  3. Combining DHT and Relay issues
4 Posts 3 Posters 2.3k Views 2 Watching
  • P
    P
    punter9
    I am having some troubles combining two sets of code. I am getting it to be recognized in domoticz and read the temp of the DHT and it sees the relay and I can add it. The issue is I cannot trigger the relay on and off. It works fine with just the relay code, but as soon as I inject the DHT code this issues arises. Any ideas?
     * Version 1.0 - Henrik Ekblad
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    //MyTransportRFM69 radio;
    //MySigningNone signer;
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      gw.sendSketchInfo("Relay & DHT", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.sendSketchInfo("Humidity", "1.0");
      gw.process();
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(SLEEP_TIME); //sleep a bit
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    • SparkmanS
      SparkmanS
      Sparkman
      At first glance, it appears to be caused by the sleep. Try using the gw.wait command as it will still process incoming messages then. The other option is to use the millis function to send temp/humidity on a regular basis and don't use a sleep or wait function at all.
      Cheers
      Al
      • P
        P
        punter9
        oh this is a great call. trying
        • P punter9
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @punter9
          Your problem looks a lot like this person's issue.
