  3. My Sensor node "motherboard" (MySensorsNode)
72 Posts 13 Posters 45.0k Views 21 Watching
  • B bilbolodz
    I've got it working BUT I've very strange "solution". I'll write it down maybe someone be able to explain me what's going on:
    I've 3 versions of "test program" 1.0, 1.1, 1.2 (actually the only difference is sketch number).
    1. I'm uploading manually with avrdude DualOptiboot from "Mysensors board package" (uploading using gui not working - gives strange error about fuses).
    2. I'm uploading (using USBasp and Arduino GUI) program version 1.0: program is working but "Reboot" command send from MYSController gets arduin into endless loop during "boot"
    0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSF:0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    1. Physical reset of board and OTA update to v 1.1 using MYSControler. OTA update is finished but at the end "endless loop"
    133398 OTA:FWP:RECV B=0000
    133400 OTA:FWP:FW END
    136038 OTA:CRC:B=05A8,C=6506,F=6506
    136040 OTA:FWP:CRC OK
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSF:�0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    1. Physical reset of board: still version 1.0 present and running, reboot NOT working
    2. One again I program bootloader using command:
    avrdude -c usbasp -p m328p -u -U flash:w:optiboot_atmega328_pro_8MHz.hex
    1. Surprise, surprise: version 1.1 present and running, reboot command WORKING!
    2. After these I can program freely (using OTA) other versions of program (e.x. 1.2 or even "start version" 1.0)
    I'm making some STUPID mistake but I can't find it......
    rozpruwaczR
    rozpruwaczR
    rozpruwacz
    @bilbolodz I had also problems with DualOptiboot and OTA. It is very poorly documented. As I understand how it works, If you burn the bootloader first and then the program You actually erasing the bootloader that you burned before (thats why it is in "endless loop"). The bootloader must be burned after the program is already on the external flash, so it can load that program into the internal memory. To do that:
    1. upload the program to the board
    2. fire the ota update to write the same program to the external flash
    3. program the bootloader
    after that you will have the bootloader and OTA working.
    B 1 Reply Last reply
    • rozpruwaczR rozpruwacz
      B
      B
      bilbolodz
      @rozpruwacz
      I've made some test. It looks that bootloader is "damaged" ONLY if sketch is loaded using programmer (USBASP in my case). If sketch is loaded via serial and bootloader all is fine. So correct usage should be:
      1. Program DualOptiboot bootloader using programmer
      2. Upload sketch using serial port and DualOptiboot bootloader
      • B bilbolodz
        @rozpruwacz
        rozpruwaczR
        rozpruwaczR
        rozpruwacz
        @bilbolodz LOL, You are absolutely right :D thats why it is called "Dual" :P because it can also boot from the serial port ... thanks !!
        • AnticimexA Anticimex
          EDIT: BOMs are now uploaded as well. I have to inspect the gerbers one more time but it is close to manufacture now :)
          B
          B
          bilbolodz
          @Anticimex
          Could you please:
          1. Point me to drop in replacement for DMP3056L-7? It's hard to get in my area...
          2. Tell where can I buy SI7021 chip?
          AnticimexA rozpruwaczR 2 Replies Last reply
          • B bilbolodz
            @Anticimex
            Could you please:
            AnticimexA
            AnticimexA
            Anticimex
            @bilbolodz you find all sourcing information I have on github
            • B bilbolodz
              @Anticimex
              Could you please:
              rozpruwaczR
              rozpruwaczR
              rozpruwacz
              @bilbolodz said in My Sensor node "motherboard" (MySensorsNode):
              SI7021
              fo the transistor search for P-CHANNEL MOSFET with Low On-Resistance (the lower the better, the DMP3056L has 500mOhms) and the transistor must be rated for voltage grater than your power supply (Drain-Source Voltage parameter in datasheet, which is negative value but think of it as it would be positive)
                B
                B
                bilbolodz
                @Anticimex I've checked it but in most cases all sources you've mentioned have very expensive shipment to Poland.
                How about DMP3056L-7 replacement? I've found it on aliexpres but shipment are twice such expensive as 35 pieces of transistor.
                • B bilbolodz
                  rozpruwaczR
                  rozpruwaczR
                  rozpruwacz
                  @bilbolodz You can buy an SI7021 module and desolder it :D https://botland.com.pl/czujniki-temperatury/6554-si7021-czujniki-temperatury-i-wilgotnosci-i2c-sparkfun.html
                  • B
                    B
                    bilbolodz
                    @rozpruwacz said in My Sensor node "motherboard" (MySensorsNode):
                    SI7021
                    Found it on ebay:
                    http://www.ebay.com/itm/SI7021-A10-GM1R-Digital-Temperature-and-Humidity-Sensor-Module-F-Arduino-Si7021-/132179773960?hash=item1ec6874a08:g:oL0AAOSw~y9ZCf9o
                    Still looking for good source of DMP3056L-7 or replecement
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      I cannot help on country specific sourcing alternatives. It would be impossible for me to create a list for the cheapest sourcing alternatives for every country. You have all part information in the BOM. So it should be relatively easy for you to search the parts. And if you want alternatives, do a parametric search at your preferred suppliers.
                      • B
                        B
                        bilbolodz
                        Do you have suggestion how to mount RFM69 radio module? "Standard" 2.54 gold pin won't fit....
                        AnticimexA 1 Reply Last reply
                        • B bilbolodz
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @bilbolodz well, no it is 2mm pitch.
