  3. Help make button-sketch sleep.
6 Posts 4 Posters 3.6k Views 2 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I tried using the button-sketch unmodified to control a lightswitch (non-momentary) I just wanted the arduino to register when it was switched and have the controller send a command to light or turn off a lamp. All worked like it should but the battery (18650) only lasated a few days before dying. I guess that it does not sleep properly.
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #include <Bounce2.h>
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
    How do I modify this sketch to only wake up when a input is activated?
    Or am I missing to understand how to connect the arduino? I connected the battery directly to the arduino and wanted it to wake up when for example the switch connected digital input 3 to ground.
    • sundberg84S
      I looked at the motion scetch when i did this:
      Sleep on interupt is: gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Ok I am not very good at this I usaly just try to copy the sketches as they are.
        But if I use the motion sketch and connect a switch to GND and D3 it will wake up and report to the controller when switch has been activated. And if I connect the switch so either D3-GND or D4-GND is activated when flicking the switch it will also wake up report to controller and then sleep.
         * Version 1.0 - Henrik Ekblad
         * Motion Sensor example using HC-SR501
         * http://www.mysensors.org/build/motion
        // Initialize motion message
          gw.begin();
          gw.sendSketchInfo("Motion Sensor", "1.0");
          gw.present(CHILD_ID, S_MOTION);
          // Read digital motion value
          Serial.println(tripped);
          gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        And hopefully the battery will last several months if activated a couple times a day,
        m26872M 1 Reply Last reply
        • sundberg84S
          I think only D2 and D3 can handle interups and D2 is used by the radio.
          hekH 1 Reply Last reply
          • sundberg84S sundberg84
            @sundberg84
            No, it is currently not used by the library. We just keep it connected to D2 (in the guides) because we could eventually find a good use for it in the future.
            Also, actually all digital pins on ATMega328 can be used to wake the MCU but only D2/D3 can trigger on RISING/FALLING. The rest support wake on CHANGE.
            (Please correct me if I'm wrong here HW-guys)
                gw.begin();
              m26872M
              m26872M
              m26872
              @Cliff-Karlsson
              There's a good example in the MySensors lib with sleep and two switches. https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/BinarySwitchSleepSensor/BinarySwitchSleepSensor.ino
              My adaption of that one to my own need and with one swtich looked like this
              #define SKETCH_NAME "BinSwSleepBat"
              #define SKETCH_VERSION "1-2"
              #define CHILD_ID 0
              #define BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch. On Atmega328p (nano and pro mini) D2 and/or D3 are interrupt pins.
              MySensor mys;
              MyMessage msg(CHILD_ID, V_TRIPPED); // Change to V_LIGHT if you use S_LIGHT in presentation below
              int sentValue=2;
                mys.begin();
                pinMode(BUTTON_PIN, INPUT);   // Setup the buttons
                digitalWrite(BUTTON_PIN, HIGH);   // Activate internal pull-ups
                mys.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                mys.present(CHILD_ID, S_DOOR);
              void loop()  // Loop will iterate on changes on the BUTTON_PINs
                mys.sleep(50);  // Short delay to allow buttons to properly settle
                uint8_t val = digitalRead(BUTTON_PIN);
                if (val != sentValue) {  // If value has changed from last transmission, send the updated value
              	 mys.send(msg.set(val==HIGH ? 1 : 0));
              	 sentValue = val;
                mys.sleep(BUTTON_PIN-2, CHANGE, 0); // Sleep until something happens with the sensor
