: Do you mean that particular pro mini, from that particular vendor, is what you succeeded in bringing down (by unspecified means) to below 1uA sleep current?
    • scalzS
      scalzS
      yep. funny you proposed this link, and I checked on my ali orders and it is the same!
      what do you mean by "unspecified means". I am not sure....
      NeverDieN 1 Reply Last reply
      • scalzS scalz
        NeverDieN
        NeverDieN
        #23
        By "unspecified means", I just mean that you never said how you managed to do it. Rather, you said you'd rather let Charles say how he did it, whenever it is that he feels like he's ready to say.
        So, apparently, I was confused. For some reason I thought you had managed to achieve <1uA sleep current in an entirely custom way and that the Pro Mini's from Great Wall Electronics were unrelated to that. That's why when I stumbled across the 3-step article I posted earlier in this thread, I thought I'd just press ahead with that because it made the entire process (seemingly) so simple. Well, it is simple, except all the different "configurations" muddied the water and created doubt about what sleep current I might really get, maybe even depending on which "configuration" I got.
        At this point I'd be happy with 3.5uA. Based on the above, it sounds like Brolly759 found a way to reduce sleep currents down even further to 2.5-2.7uA, though I haven't yet wrapped my head around how Brolly759 did it, aside from reverting to IDE 1.0.6. I need to back up and re-read what he wrote now.
        • scalzS
          scalzS
          wrote on last edited by scalz
          #24
          @Neverdie: ok. this is what I was thinking..ahah no problem. I think you have misunderstood me.
          First, I think Brolly knows how to get low power as he said he has studied Gammon sketch. have you?
          Then, at the beginning I give you links to achieve low power but you told me that you wanted an easy to do way (the link with coin cell) and told !scalz. So I thought you didn't want to know more.
          So, if you want to try these steps and check (this was my first steps):
          • arduino pro mini, remove led and voltage reg
          • upload sketch J from Gammon, so you will be sure the best you can achieve
          • check at your uCurrent you will be < uA
          • Mysensors part : make a function from this sketch J and use it for sleeping instead of gw.sleep which use lowpowerlab (very strange I had difference with it and didn't investigated more). but you will need to find something for your radio next...like mosfet but it is other things.
          But If you try it, you will see with your eyes now...
          Yes I have already some codes. but I told you I don't share as it is experimental, not clean, and a good lib will be released soon. So i don't want to spend more time for nothing.
          • B brolly759
            OK I am going to join the party as this is exactly what I have been testing this past week. I have a uCurrent Gold and running on an 8Mhz 3.3v Nano Pro from this site:
            https://www.sparkfun.com/products/11114
            I have un-soldered the smt jumper to bypass all voltage regulating and running off of 2 AA Batteries.
            I am using the BinarySwitchSleepSensor sketch from the MySensors library. This uses pin 2/3 as an interrupt and sleeps until a pin hits GND. It wakes up, sends the new state, and goes back to sleep. The sketch also makes pin 2/3 high and uses the internal pull-up resistor.
            Originally I was getting 23-24uA in sleep mode when GND was not connected to pin 2/3. 117uA when GND was connected to pin 2/3. We will refer to this as open and closed pin state.
            Here is my methods:
            I downgraded my version of Arduino IDE to 1.0.6 from the latest build 1.6.5 and here are my new numbers:
            2.5-2.7uA sleep mode - Open pin state
            98-100uA sleep mode - Closed pin state
            Then I deleted from the sketch the digitalWrite on pin 2/3 and used an external resistor thanks to the advice from AWI. I plugged in an 10M Resistor to pin 2 to VCC and GND was the switch. Here are my new numbers:
            3.1-3.2uA sleep mode - Closed pin state
            So far today I have not gotten any false positives in my setup which is freaking amazing.
            Now I used a quick sketch "DallasTemperatureSensor" from the MySensors library to test what my current would be in sleep mode with a watchdog timer. I did NOT connect a temp sensor but my sleep current is: 7.6uA - 7.8uA.
            I hope this helps and if you need any testing let me know.
            I have a post on the Arduino forums here:
            http://forum.arduino.cc/index.php?topic=341958.msg2360300#msg2360300
            You can see me talking to the guy who actually wrote up the gammon website and you can ask him things directly if you ever wanted too. Very helpful guy!
            NeverDieN
            NeverDieN
            Here is my methods:
            If you removed your switch from the equation and just had the arduino pro mini sleep and never wake up (yeah, I know, it's a NOP), what sleep current would you get? That's the sleep current I've lately been trying to measure, because it's the simplest, base case, and you can add current drains to that, as needed.
            • B
              B
              brolly759
              This is testing using the Binary Switch Sleep sketch.
              The switch is not active when its in its "open state" so there is no drain. I removed the resistor though and all the jumpes, I am still getting around 2.7-2.8uA is sleep mode without switch.
              In sleep mode with the NRF ONLY VCC unplugged I am getting 1.3uA - 1.5uA.
              In sleep mode with ALL cables unplugged from NRF I am getting a strange reading and not really sure which one is accurate but here are my numbers:
              With uCurrent in uA mode I am getting .4uA -.5uA
              With uCurrent in nA mode I am getting 110-120nA
              I checked on Gammon site using the reference code, the nA of 110-120nA is accurate and the uA mode is wrong when I go down that low. So in short, I am getting 110-120nA when nRF is unplugged completely.
              • scalzS scalz
                NeverDieN
                NeverDieN
                #27
                Sounds that way. Probably my fault, due to lack of sleep.
                Excellent!
                Next step for me: placing an order with Great Wall Electronics for 10x pro mini's, as that is now critical path. By the time it arrives (hopefully even sooner), l should have this figured out.
                • NeverDieN
                  NeverDieN
                  #28
                  BTW, while on Great Wall, I noticed these RTC functional knock-offs of the Chronodot are just $0.57/each.
                  http://www.aliexpress.com/item/DS3231-AT24C32-IIC-Module-Precision-Clock-Module-DS3231SN-for-Arduino-Memory-module-Free-Shipping/32346088222.html
                  It might make sense to use one of them to wake up an arduino just once, when it needs to be woken, instead of every 8 seconds, as when using the Watchdog Timer. The current consumed by a genuine ChronoDot is: 200uA (active), 840nA (timekeeping) I don't have amp figures for the Great Wall knock-offs. I have a couple of the genuine chronodots, and they keep pretty accurate time.
                  • B
                    B
                    brolly759
                    We really need a separate section just on power consumption, what each person gets per each configuration and instructions lol.
                    I have never played with the Chronodot or any time stamp stuff. Is is easy to program?
                    It does make sense to remove the watchdog timer: 7uA current with this but, who wants to do the math? What is the rise/fall time of the Chronodot? Depending on the duration of the rise time and frequency of waking up the arduino, we may not be saving much power. (Algebra was never my strong suite. Never went to college lol)
                    On a side note, I am working with Gammon on figuring out why the nRF takes so much power: 2.4uA in sleep mode. Though I don't have any hardware at home so we must wait until tomorrow for that. In theory Arduino = 100+- nA + 800-900nA(NRF) = 1uA in sleep mode with an interrupt. That is what we all need to be aiming for, or at least I am.
                    • NeverDieN
                      NeverDieN
                      I think I spoke too soon. For battery applications, probably by now there are better options.
                      • B
                        B
                        brolly759
                        @NeverDie Trust me, there is never the perfect option... every time you think you have the right part and use it, another one that is better comes out... cant work fast enough anymore lol
                        • B
                          B
                          brolly759
                          Look at this one:
                          http://ambiqmicro.com/am18xx-ultra-low-power-rtc
                          14nA !!!! haha
                          • NeverDieN
                            NeverDieN
                            #33
                            Wow! Good find. LOL. I was just about to post the following, as a "for instance," but you already found something that's 2-7x better.
                            "For instance, Digikey now sells a$14.40 eval board with a newer RTC clock on it that consumes just 100na: http://www.digikey.com/product-detail/en/OM13512/568-11550-ND/4947022
                            That one uses SPI bus, but there's an I2C variant."
                            I'd really prefer that it be built into the MCU anyway. These things are just the bridge to that. If the WDT could have timed beyond 8 seconds to hours or days, we might not even be talking about it. Apparently it was meant for rebooting the MCU if the MCU got wedged, not for sleeping the MCU for hours or days. It illustrates how long overdue the arduino is for a major updating.
                            • B
                              B
                              brolly759
                              You may want to check how the mySensors library actually works. I barely know hardware and coding, I scrape by... lol but in all the sensor examples you have this code:
                              gw.sleep(SLEEP_TIME);
                              That is a 30 second duration for sleep. I haven't tried to increase that time yet but maybe they are looping through the 8 second limit? Dunno. Worth to check though how they do it.
                              My issue is that this sleep method uses 7.6-7.8uA. It would be nice to have it at like < 3uA.
                              • B
                                B
                                brolly759
                                I am digging around and looking at the code, I think it just cycles through 8 second batches.
                                We have an unsigned long, so thats 4,294,967,295 ms = 4294967.295 seconds = 71582.78825 minutes = 1193.046470833333 hours = 49.71026961805556 days.
                                So IF there is not a cap on the max duration of sleep in the Mysensors library, you can theoretically go to sleep for the max duration of the unsigned long which is about 49 ish days...
                                  wrote on last edited by hek
                                  #36
                                  Actually the ATMega328 can only sleep in cycles of 8 seconds maximum:
                                  This is where the virtual long sleep is generated:
                                  https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyHwATMega328.cpp#L124
                                  • scalzS
                                    scalzS
                                    #37
                                    I have some chronodots too. I thought about same thing (wake up with rtc) but I have not tested yet. And, anyway, i will stay with ulpnode. I have bought chronodots for another pcb I am working on; sort of low power Flower Power for outdoor more robust as I will do my inox ec/humidity sensors myself (I have a mini lathe at home) and with datalogging inside (so need rtc). And I will try to wake up with rtc (programmable hours).
                                    For Atmega328, I agree with @Hek, and you can't do what you want with watchdog. WDT is already well implemented in Lowpowerlab/MYsensors. You can't do more than 8sec cycles. It is in datasheet.
                                    So if you want to wake up each x min/hours or days. Best way I think is RTC. If you need smaller cycle, WDT or ulpnode power management sequence.
                                    I have already done your research few months ago to see if if i could do something different Charles. Unfortunately for me, I had to reproduce ulpnode sequence as he already had the good idea for this I think..it was a good exercise for me :smiley:
                                    Yesterday I found this https://www.kickstarter.com/projects/flutterwireless/flutter-20-wireless-arduino-with-half-mile-1km-ran It is opensource. Well designed I think.
                                    Funny thing too, atsam3s1a is not bad and have rtc too.
                                    • OitzuO
                                      OitzuO
                                      Oitzu
                                      I see they using the CC1200. I don't want to hijack this thread, but any information if they really can achive the 1000m they promise with that?
                                      • OitzuO Oitzu
                                        NeverDieN
                                        NeverDieN
                                        TI did some youtube videos in Norway and South Africa showing huge outdoor range (tens of kilometers) if the conditions are ideal (line of sight, with one transmitter on a mountain, etc.). But you gotta ask yourself: why South Africa? I think probably because the noise floor is so low. It makes for a more seemingly impressive demo.
                                        They have very high sensitivity, which is great. I'm told much of it might be wastedl in a home environment, where the noise floor tends to be higher.
                                        OitzuO 1 Reply Last reply
                                        • NeverDieN NeverDie
                                          OitzuO
                                          OitzuO
                                          Oitzu
                                          Hm.. okay. I'm asking because i'm currently trying to build an outdoor high range / low power network.
                                          I don't find any of these cc1200 available on the market, so i will stick to my way of testing some nrf24L01+ with high gain directional antennas. :)
                                          NeverDieN SparkmanS 2 Replies Last reply
