  3. find parent [solution found]
find parent
6 Posts 3 Posters 3.3k Views 2 Watching
  • J
    J
    jeti
    wrote on last edited by jeti
    Hi all,
    i just built a motion, lux and dimmer sensor. The sketch is working perfeclty on a UNO+breadboard but does not seem to work on a pro mini+hardwired, i check the wiring already twice...
    The error i get in serial consol is:
    " find parent"
    what could be the trigger for this?
    thanks
      Mickey
      try to delete eeprom of gateway and node...
      • J
        J
        jeti
        just tried cleared the sensors eeprom, did not show any difference.
        As the "find parent" is the only line in the serial consol, do you think it can be related to the gateway?
        • J
          J
          jeti
          this is my sketch:
          #include <BH1750.h>
          #include <Wire.h>
          #define NODE_ID 136
          unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
          #define LED_PIN 5      // Arduino pin attached to MOSFET Gate pin
          #define FADE_DELAY 25  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
          #define PIR_ID 0   // Id of the sensor child
          #define DIM_ID 1  // Id of the sensor child
          #define CHILD_ID_LIGHT 2
          boolean lasttripped = false;
          BH1750 lightSensor;
          // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
          uint16_t lastlux;
          MyMessage pirMsg(PIR_ID, V_TRIPPED);
          // Initialize Dimmer
          static int currentLevel = 0;  // Current dim level...
          MyMessage dimmerMsg(DIM_ID, V_DIMMER);
          MyMessage lightMsg(DIM_ID,  V_LIGHT);
            gw.begin(incomingMessage, NODE_ID, false);
            gw.sendSketchInfo("PIR & DIM & LUX", "1.0");
            gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
            gw.present(DIM_ID, S_DIMMER );
            gw.request(DIM_ID, V_DIMMER );
            gw.present(PIR_ID, S_MOTION);
            lightSensor.begin();
           gw.process();
              if (lasttripped != tripped) {
              lasttripped = tripped;
            Serial.print("PIR ");
            Serial.println(tripped);
            gw.send(pirMsg.set(tripped?"1":"0"));  // Send tripped value to gw
            uint16_t lux = lightSensor.readLightLevel();// Get Lux value
            if ((round(lux/25))*25 != lastlux) {
              Serial.print("LUX ");
              Serial.println(lux);
                gw.send(msg.set(lux));
                lastlux = (round(lux/25))*25;
            if (message.type == V_LIGHT || message.type == V_DIMMER) {
              requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
              // Clip incoming level to valid range of 0 to 100
              Serial.print( "Changing level to " );
              Serial.print( ", from " );
              Serial.println( currentLevel );
              fadeToLevel( requestedLevel );
              gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
              // hek comment: Is this really nessesary?
              gw.send( dimmerMsg.set(currentLevel) );
           *  This method provides a graceful fade up/down effect
          void fadeToLevel( int toLevel ) {
            int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
            while ( currentLevel != toLevel ) {
              currentLevel += delta;
              analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
              delay( FADE_DELAY );
          • J
            J
            jeti
            found it, it was a not stable 3.3V for the radio... :( added a cap now everything works!
            topic can be closed
            Thorsten MuhlakT 1 Reply Last reply
            • J jeti
              topic can be closed
              Thorsten MuhlakT
              Thorsten MuhlakT
              Thorsten Muhlak
              topic can be closed
              Thanks...you pushed me in the right direction! Same issue with the same solution here!
              Raspberry Pi - FHEM (Controller)
              Arduino UNO R3 - W5100 Shield Ethernet GW
