  3. Scrolling Text sensor node with new V_TEXT
51 Posts 17 Posters 35.5k Views 13 Watching
  • korttomaK korttoma
    @Orkspalter said:
    please share the 2.0 version of the sketch
    Sure I can do that, I will share it when I get home to the computer where it is located.
    A Former User
    Thanks Tomas
    • gusG
      gusG
      gus
      I'm using this fantastic code as well. This is working on 2.0
      Next step for me would be to be able to create an array with more messages, so that the display could cycle thru them.
       PROJECT: MySensors / Scrolling Text display
       PROGRAMMER: AWI
       DATE: september 12, 2015/ last update: september 12, 2015
       FILE: AWI_scroll_MAX.ino
       LICENSE: Public domain
       Hardware: tbd ..Ceech - ATmega328p board w/ NRF24l01
          and MySensors 1.5 ()
      Special:
          Need to use MySensors development edition
      SUMMARY:
          3 S_xx devices for scrolling text
          - Displays a scrolling text from a "V_TEXT" variable
          - additional dimmer sensor for controlling display brightness
          - 'Alarm' switch. If "On", overrides the text display to display ALARM message
          - You can also input messages from the Serial monitor (testing)
          Uses excellent MD_MAX72XX library
       Remarks:
          Fixed node-id
      #include <MD_Parola.h>
      #define MY_REPEATER_FEATURE
      // Use the MD_MAX72XX library to scroll text on the display with the use of the callback function
      // to control what is scrolled on the display text.
      // You need to set the used display in the library MD_MAX72XX.h
      // User can enter text on the serial monitor and this will display as a
      // Speed for the display is controlled by a pot on SPEED_IN analog in.
      #include <MD_MAX72xx.h>                     // multipurpose library for MAX72xx diaplay driver  https://parola.codeplex.com/
      #include <MySensors.h>                       // Mysensor network
      #include <Time.h>                           //http://playground.arduino.cc/Code/Time
      #include <TimeLib.h>
      #define USE_POT_CONTROL 0                   // enable Scroll speed  potentiometer
      #define PRINT_CALLBACK  1
      // Macro to simplify serial print
      #define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
      // Define the number of devices we have in the chain and the hardware interface
      // need to be adapted to your setup
      const int MAX_DEVICES = 2 ;                 // number of 8x8 displays
      const int CLK_PIN = 7 ;                     // SPI like clock
      const int DATA_PIN = 8 ;                    // SPI like data
      const int CS_PIN = 6 ;                      // SPI like select
      // Parola is able to use SPI hardware interface, not testted in combination with MySensors
      // MD_MAX72XX mx = MD_MAX72XX(CS_PIN, MAX_DEVICES);
      // now use Arbitrary pins
      MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES); // instantiate one display chain
      // Scrolling parameters, you can attach normal potentiometer to A5, Vcc, Gnd
      #if USE_POT_CONTROL
      const int SPEED_IN = A5 ;
      #else
      const int SCROLL_DELAY = 20 ;               // in milliseconds
      #endif // USE_POT_CONTROL
      const int CHAR_SPACING = 1 ;                // pixels between characters
      // MySensors constants & variables
      //const byte nodeId = 51 ;                    // MySensors fixed node id
      const byte messageCHILD = 8 ;               // Text from ControllerLCD
      const byte brightnessChild = 9 ;            // Brightness of display
      const byte alarmChild = 10 ;                // Display Alarm text (overrides normal text)
      boolean timeReceived = false ;              // Flag to indicate time received
      // Display constants & variables
      byte textBrightness = 1 ;                   // brightness of display (between 0 - MAX_INTENSITY (0xF)
      byte textOnOff = false ;                     // textOnOff = ! shutdown
      boolean textAlarm = false ;                 // Alarm (switch S_BINARY)
      // Global message buffers shared by MySensors and Scrolling functions
      const int BUF_SIZE = 25 ;                   // max payload for MySensors(NRF24l01)
      char curMessage[BUF_SIZE];                  // current displayed message
      char newMessage[BUF_SIZE];                  // next message to be displayed if available
      bool newMessageAvailable = false ;          // new message available flag
      uint16_t    scrollDelay;                    // in milliseconds
      // *** Definition and initialisation
      // define the MySensor network (1.5)
      // Initialize messages for sensor network
      MyMessage textMsg(messageCHILD, V_TEXT);    // message for Sending Text to Controller
      /* MD_MAX72XX functions: can be found in the documentation for the library,
       * no need to customtize callback & scroll routines (unless you want to...)
      uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
      // Callback function for data that is required for scrolling into the display
        static char       *p = curMessage;
        static uint8_t    state = 0;
        static uint8_t    curLen, showLen;
        static uint8_t    cBuf[8];
        uint8_t colData;
        // finite state machine to control what we do on the callback
        switch(state)
          case 0: // Load the next character from the font table
            showLen = mx.getChar(*p++, sizeof(cBuf)/sizeof(cBuf[0]), cBuf);
            curLen = 0;
            state++;
            // if we reached end of message, reset the message pointer
            if (*p == '\0')
              p = curMessage;         // reset the pointer to start of message
              if (newMessageAvailable)    // there is a new message waiting
                strcpy(curMessage, newMessage);   // copy it in
                newMessageAvailable = false;
            // !! deliberately fall through to next state to start displaying
          case 1: // display the next part of the character
            colData = cBuf[curLen++];
            if (curLen == showLen)                // end of character insert interchar space
              showLen = CHAR_SPACING;
              curLen = 0;
              state = 2;
            break;
          case 2: // display inter-character spacing (blank column)
            colData = 0;
            curLen++;
              state = 0;
            break;
          default:
            state = 0;
        return(colData);
      // Callback (not used here)
      void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col){
      // Callback function for data that is being scrolled off the display
      #if PRINT_CALLBACK
          Serial.print("\n cb ");
          Serial.print(dev);
          Serial.print(' ');
          Serial.print(t);
          Serial.print(' ');
          Serial.println(col);
      // non-blocking text display to be used in loop (call frequently)
      void scrollText(void){
          static uint32_t prevTime = 0;
          if (millis()-prevTime >= scrollDelay){                  // Is it time to scroll the text?
              mx.transform(MD_MAX72XX::TSL);                      // scroll along - the callback will load all the data
              prevTime = millis();                                // starting point for next time
      // sets the scroll delay (read from potentiometer if enabled)
      uint16_t getScrollDelay(void){
      #if USE_POT_CONTROL
          uint16_t t = analogRead(SPEED_IN);
          t = map(t, 0, 1023, 25, 250);
          return(t);
      #else
          return(SCROLL_DELAY);
      void setup(){
          // set up the display first
          mx.begin();                                             // initialize display chain
          mx.setShiftDataInCallback(scrollDataSource);            // define function to get the scrolldata (returned as int8)
          //mx.setShiftDataOutCallback(scrollDataSink);           // not used
          mx.control(MD_MAX72XX::INTENSITY, 0x01);
      #if USE_POT_CONTROL                                         // initialize speed potentiometer if enabled
          pinMode(SPEED_IN, INPUT);
      #else
          scrollDelay = SCROLL_DELAY;
          strcpy(curMessage, "I \x03 MySensors ");                // first message on display
          //newMessage[0] = '\0';                                   // new message initialized to empty RE This is not working....
          // Setup MySensors
         //Serial in Sensor network = 115200
          //Send the sensor node sketch version information to the gateway
      void presentation() {
          sendSketchInfo("Scrollo small 52", "1.0");
          present(messageCHILD, S_INFO, "Text line Scroll");   // new S_type 20150905 (not know by domoticz)
          present(alarmChild, S_BINARY, "Alarm display");      // to display alarm text
          present(brightnessChild, S_DIMMER, "Text brightness"); // new S_type 20150905 (not know by domoticz)
          //send(textMsg.set("-"));                            // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
          request(messageCHILD, V_TEXT, 0);                    // request value from controller
          // Initializations
          requestTime();                            // get the time from controller (handled by receiveTime)
      // loop only uses non-blocking functions
          static unsigned long lastUpdate ;                       // Static hold the last update time
          unsigned long now = millis();
          scrollDelay = getScrollDelay();                         // update scroll delay from potentiometer
          //readSerial();
          // Check for new conditions & ask for new information from controller every 10 seconds
          if (now-lastUpdate > 10000){
              if (textAlarm){                                     // if alarmstatus: override all text and set max intensity
                  strcpy(curMessage, "   ALARM   ");
                  mx.control(MD_MAX72XX::INTENSITY, MAX_INTENSITY);   // set current brightness
                  mx.control(MD_MAX72XX::SHUTDOWN, false) ;
              } else {                                            // standard (non Alarm actions)
                  mx.control(MD_MAX72XX::INTENSITY, textBrightness);  // set current brightness
                  mx.control(MD_MAX72XX::SHUTDOWN, textOnOff) ;
                  request(messageCHILD, V_TEXT, 0);                // request new value from controller
              lastUpdate = now;
          scrollText();
      // This is called when a new time value was received
      void receiveTime(unsigned long controllerTime) {
          Serial.print("Time value received: ");
          Serial.println(controllerTime);
          setTime(controllerTime);                                // time from controller
          timeReceived = true;
      // This is called when a message is received
          Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
          if (message.sensor == messageCHILD){
              if (message.type==V_TEXT) {                     // Text content
              strcpy(newMessage, message.getString());        // copy it in
                  newMessageAvailable = true ;
          } else if (message.sensor == alarmChild) {
              if (message.type==V_STATUS) {                   // True/ false content
                  textAlarm = message.getBool()?true:false ;  // set alarmflag
                  Serial.print("TextAlarm: ");
                  Serial.println(textAlarm);
          } else if (message.sensor == brightnessChild){
              if (message.type==V_PERCENTAGE) {               // Level 0..100  content
                  textBrightness = map(message.getInt(),0, 100, 0, MAX_INTENSITY ) ;  // map to brightnesslevel
                  Serial.print("TextBrightness: ");
                  Serial.println(textBrightness);
              } else if (message.type==V_STATUS) {            // Display on/off
                  textOnOff = message.getBool()?false:true ;      // set shutdown/ !on/off
                  Serial.print("Text on/off: ");
                  Serial.println(textOnOff);
      // Testing purposes: input routine character buffer. Reads serial characters in buffer newMessage.
      // sets flag newMessageAvailable to true if completed
      void readSerial(void)
        static uint8_t    putIndex = 0;
        while (Serial.available())
          newMessage[putIndex] = (char)Serial.read();
          if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE-3)) // end of message character or full buffer
            // put in a message separator and end the string
            newMessage[putIndex++] = ' ';
            newMessage[putIndex] = '\0';
            // restart the index for next filling spree and flag we have a message waiting
            putIndex = 0;
            newMessageAvailable = true;
          else
            // Just save the next char in next location
            newMessage[putIndex++];
      korttomaK 1 Reply Last reply
      • gusG gus
         PROGRAMMER: AWI
        Special:
        SUMMARY:
         Remarks:
            Fixed node-id
        #if USE_POT_CONTROL
        #else
          uint8_t colData;
          switch(state)
              curLen = 0;
              state++;
              if (*p == '\0')
                curLen = 0;
                state = 2;
              break;
              colData = 0;
              curLen++;
                state = 0;
              break;
            default:
              state = 0;
          return(colData);
        #if PRINT_CALLBACK
            Serial.print(dev);
            Serial.print(' ');
            Serial.print(t);
            Serial.print(' ');
        #if USE_POT_CONTROL
            return(t);
        #else
        void setup(){
        #else
            // Setup MySensors
            // Initializations
            //readSerial();
                lastUpdate = now;
            scrollText();
              putIndex = 0;
            else
        korttomaK
        korttomaK
        korttoma
        @gus you beat me to it, nice job!
        Sorry @Orkspalter I forgot yesterday but I'm sure the one @gus posted is quite similar.
        Is there anyone out there using this setup that have a sketch that can handle scandinavian letters (å, ä, ö). I just get gibberish instead of the letters.
        • Tomas
          korttomaK
          korttomaK
          korttoma
          @korttoma here is the sketch I'm using, probably quite similar to the one @gus shared
           PROGRAMMER: AWI
          Special:
          SUMMARY:
           Remarks:
              Fixed node-id
          #define MY_BAUD_RATE  9600
          #define MY_NODE_ID  20
          #define SN "Scrolling Text"
          #define SV "2.1"
          #include <MyConfig.h>
          const int MAX_DEVICES = 8 ;                 // number of 8x8 displays
          #if USE_POT_CONTROL
          #else
          const int SCROLL_DELAY = 60 ;               // in milliseconds
            sendSketchInfo(SN, SV);
             wait(200);
             wait(200);
             //gw.send(textMsg.set("-"));                            // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
             wait(200);
              // Initializations
             wait(200);
             requestTime(receiveTime);                            // get the time from controller (handled by receiveTime)
             wait(200);
            uint8_t colData;
            switch(state)
                curLen = 0;
                state++;
                if (*p == '\0')
                  curLen = 0;
                  state = 2;
                break;
                colData = 0;
                curLen++;
                  state = 0;
                break;
              default:
                state = 0;
            return(colData);
          #if PRINT_CALLBACK
              Serial.print(dev);
              Serial.print(' ');
              Serial.print(t);
              Serial.print(' ');
          #if USE_POT_CONTROL
              return(t);
          #else
          void setup(){
          #else
              strcpy(curMessage, "HEJ ARON      ");                // first message on display
              // Setup MySensors
              readSerial();
                  lastUpdate = now;
              scrollText();
                      int IncomingBrightness = message.getInt();
                      if (IncomingBrightness == 0) {
                        textOnOff = true;
                      }else {
                        textOnOff = false;
                putIndex = 0;
              else
          • Tomas
          • korttomaK
            korttomaK
            korttoma
            Anybody have an example where this setup shows the time while there is no message to scroll?
            • Tomas
            A 1 Reply Last reply
              A
              A
              artur
              @korttoma
              Here are found the blank, you need to check how it works
                PROGRAMMER: AWI
                Special:
                SUMMARY:
                Remarks:
                  Fixed node-id
              #define  DEBUG 0   // Enable or disable (default) debugging output
              #include <MySensor.h>                       // Mysensor network
              #define PRINT_CALLBACK  0
              #define  PRINTS(x) Serial.print(F(x))
              #define PRINTD(x) Serial.println(x, DEC)
              int statetus_tame = 1;
              char sdate[11];
              char stime[9];
              byte textOnOff = true ;                     // textOnOff = ! shutdown
                uint8_t colData;
                switch (state)
                    showLen = mx.getChar(*p++, sizeof(cBuf) / sizeof(cBuf[0]), cBuf);
                    curLen = 0;
                    state++;
                    if (*p == '\0')
                      curLen = 0;
                      state = 2;
                    break;
                    colData = 0;
                    curLen++;
                      state = 0;
                    break;
                  default:
                    state = 0;
                return (colData);
              void printText(uint8_t modStart, uint8_t modEnd, char *pMsg)
              // Print the text string to the LED matrix modules specified.
              // Message area is padded with blank columns after printing.
                uint8_t   state = 0;
                uint8_t    curLen;
                uint16_t  showLen;
                uint8_t   cBuf[8];
                int16_t   col = ((modEnd + 1) * COL_SIZE) - 1;
                mx.control(modStart, modEnd, MD_MAX72XX::UPDATE, MD_MAX72XX::OFF);
                do     // finite state machine to print the characters in the space available
                  switch (state)
                      if (*pMsg == '\0')
                        showLen = col - (modEnd * COL_SIZE);  // padding characters
                        state = 2;
                        break;
                      // retrieve the next character form the font file
                      showLen = mx.getChar(*pMsg++, sizeof(cBuf) / sizeof(cBuf[0]), cBuf);
                      curLen = 0;
                      state++;
                      mx.setColumn(col--, cBuf[curLen++]);
                      // done with font character, now display the space between chars
                        state = 2;
                      break;
                    case 2: // initialize state for displaying empty columns
                      curLen = 0;
                      state++;
                    // fall through
                    case 3: // display inter-character spacing or end of message padding (blank columns)
                      mx.setColumn(col--, 0);
                      curLen++;
                        state = 0;
                      break;
                    default:
                      col = -1;   // this definitely ends the do loop
                } while (col >= (modStart * COL_SIZE));
                mx.control(modStart, modEnd, MD_MAX72XX::UPDATE, MD_MAX72XX::ON);
              void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col) {
              #if PRINT_CALLBACK
                Serial.print(dev);
                Serial.print(' ');
                Serial.print(t);
                Serial.print(' ');
              void scrollText(void) {
                if (millis() - prevTime >= scrollDelay) {               // Is it time to scroll the text?
              uint16_t getScrollDelay(void) {
                return (SCROLL_DELAY);
                // Setup MySensors
                sendSketchInfo("AWI Scroll MAX 51", "1.1");
                // Initializations
                static unsigned long lastUpdate2 ;                       // Static hold the last update time
                readSerial();
                if (now - lastUpdate > 30000 && statetus_tame == 0) {
                  statetus_tame = 0;
                  sprintf(sdate, "%02d-%02d-%d", day(), month(), year());
                  printText(0, MAX_DEVICES - 1, sdate);
                  lastUpdate = now;
                if (textAlarm) {                                    // if alarmstatus: override all text and set max intensity
                  //strcpy(curMessage, "   ALARM   ");
                if (textAlarm) {
                  scrollText();
                } else {
                  //sprintf(stime, "%02d:%02d:%02d", hour(), minute(), second());
                  if (statetus_tame == 1) {
                    printText(0, MAX_DEVICES - 3, stime);
                if (now - lastUpdate2 > 32000) {
                  statetus_tame = 1;
                  mx.clear();
                  lastUpdate2 = now;
              if (now - lastUpdate >33000 ){
                requestTime();
                lastUpdate = now;
                if (message.sensor == messageCHILD) {
                  if (message.type == V_TEXT) {                   // Text content
                  if (message.type == V_STATUS) {                 // True/ false content
                    textAlarm = message.getBool() ? true : false ; // set alarmflag
                } else if (message.sensor == brightnessChild) {
                  if (message.type == V_PERCENTAGE) {             // Level 0..100  content
                    textBrightness = map(message.getInt(), 0, 100, 0, MAX_INTENSITY ) ; // map to brightnesslevel
                  } else if (message.type == V_STATUS) {          // Display on/off
                    textOnOff = message.getBool() ? false : true ;  // set shutdown/ !on/off
                  if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE - 3)) // end of message character or full buffer
                    putIndex = 0;
                  else
              • A artur
                @korttoma
                  PROGRAMMER: AWI
                  Special:
                  SUMMARY:
                  Remarks:
                    Fixed node-id
                char sdate[11];
                char stime[9];
                  uint8_t colData;
                  switch (state)
                      curLen = 0;
                      state++;
                      if (*p == '\0')
                        curLen = 0;
                        state = 2;
                      break;
                      colData = 0;
                      curLen++;
                        state = 0;
                      break;
                    default:
                      state = 0;
                  return (colData);
                  uint8_t   state = 0;
                  uint8_t    curLen;
                  uint16_t  showLen;
                  uint8_t   cBuf[8];
                    switch (state)
                        if (*pMsg == '\0')
                          state = 2;
                          break;
                        curLen = 0;
                        state++;
                          state = 2;
                        break;
                        curLen = 0;
                        state++;
                      // fall through
                        curLen++;
                          state = 0;
                        break;
                      default:
                #if PRINT_CALLBACK
                  Serial.print(dev);
                  Serial.print(' ');
                  Serial.print(t);
                  Serial.print(' ');
                  // Setup MySensors
                  // Initializations
                  readSerial();
                    statetus_tame = 0;
                    lastUpdate = now;
                  if (textAlarm) {
                    scrollText();
                  } else {
                    statetus_tame = 1;
                    mx.clear();
                    lastUpdate2 = now;
                  requestTime();
                  lastUpdate = now;
                      putIndex = 0;
                    else
                korttomaK
                korttomaK
                korttoma
                #47
                @artur thanks for your example. I managed to make it show the time. Now I just need to figure out how to make it show the text also.
                • Tomas
                • S
                  shabba
                  Sorry for hijack. I am trying to get domoticz to show text from a node but am not able to.
                  present(2, S_INFO, "Gate Open Reason");
                  MyMessage msg2(2,V_TEXT);
                  String reason = "blah";
                  send(msg2.set(reason));
                  But domoticz only shows a 1. Probably missing something obvious?
                  AWIA 1 Reply Last reply
                  • S shabba
                    AWIA
                    AWIA
                    AWI
                    @shabba Try without using "String" type use "char[x]" instead. In general you should try to avoid using this type in real time environments. send(msg2.set("Blah")); should do the trick in first instance.
                    S 1 Reply Last reply
                    • AWIA AWI
                      shabba
                      @AWI Derp! Looking at the headers that looks right! Will try a little later and report. Thanks!
                      • S
                        shabba
                        I just did send(msg2.set(reason.c_str())); and it worked. Thanks @AWI
