  3. Domoticz
  4. Raspbery PI + nrf24 (gpio) not work Domoticz Temp+humanidy PLS HELP
24 Posts 8 Posters 15.8k Views 5 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    Probably your nodes which were compiled with version 1.5 of the library, and the fact that the version of the library upon which the PiGatewaySerial is compiled is still version 1.4
    On your Raspberry, in the Raspberry directory you should find a "Version.h" file.
    Try changing the content to this:
    • This file defines the Sensor library version number
    • Normally, contributors should not modify this directly
    • as it is manaaged by the MySensors Bot.
      #ifndef Version_h
      #define Version_h
    #define LIBRARY_VERSION "1.5"
    The do another sudo make etc...
    I hope this helps you.
    • W
      W
      wergeld
      GertSanders,
      All of my nodes are using 1.4 library. Oddly at around 2:30 am my one sensor I moved to same channel as my domoticz gateway got picked up. Pretty interesting! I had changed it to the domiticz channel at 11pm. Progress is good. Now going to see about why the temp is being reported as ~140 F when that sensor reported ~70 F (correct) when attached to my other controller.
        Install the gateway:
        git clone https://github.com/mysensors/Raspberry.git
        cd Raspberry/librf24-bcm
        make all && sudo make install
        cd ..
        sudo make enable-gwserial
        sudo /etc/init.d/PiGatewaySerial start
        Verify that the gateway started properly:
        cat /dev/ttyMySensorsGateway
        Domoticz is unable to read from /dev/ttyMySensorsGateway so create a link to a name that Domoticz understands:
        sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
        To automatically create the link on startup, add
        just before
        exit0
        in /etc/rc.local
        I then added the gateway as per the image in my last post.
        EDIT: Changed instructions to use librf24-bcm instead of tmrh20. tmrh20 tricked my Gateway into forwarding everything to a strange (non-existing) parent node.
        tommyken
        cd ..
        just before
        exit0
        in /etc/rc.local
        I tried this for SPI through raspberry
        Can someone provide me the correct way to install those ?
        First attempt was like mentioned above. But i don't have the folder librf24-bcm
        then i placed nrf2401 zip file into the folder from http://tmrh20.github.io/
        Now i got this error
        pi@testdom ~/Raspberry $ make all
        g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME="/dev/ttyMySensorsGateway" -D_TTY_GROUPNAME="tty" -march=armv6zk -D__PI_BPLUS -I. -I/usr/local/include/RF24
        In file included from RF24.h:18:0,
        from MySensor.h:37,
        from MyGateway.h:16,
        from MyGateway.cpp:13:
        RF24_config.h:38:32: fatal error: utility/includes.h: No such file or directory
        #include "utility/includes.h"
        compilation terminated.
        Makefile:57: recipe for target 'MyGateway.o' failed
        make: *** [MyGateway.o] Error 1
        I have lateste update and upgrade and i'm using Jessie. Hopely can someone help me.
        Thanks in advance.
        • T tommyken
          cd ..
          just before
          exit0
          in /etc/rc.local
          from MySensor.h:37,
          Thanks in advance.
          @tommyken see the updated instructions at http://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway They show how to get the rf24 files.
