  3. What radio to use? NRF24L01+, RFM69, RFM73 ?
52 Posts 11 Posters 55.5k Views 9 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Ok, this is my temp sensor sketch. Does it also look Ok?
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #include <OneWire.h>
    #include <MyTransportRFM69.h>
    MyTransportRFM69 transport;
    MySensor gw(transport);
    int numSensors=0;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor", "1.1");
         gw.present(i, S_TEMP);
      gw.process();
      gw.sleep(conversionTime);
        #if COMPARE_TEMP == 1
        #else
      gw.sleep(SLEEP_TIME);
    • TD22057T
      TD22057T
      TD22057
      Well I'm having problems too... :anguished: I'm running basically the same serial gateway code you are and, like you, it starts up fine. For my sensor, I'm using the MockSensor sketch modified to send a counter. That starts up fine as well but can't communicate with the gateway. I tried level shifting IRQ and not level shifting IRQ - no change. Basically the gateway never gets the transmitted message. I'm using a small helical antenna that came w/ the radio on the sensor and a home made dipole on the gateway. I'm going to try and replace my home made antenna with a helical model on the gateway and see what happens.
      Here's what I see on the sensor:
      find parent
      send: 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
      I'm using this level shifter. If my antenna mod doesn't work (I'm not expecting it to), I'll try changing this to a resistor network to do the shifting and see if that helps.
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Hmm...
        I just connected both gateway and temp sensor to the same computer and used the serial monitor and now it shows temp info
        0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
        1;255;0;0;17;1.5
        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        1;255;3;0;6;0
        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Senso
        1;255;3;0;11;Temperature Sensor
        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
        1;255;3;0;12;1.1
        0;0;3;0;9;read: 1-1-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
        1;0;0;0;6;
        0;0;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.5
        1;0;1;0;0;24.5
        0;0;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.7
        1;0;1;0;0;24.7
        0;0;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.8
        1;0;1;0;0;24.8
        I don´t know if it is a range problem or if it is my controller platform.
        I am using a raspberry pi and domoticz and I get a lot of errors like:
        2015-09-28 19:30:16.415 MySensors: Using serial port: /dev/ttyUSB0
        2015-09-28 19:30:17.881 MySensors: Gateway Ready...
        2015-09-28 19:30:36.661 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:31:06.795 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:31:36.930 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:32:07.060 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:32:37.168 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:33:07.298 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:33:37.410 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:34:07.541 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:34:37.658 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:35:07.784 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:35:37.925 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:36:08.054 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:36:38.167 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:37:08.298 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:37:38.428 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:38:08.537 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:38:38.666 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:38:38.852 Error: Serial Port closed!... Error: End of file
        2015-09-28 19:38:39.513 MySensors: retrying in 30 seconds...
        2015-09-28 19:39:08.518 MySensors: Using serial port: /dev/ttyUSB0
        2015-09-28 19:39:08.518 Error: MySensors: Error opening serial port!
        2015-09-28 19:39:08.799 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:39:09.518 MySensors: retrying in 30 seconds...
        2015-09-28 19:39:38.523 MySensors: Using serial port: /dev/ttyUSB0
        2015-09-28 19:39:38.523 Error: MySensors: Error opening serial port!
        2015-09-28 19:39:38.898 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:39:39.523 MySensors: retrying in 30 seconds...
        2015-09-28 19:40:08.528 MySensors: Using serial port: /dev/ttyUSB0
        2015-09-28 19:40:08.528 Error: MySensors: Error opening serial port!
        2015-09-28 19:40:09.013 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:40:09.529 MySensors: retrying in 30 seconds...
        2015-09-28 19:40:38.533 MySensors: Using serial port: /dev/ttyUSB0
        2015-09-28 19:40:38.534 Error: MySensors: Error opening serial port!
        2015-09-28 19:40:39.107 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:40:39.534 MySensors: retrying in 30 seconds...
        2015-09-28 19:41:08.538 MySensors: Using serial port: /dev/ttyUSB0
        2015-09-28 19:41:08.539 Error: MySensors: Error opening serial port!
        2015-09-28 19:41:09.222 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:41:09.539 MySensors: retrying in 30 seconds...
        2015-09-28 19:41:38.543 MySensors: Using serial port: /dev/ttyUSB0
        2015-09-28 19:41:38.544 Error: MySensors: Error opening serial port!
        2015-09-28 19:41:39.335 Hardware Monitor: Fetching data (System sensors)
        2015-09-28 19:41:39.544 MySensors: retrying in 30 seconds...
        I have tried using two different raspberry pi´s and tried both the stable and the beta of domoticz and I get the same errors everytime.
        I was thinking there was some error in the gateway-sketch/temp-sketch or that the usb-port of the pi could not provide enough power for the nano+RFM69W.
        fetsF 1 Reply Last reply
          Hmm...
          1;255;0;0;17;1.5
          1;255;3;0;6;0
          1;255;3;0;12;1.1
          1;0;0;0;6;
          1;0;1;0;0;24.5
          1;0;1;0;0;24.7
          1;0;1;0;0;24.8
          fetsF
          fetsF
          fets
          @Cliff-Karlsson glad it works now.
          You should now try to use a different power source for node and see if it's stil working. Next start to move your node.
          Regarding domoticz outputs, these are not errors but' just logs from raspberry motherboard sensors.
          • TD22057T
            TD22057T
            TD22057
            Well - the good news is that mine is working now. The ??? news is that I'm not sure why. I was using an Uno as my gateway (w/ a dipole antenna) and a 5V mini (small helical antenna) as the sensor and couldn't get anything to go between them. To simply things, I changed the Uno to a 3V mini w/ a monopole antenna and got some traffic, but not very consistent. So I shut everything down, ate some dinner, watched some TV and came back to it. Turned both nodes on and everything was working fine. I rigged up a battery and booster to the 5V mini and started moving it around the house and it's working perfectly. Basically there doesn't seem to be anywhere on my property that I can't get a signal.
            The 5V mini is using a level shifter on all the lines (including IRQ) except MISO so I'll try removing the IRQ shifting next to make sure it works without that. And I need to see if I can get the Uno working as the gateway.
            My best guess is that I had a loose connection in the breadboard (i.e. maybe I should stop buying cheap breadboards). Or maybe start using wire wrap for my prototypes.
            NeverDieN 1 Reply Last reply
            • TD22057T TD22057
              NeverDieN
              NeverDieN
              Great!
              • S
                shabba
                So does the RFMxx need level shifters? I was under impression they were like that NRF24LO1+ and could just be wired direct to the minis.
                • S shabba
                  fetsF
                  fetsF
                  fets
                  @shabba levels shifters needed, unless with pro mini 3.3v
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    Hi I had my RFM69(H)W Gateway and sensors working after several days of trial and error. A couple of days ago I started fiddeling around with the gateways when trying to add a NRF radio. The nrf works great but now my RFM69 has stopped working.
                    Can anyone write down a complete step by step instruction of how to get the Serial gateway and sensors working using the RFM69.
                    This is what I have done:
                    MyConfig.h - Checked that the right radio options was selected.
                    Mysensor.h - Added
                    #include "MyTransportRFM69.h"
                    //MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()
                    MySensor(MyTransport &radio =*new MyTransportRFM69(), MyHw &hw=*new MyHwDriver()
                    SerialGateway:
                    added:
                    "MyTransportRFM69 transport (RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, true, RF69_IRQ_NUM) ;" (I have the H version on the gateway)
                    Are there any more steps? anything more I need to add to the SerialGateway Sketch?
                    The Sensor-sketches also seems to have been modified recently, how do I add the Radio info in the sketches?
                    • S
                      shabba
                      Did anyone manage to get direct raspberry pi to RFM69 working? About to roll out a rfm69 network beside my nrf24 one.
                      • mahesh2000M
                        mahesh2000M
                        mahesh2000
                        hi, is there something like the nRF24LE1 (which has an nRF24L01 and 8051 microprocessor in one chip) in the RFM family? thanks!
                          @mahesh2000 please don't post the same question in multiple places. It wastes people's time when some details are available in one thread and some details in another thread.
                          To anyone responding to @mahesh2000's question, please reply in https://forum.mysensors.org/post/85838 instead.
