  3. Power/ Usage sensor - multi channel - local display
41 Posts 6 Posters 23.5k Views 7 Watching
  • A Offline
    A Offline
    AWI
    It is a power meter device which displays: current power, daily usage and total usage of upto 12 S0 meters and sends all the information through the MySensors network. The current sketch displays power used and generated from the different channels and uses a rotary encoder to browse the displays and adjust the (total values).upload-47e80693-5e06-4b90-9e6b-c435212fc038 (also added message communication to the display from the controller (V_TEXT).
    With reference to my earlier project I reworked the whole thing to be more reliable and added functionality. The basic concept is the same:
    1 Arduino doing the time critical measurement and counting of the pulses and time, sending the measurements via a one-wire serial in JSON
    upload-e7fcad43-2ae0-4762-8c25-7d1bc3c71e2b
    including "patch panel" for connection to the S0 meters.
    upload-d07ff26c-a941-4923-9324-7b7842627af2
    Another arduino reading the JSON string and performing the tasks like display and sending the values over the MySensors network.
    upload-bbac86e4-758d-4794-8740-05e22b54be8d
    The grey and white wire connect to the "measurement" Arduino.
    some displays:
    upload-762b5e1e-dada-4314-ae95-7d6fa6c1b2aa
    adjusting the values
    upload-b1afc999-309b-4b5a-9170-c4998e2c7627
    reset the daily values
    • A Offline
      A Offline
      AWI
      the code for the measurement device::
      // Arduino Pulse Counting Sketch for counting pulses from up to 12 pulse output meters.
      // uses direct port manipulation to read from each register of 6 digital inputs simultaneously
      // Licence: GNU GPL
      // part of the openenergymonitor.org project
      // Author: Trystan Lea
      // AWI: adapted to produce JSON and error checking at client side.
      // Pulse Counting Class - could be placed in seperate library...
      class PulseOutput
      public:                                 		 //AWI: access to all
        boolean pulse(int,int,unsigned long);                  //Detects pulses, in pulseLib.ino
        unsigned long rate( unsigned long );                   //Calculates rate
        unsigned long count;                                   //pulse count accumulator
        unsigned long countAccum;                              //pulse count total accumulator for extended error checking (only resets at startup)
        unsigned long prate;                                   //pulse width in time
        unsigned long prateAccum;                              //pulse rate accumulator for calculating mean.
      private:
        boolean ld,d;                                          //used to determine pulse edge
        unsigned long lastTime,time;                           //used to calculate rate
      // Variable declaration
      //CHANGE THIS TO VARY RATE AT WHICH PULSE COUNTING ARDUINO SPITS OUT PULSE COUNT+RATE DATA
      //time in seconds;
      const unsigned long printTime = 1000000;	// delay between serial outputs in us (one meter at a time)
      const int lastMeter = 7 ; 	 	// is number of meters + 1
      byte curMeter = 2 ;				// current meter for serial output, wraps from 2 to lastMeter
      PulseOutput p[14];            //Pulse output objects
      int a,b,la,lb;                //Input register variables
      unsigned long ltime, time;    //time variables
       // take care: pull-up inverses state! line 155
      	//setup input pins here with pull_up, else (default) float
      	pinMode( 2, INPUT_PULLUP);
      	pinMode( 3, INPUT_PULLUP);
      	pinMode( 4, INPUT_PULLUP);
      	pinMode( 5, INPUT_PULLUP);
      	pinMode( 6, INPUT_PULLUP);
      	pinMode( 7, INPUT_PULLUP);
      	pinMode( 8, INPUT_PULLUP);
      	pinMode( 9, INPUT_PULLUP);
      	pinMode(10, INPUT_PULLUP);
      	pinMode(11, INPUT_PULLUP);
      	pinMode(12, INPUT_PULLUP);
      	pinMode(13, INPUT_PULLUP);
        Serial.begin(115200);       //standard serial
        DDRD = DDRD | B00000000;
        DDRB = DDRD | B00000000;
        la = a;                    //last register a used to detect input change
        lb = b;                    //last register b used to detect input change
        // Read from input registers
        a = PIND >> 2;             //read digital inputs 2 to 7 really fast
        b = PINB;                  //read digital inputs 8 to 13 really fast
        time = micros();
        if (la!=a || lb!=b)
          // Detect pulses from register A
          p[2].pulse(0,a,time);                //digital input 2
          p[3].pulse(1,a,time);                //    ''        3
          p[4].pulse(2,a,time);                //    ''        etc
          p[5].pulse(3,a,time);
          p[6].pulse(4,a,time);
          p[7].pulse(5,a,time);
          // Detect pulses from register B
          p[8].pulse(0,b,time);                //digital input 8
          p[9].pulse(1,b,time);                //etc
          p[10].pulse(2,b,time);
          p[11].pulse(3,b,time);
          p[12].pulse(4,b,time);
          p[13].pulse(5,b,time);
        // Spit out data every printTime sec (time here is in microseconds)
        // build JSON: for all counters print Count (W), Count Accum(W), Average ms
        // Format {"m":meter,"c":count,"r":rate, "cA":countAccum}
        if ((time-ltime)>(printTime))
          ltime = time;                          	//Print timer
            Serial.print("{\"m\":");
            Serial.print(curMeter-1);           	//Print meter number
            Serial.print(",\"c\":");
            Serial.print(p[curMeter].count);    	//Print pulse count
            Serial.print(",\"r\":");
            Serial.print(p[curMeter].rate(time));	//Print pulse rate
      	  p[curMeter].countAccum += p[curMeter].count;	//Increment and print count accumulator to allow for error checking at client side;
      	  Serial.print(",\"cA\":");
            Serial.print(p[curMeter].countAccum);
            Serial.println("}");
            p[curMeter].count = 0;                //Reset count (we just send count increment)
            p[curMeter].prateAccum = 0;       	//Reset accum so that we can calculate a new average
      	curMeter++ ;
      	if (curMeter > lastMeter){				// wrap a around if passed last meter
      		curMeter = 2;}
      // library for pulse, originally in separate file
      //Gets a particular input state from the register binary value
      // A typical register binary may look like this:
      // B00100100
      // in this case if the right most bit is digital pin 0
      // digital 2 and 5 are high
      // The method below extracts this from the binary value
      #define BIT_TST(REG, bit, val)( ( (REG & (1UL << (bit) ) ) == ( (val) << (bit) ) ) )
      // Method detects a pulse, counts it, finds its rate, Class: PulseOutput
      boolean PulseOutput::pulse(int pin, int a, unsigned long timeIn)
         ld = d;                                    //last digital state = digital state
         if (BIT_TST(a,pin,1)) d = 1; else d = 0;   //Get current digital state from pin number
         // if (ld==0 && d==1)                      // no internal pull_up if state changed from 0 to 1: internal pull-up inverts state
      	if (ld==1 && d==0)                         //pull_up f state changed from 0 to 1: internal pull-up inverts state
           count++;                                 //count the pulse
           // Rate calculation
           lastTime = time;
           time = timeIn ;						// correction to allow for processing
           prate = (time-lastTime);// - 400;          //rate based on last 2 pulses
                                                      //-190 is an offset that may not be needed...??
           prateAccum += prate - 2000;                     //accumulate rate for average calculation
           return 1;
         return 0;
      // Method calculates the average rate based on multiple pulses (if there are 2 or more pulses)
      unsigned long PulseOutput::rate(unsigned long timeIn)
       if (count > 1)
         prate = prateAccum / count;                          //Calculate average
       } else
       if ((timeIn - lastTime)>(prate*2)) prate = 0;}         //Decrease rate if no pulses are received
                                                              //in the expected time based on the last
                                                              //pulse width.
       return prate;
      F 1 Reply Last reply
      • A Offline
        A Offline
        AWI
        And an little code for the master, heavily commented. I used the "click encoder" library in combination with a "State machine" to get to a comprehensible user interface.
         * MySensors interface to AWI 12 input usage/ power Meter                  *
         * measures Power/ Usage/ Cumm. usage for upto 12 independent channels.    *
         * 20x4 (I2C) Display shows consumption                                    *
         * Update:        *
         * 20150821 - removed dependency on controller, added local history        *
         *	- New rotary encoder library with acceleration and click               *
         *	- Changed to simple State machine                                      *
        // Licence: GNU GPL
        // Author: AWI 2015
        // Updates: AWI 20150815, new RotaryEncoder & ArduinoJson libraries
        // 20150821 - removed dependency on controller, added local history and update
        //	- Changed rotary encoder library
        //	- Changed to simple "state machine"
        // Functionality:
        // continuously:
        // 1. read JSON strings from Pulse12Counter slave , format {"m":meter,"c":count,"r":rate, "cA":countAccum}
        // 2. calculate real time Power from "pulse rate"
        // 3. daily counters
        // 4. send to controller
        // Changed
        // 1. Total Wh values are now stored local and are only sent to controller
        // Other:
        // 1. display on LCD, time & energy values, usage can be shown as Daily & Total
        // 2. rotary encoder to browse the different displays
        // 3. rotary encoder used to change the local values, stored in EEPROM every day and after update
        // 4. depending on display encoder has "short/ long/ click/ double clik" functionality
        // 5. Uses new (201509) V_TEXT to display text from controller.
        // Caution: pulse meter is connected to std serial (pin D0), Serial.print can still be used
        //    Disconnect pulse meter when programming via FTDI! (else sync error)
        #include <MySensor.h>                 	// MySensors network
        #include <LiquidCrystal_I2C.h>        	// display I2C
        #include <Time.h>
        #include <Wire.h>
        #include <ClickEncoder.h>				// Lib includes click functionality: https://github.com/0xPIT/encoder/tree/arduino
        #include <TimerOne.h>					// for ClickEncoder interrupt calls
        #include <ArduinoJson.h>          		// used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
        // Constants & globals
        const int NO_METERS = 6 ;				// actual meters used (max 12)
        const int NODE_ID = 24 ;             	// fixed MySensors node ID
        const int LCD1_CHILD = 20 ;				// custom text message child, Controller can display message
        const int JSON_LENGHT = 80 ;			// Maximum json string length
        // new V_TEXT variable type (development 20150905)
        //const int V_TEXT = 47 ;
        // new S_INFO sensor type (development 20150905)
        //const int S_INFO = 36 ;
        char lastLCD1[21] = "--                  ";	// LCD message line
        typedef enum meterTypes: int8_t {meterIn, meterOut, meterNeutral} ;				// metertype for addition in totals: in, out, neutral
        const char METER_NAMES[NO_METERS][4] = {"Gr1", "Gr2","EA ","Pv1","Pv2", "Tst"} ; // meter names
        const meterTypes METER_TYPES[NO_METERS] = {meterOut, meterOut, meterOut, meterIn, meterIn, meterOut};
        const unsigned long idleTime = 10000 ;	// Delay time for any of the states to return to idle
        unsigned long idleTimer ;				// Delay timer for idleTime
        // RotaryEncoder
        const int8_t encPinA = A1;				// Encoder pins
        const int8_t encPinB = A0;
        const int8_t encPinButton = A2;
        const int8_t encStepsNotch = 2;   		// tune for best stepsize (1..4, 1=default)
        const bool encButton = LOW ;      		// active low pushbutton
        ClickEncoder encoder(encPinA, encPinB, encPinButton, encStepsNotch, encButton);	// instantiate the encoder
        union {									// used to convert long to bytes for EEPROM storage
        	long kWhLongInt;
        	uint8_t kWhLongByte[4];
        	} kWhLong ;
        // Possible states for the state machine.
        // Idle: default state, show totals for in/out nett
        // Browse: dive into meter details
        // Update: update meter value (Wh total)
        // Reset: reset day values
        enum States: int8_t {IDLE, BROWSE, UPDATE, RST} ;
        uint8_t State = IDLE;					// current state machine state
        // meter class, store all relevant meter data (equivalent to struct)
        class pulseMeter
        public:
        	long UsageWh; 						// last (current) usage (in W) from pulse counter
        	long UsageAccumWh;					// usage accumulator (to keep in sync) from pulse counter
        	long PowerW;						// actual power, calculated from pulse "rate"
        	long DayUsageWh;					// daily usage for display
        	meterTypes Type;					// metertype for addition in totals: in, out, neutral
        	char Name[4] ;						// meter name for display
        pulseMeter pulseMeters[NO_METERS] ;		// define power meters
        pulseMeter totalMeterIn, totalMeterOut, totalMeter;	//  accumulated
        unsigned long tempUsageWh ;				// temporary store while manually updating (state UPDATE)
        // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
        // example: "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}"
        char json[JSON_LENGHT] ;		// Storage for serial JSON string (init for example)
        // flags & counters
        bool timeReceived = false;				// controller time
        bool newDay = false;					// reset at 00:00:00
        unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
        int updateMeter = 0;					// current meter for update
        bool updateDisplayFlag = true ;			// indicate that display needs to be updated
        int currentMeter = 0;					// active meter for update & check, cycles through meters (0..NO_METERS-1)
        int lastRotary = 0;						// last rotary encoder position
        int updateIncrement = 1000 ;			// Interval multiplier for Update
        int errCount = 0 ;						// error counter
        // *** Definition and initialisation
        // define the MySensor network
        MySensor gw;							// pins used RFX24(default 9,10)
        // Initialize messages for sensor network
        MyMessage powerMsg(0,V_WATT); 	        // message to send power in W
        MyMessage usageMsg(0,V_KWH);    	    // message to send usage in kWH
        MyMessage textMsg(0,V_TEXT);    	    // message to send/receive text
        // Set the pins on the I2C chip used for LCD connections:
        //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
        LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
        // OPTIONAL: Custom characters for display - Units)
        byte degCelcius[8] = { B01000, B10100, B01000, B00111, B00100, B00100, B00111, B00000};
        //byte Pascal[8] = { B00000, B11100, B10100, B11100, B10010, B10111, B10101, B00000};
        //byte hecto[8] = { B00000, B00000, B00000, B00100, B00110, B00101, B00101, B00000};
        //byte Lux[8] = { B00000, B10000, B10101, B10010, B10010, B10101, B11100, B00000};
        byte hr[8] = { B00000, B00000, B10000, B10000, B11000, B10100, B10100, B00000};			// small hour symbol
        byte perDay[8] = { B00000, B00000, B00001, B00001, B00011, B00101, B00011, B00000};
        void timerIsr() {						// RotaryEncoder timer interrupt routinge
        	encoder.service();
        // function to reset the Arduino (jump to 0 address)
        void(* resetFunc) (void) = 0;//declare reset function at address 0
        void setup(void)
        	gw.begin(incomingMessage, NODE_ID, false);  			// this node is fixed, no repeat
        	//Send the sensor node sketch version information to the gateway
        	gw.sendSketchInfo("AWI-12ChannelPulse", "2.0");
        	// Initialize the meter names
        	// Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
        	for (int x = 0; x < NO_METERS; x++){
        		gw.present(x, S_POWER, METER_NAMES[x]);             // present power meters to gateway
        		delay(10);                        					// give it some time to process
        	gw.present(LCD1_CHILD, S_INFO);							// present the child for custom text line (20150906)
        	delay(100);
        	gw.send(textMsg.setSensor(LCD1_CHILD).set("-"));		// initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
        	for (int x = 0; x < NO_METERS; x++){ 					// initialize previous kWh values from EEPROM and init
        		for (int y = 0; y < 4 ; y++){						// convert from bytes
        			kWhLong.kWhLongByte[y]= gw.loadState(x *4 + y) ;// EEPROM position = meter number * 4 bytes
        			}												// controller is updated later automatically
        		pulseMeters[x].UsageWh = kWhLong.kWhLongInt;
        		strcpy(pulseMeters[x].Name, METER_NAMES[x] ); 		// copy string for meter names
        		pulseMeters[x].Type = METER_TYPES[x];				// Set type
        	// Initializations
        	Wire.begin();                 							// I2C for display
        	Timer1.initialize(1000);								// interrupt calls for RotaryEncoder
        	Timer1.attachInterrupt(timerIsr);
        	encoder.setAccelerationEnabled(true);
        	gw.requestTime(receiveTime);							// Request latest time from controller at startup
        	// ** LCD display **
        	lcd.begin(20, 4);										// LCD 2 lines * 16 char.
        	lcd.setBacklight(HIGH);
        	// send custom characters to display
        	lcd.createChar(1, degCelcius);
        	lcd.createChar(4, hr);
        	lcd.createChar(7, perDay);
        	lcd.setCursor(0, 0);             						// Reset cursor position
        void loop(void)
        	// Before specific states, perform generic tasks
        	unsigned long now = millis();      						// Timer in loop for "once in a while" events
        	gw.process() ;                      					// process incoming messages
        	// If no time has been received yet, request it every 10 second from controller
        	if ((!timeReceived && (now-lastRequest > 10*1000)) ||
        		(now-lastRequest > 3600000UL)){						// request update every hour to keep in sync
        		Serial.println(F("requesting time"));				// Request time from controller.
        		lastRequest = now;
        	// Check if new day has started (hour == 0) and reset day usage counters of meters
        	if (hour()==0 && !newDay){
        		newDay = true;
        			pulseMeters[x].DayUsageWh = 0 ;					// reset daily counters
        			saveMeters(x);									// save meter values to EEPROM
        	} else if(hour() != 0 && newDay)						// reset newday flag if hour != 0
        		{ newDay = false;}
        	// State machine depends on RotaryEncoder and time actions
        	ClickEncoder::Button rotaryButton = encoder.getButton();// Get the button state
        	switch (State) {
                // Idle state, browse through displays, watches for key presses
                // and changes state accordingly, while taking care of next state init
                case IDLE:
                    if (rotaryButton == ClickEncoder::Clicked) {
        				idleTimer = now ;										// set delay timer for return to idle
        				State = BROWSE ;
        				updateDisplayFlag = true ;}  							// only change state
                    else if (rotaryButton == ClickEncoder::Held) {
        				idleTimer = now ;
        				State = RST;}											// Enter Reset state with Long press.
                    //else if (rotaryButton == ClickEncoder::Released) {} 		// do nothing
        			//else if (rotaryButton == ClickEncoder::Pressed) {} 		// do nothing
                    //else if (rotaryButton == ClickEncoder::DoubleClicked) {} 	// do nothing
        			else {}// perform Idle actions: browse display)
        			break ;
         		case BROWSE:
                    if (rotaryButton == ClickEncoder::Clicked) {State = IDLE ;	// return to IDLE on click
                    else if (rotaryButton == ClickEncoder::Held) {				// update the current displayed value.
        				tempUsageWh = pulseMeters[currentMeter].UsageWh ;		// use temp variable for update (background changes)
        				State = UPDATE ;
                    //else if (rotaryButton == ClickEncoder::Released) {break;} // do nothing
        			//else if (rotaryButton == ClickEncoder::Pressed) {break;} 	// do nothing
                    //else if (rotaryButton == ClickEncoder::DoubleClicked) {break;} // do nothing
        			else if (now > idleTimer + idleTime){State = IDLE ;}		// return to idle after expiration of delay
        			else {// perform Idle actions: browse display)
        				int enc = encoder.getValue();							// get the value from the encoder
        				if (enc != 0)idleTimer = now ;							// set delay timer for return to idle
        				if( enc > 0) {											// cycle through displays depending on up/ down (actual value not used)
        					if (currentMeter++ >= NO_METERS - 1 ) currentMeter = 0;
        					lastRotary = enc ;
        				else if (enc < 0) {
        					if (currentMeter-- <=  0) currentMeter = NO_METERS - 1;
        					lastRotary = enc ;
        			break ;
        		case UPDATE:                									// Double state for large (start) & small increments
        				if (updateIncrement == 1) {								// Save values and return to idle
        					updateIncrement = 1000 ; 							// increment in kWh (x1000)
        					pulseMeters[currentMeter].UsageWh = tempUsageWh;	// save temp to actual
        					saveMeters(currentMeter);							// !!Save the current value to EEPROM (controller will be updated automatically)
        					State = BROWSE; 									// return to browse after update
        				} else{													// increment in Wh (x1)
        					updateIncrement = 1 ;
                    //else if (rotaryButton == ClickEncoder::Held)  break; 		// (use as cancel function?)
                    //else if (rotaryButton == ClickEncoder::Released) break; 	// do nothing
        			//else if (rotaryButton == ClickEncoder::Pressed) break; 	// do nothing
                    //else if (rotaryButton == ClickEncoder::DoubleClicked) break; 		// do nothing
        			else {														// perform Update actions: change current value
        				int16_t enco = encoder.getValue();						// get the value from the encoder
        				if (enco != 0) {
        					tempUsageWh += enco * updateIncrement ;				// update the temp value from the encoder}
        					idleTimer = now ;}									// set delay timer for return to idle
                    break ;
        		case RST:														// reset (jump to reset if Held again)
        				State = IDLE ; 											//reset
        				errCount = 0 ;											// reset Json err counter
        			else if (rotaryButton == ClickEncoder::Clicked) {
        				State = IDLE ;}	// click = return to Idle
        			break ;
        	// Update display every 1 second (IDLE) every loop (Other states)
        	//if (((State == IDLE) && (now-lastUpdate > 100)) || State != IDLE ){
        	if (now-lastDisplay > 1000){
        		lastDisplay = now;
        		//Serial.print("State: ");
        		//Serial.println(State);
        	if (updateDisplayFlag) {
        		LCD_local_display();
        		updateDisplayFlag = false ;
        	// Every 10 seconds update one meter to controller to avoid traffic jams
         	if (now-lastSyncKWH > 10000){
        		//printPulsemeter(updateMeter);
        		sendPowerUpdate(updateMeter);        						// update the values for currentMeter
        		updateMeter++ ;
        		if (updateMeter >= NO_METERS){     							// increment and wrap current meter
        			updateMeter = 0 ;}
        		lastSyncKWH = now ;
        	// Update sensors every 10 secs
        	if (now-lastUpdate > 10000) {
        		// get values to be displayed from controller
        		gw.request(LCD1_CHILD, V_TEXT);		 						// LCD text message
        		lastUpdate = now;
        	// get readings from serial (sent every 10s)
        	// format {"m":meter,"c":count,"r":rate, "cA":countAccum}
        	// use JSON parser to process (could be replaced by simple split routine, but this works just fine)
        	if(readLineJSON(Serial.read(), json, JSON_LENGHT) > 0 ){   		//dummySerial(), Serial.read()
        	// if(readLineJSON(dummySerial(), json, 80) > 0 ){   			//dummySerial(), Serial.read()
        		Serial.println(json);
        		storeMeterJSON(json);           							//store the meter reading
        		calcMeterTotals();											// update totals
        // This is called when a new time value was received
        void receiveTime(unsigned long controllerTime) {
            // Ok, set incoming time
            Serial.print(F("Time value received: "));
            Serial.println(controllerTime);
            setTime(controllerTime); 										// set the clock to the time from controller
        	timeReceived = true ;
        // This is called when a message is received
          // Expect few types of messages from controller, V_VAR1 for messages
        	if (message.type==V_TEXT) {
        		// if message comes in, update the kWH reading for meter with value since last update
        		// Write some debug info
        		//Serial.print("Last reading for sensor: ");
        		//Serial.print(message.sensor);
        		//Serial.print(", Message: ");
        		//Serial.println(message.getString());
        		if (message.sensor == LCD1_CHILD ) {
        			strcpy(lastLCD1, message.getString());	// read payload in LCD string
        // save Meter to EEPROM when needed
        void saveMeters(int8_t meterNo){
        	kWhLong.kWhLongInt = pulseMeters[meterNo].UsageWh ; 					// convert to separate bytes via struct
        		gw.saveState(meterNo * 4 + y, kWhLong.kWhLongByte[y])  ;			// EEPROM position = meter number * 4 bytes
        void sendPowerUpdate(int meterNo)
        // Sends update to controller for current meter
            gw.send(powerMsg.setSensor(meterNo).set((long)pulseMeters[meterNo].PowerW));			// meterNo * 100 ));
            gw.send(usageMsg.setSensor(meterNo).set((float)pulseMeters[meterNo].UsageWh/1000L ,3)); // send in kWh!
        //  calculate the total values for from the meters
        //  Total in and out
        void calcMeterTotals(void)
        	totalMeterIn.UsageWh = 0 ;
        	totalMeterIn.PowerW = 0 ;
        	totalMeterIn.DayUsageWh = 0 ;
        	totalMeterOut.UsageWh = 0 ;
        	totalMeterOut.PowerW = 0 ;
        	totalMeterOut.DayUsageWh = 0 ;
        	for (int x = 0; x < NO_METERS; x++){ 					// add In and Out meters to totals
        		if (pulseMeters[x].Type == meterIn){
        			totalMeterIn.UsageWh += pulseMeters[x].UsageWh;
        			totalMeterIn.PowerW += pulseMeters[x].PowerW ;
        			totalMeterIn.DayUsageWh += pulseMeters[x].DayUsageWh ;
        		else if (pulseMeters[x].Type == meterOut){
        			totalMeterOut.UsageWh += pulseMeters[x].UsageWh;
        			totalMeterOut.PowerW += pulseMeters[x].PowerW ;
        			totalMeterOut.DayUsageWh += pulseMeters[x].DayUsageWh ;
        	} // else = neutral, do nothing
        	totalMeter.UsageWh = totalMeterOut.UsageWh - totalMeterIn.UsageWh ;		// calculate nett values
        	totalMeter.PowerW = totalMeterOut.PowerW - totalMeterIn.PowerW ;
        	totalMeter.DayUsageWh = totalMeterOut.DayUsageWh - totalMeterIn.DayUsageWh ;
        void LCD_local_display(void)
        // prints variables on LCD display with units, depending on current State
        // IDLE = totals
        // BROWSE = individual meters
        // SET = individual meter & value
           	//long loopDelay = millis();									// Test loop time
        	char buf[21]; 												// buffer for display
        	char tempBuf[11];											// Temporary storage for float -> char conversion
        	// always, time on first line
        	snprintf(buf, sizeof buf, "%02d:%02d:%02d %02d-%02d %5s", hour(), minute(), second(), day(), month(), lastLCD1);
        	lcd.setCursor(0,0);               							// LCD line 1
        	lcd.print(buf);
        	// State specific (line 2, 3, 4)
        	switch (State) {
        		case IDLE:
        			// display In meter total on line 2
        			dtostrf((float)totalMeterOut.DayUsageWh /1000.0, 6, 2, tempBuf);
        			snprintf(buf, sizeof buf, "Use: %6skW\x04%5dW  ", tempBuf, (int)totalMeterOut.PowerW );
        			lcd.setCursor(0,1);               					// LCD line 2
        			lcd.print(buf);
        			// display Out meter total on line 3
        			dtostrf(totalMeterIn.DayUsageWh /1000.0, 6, 2, tempBuf);
        			snprintf(buf, sizeof buf, "Gen: %6skW\x04%5dW  ", tempBuf, (int)totalMeterIn.PowerW );
        			lcd.setCursor(0,2);               					// LCD line 3
        			lcd.print(buf);
        			// display Net meter total on line 4
        			dtostrf(totalMeter.DayUsageWh /1000.0, 6, 2, tempBuf);
        			snprintf(buf, sizeof buf, "Net: %6skW\x04%5dW  ", tempBuf, (int)totalMeter.PowerW );
        			lcd.setCursor(0,3);               					// LCD line 4
        			lcd.print(buf);
        			break;
        		case BROWSE:
        			// meter indicated by "currentMeter"
        			dtostrf((float)pulseMeters[currentMeter].DayUsageWh /1000.0, 6, 2, tempBuf);
        			snprintf(buf, sizeof buf, "%4s%6skW\x04\x07%5dW  ", pulseMeters[currentMeter].Name, tempBuf, (int)pulseMeters[currentMeter].PowerW );
        			lcd.print(buf);
        			// display total for meter line 3,
        			dtostrf((float)pulseMeters[currentMeter].UsageWh /1000.0, 10, 2, tempBuf);
        			snprintf(buf, sizeof buf, "tot:%10skW\x04          ",tempBuf);
        			lcd.print(buf);
        			// TEST: display full message on line 4
        			snprintf(buf, sizeof buf, "%20s", lastLCD1);
        			lcd.print(buf);
        			break;
        		case UPDATE:
        			lcd.print(buf);
        			// display current value on line 3
        			dtostrf((float)pulseMeters[currentMeter].UsageWh /1000.0, 10, 3, tempBuf);
        			snprintf(buf, sizeof buf, "tot:%10skW\x04 \x7E      ",tempBuf);
        			lcd.print(buf);
        			// display update value on line 4
        			dtostrf((float)tempUsageWh /1000.0, 10, 3, tempBuf);
        			lcd.print(buf);
        			break;
        		case RST:
        			//snprintf(buf, sizeof buf, "Use: %6skW\x04%5dW  ", tempBuf, (int)totalMeterOut.PowerW );
        			lcd.clear();
        			lcd.setCursor(0,0);               					// LCD line 2
        			lcd.print("Doubleclick to reset");
        			lcd.setCursor(0,2);
        			snprintf(buf, sizeof buf, "JSON err count: %d",errCount);
        			lcd.print(buf);
        		default:												// default display
        			break;
        int storeMeterJSON(char *json)
        /* convert JSON to values and store in corresponding meter (if used)
         input: JSON string (can be wrong formatted), with length
         output: changed meter record number or -1 if error
         use JsonParser
          StaticJsonBuffer<50> jsonBuffer; 							// 4 object  -> 4 + 4*10 = 44
          // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
            JsonObject& root = jsonBuffer.parseObject(json);
          if (!root.success())
                Serial.println(F("JsonParser.parse() failed"));
        		errCount++ ;
                return -1;
          int m = (long)root["m"];
          if (m > NO_METERS){                 						// meter value out of range for used meters (m starts at 1)
            return -1 ;
          } else {                     								// update meter values, Power is momentary, Usage is cumulative
        	long newAccumWh = (long)root["cA"] ;
        	long newWh = (long)root["c"] ;
        	long diffAccumWh = newAccumWh - pulseMeters[m-1].UsageAccumWh; 	// check for missed pulses by comparing cA with last stored value
        	if (diffAccumWh >= newWh){								// no difference or missed pulses -> correct: add difference
        		pulseMeters[m-1].UsageWh += diffAccumWh;
        		pulseMeters[m-1].DayUsageWh += diffAccumWh;
        	else {													// negative diff, out of sync -> add pulses only (can be out of range or restart)
        		pulseMeters[m-1].UsageWh += newWh;
        		pulseMeters[m-1].DayUsageWh += newWh;
        	pulseMeters[m-1].UsageAccumWh = newAccumWh; 			// always update sync counter (only for sync and error correction(serial))
            if ((long)root["r"] == 0){            					// calculate power from pulse rate (ms) and truncate to whole Watts
              pulseMeters[m-1].PowerW = 0;							// if overflow assume no Usage
            } else {
              pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]); // rate in microseconds
            return m ;
        int readLineJSON(int readch, char *buffer, int len)
        /* checks for JSON and when started append char tot buffer and checks for line completion
        usage:
          static char buffer[80];
          if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
          returns simple JSON
          static int pos = 0;
          int rpos;
          if (readch > 0) {
            switch (readch) {
              case '\n':                // Ignore new-lines
                break;
              case '\r':                // Return on CR
                rpos = pos;
                pos = 0;                  // Reset position index ready for next time
                return rpos;
              default:
                if (pos < len-1) {
                  buffer[pos++] = readch;
                  buffer[pos] = 0;
          // No end of line has been found, so return -1.
          return -1;
        int dummySerial()
        // Acts as a dummy JSON serial character generator for debugging
        // input: none
        // output: preset JSON string
          static int pos = 0;
          char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
          if (pos++ >= strlen(json)){
            pos = 0;
          return json[pos] ;
        void printPulsemeter(int meter)
        // prints the Pulsemeter record to serial out
          Serial.print("m:");
          Serial.print(meter);
          Serial.print(", power: ");
          Serial.print(pulseMeters[meter].PowerW);
          Serial.print(", usage: ");
          Serial.print(pulseMeters[meter].UsageWh);
          Serial.print(", day usage: ");
          Serial.println(pulseMeters[meter].DayUsageWh );
        //  Serial.print(", Ca: ");
        //  Serial.println(pulseMeters[meter].UsageAccumWh);
        • J Offline
          J Offline
          jeti
          Hi, great work :+1:
          as my S0 meter uses 2000imp/kwh and my reading seem to be twice as high as they should be i guess your meters do 1000imp/kwh?
          As i am still working on my programming skills i could not figure out where to change this :flushed:
          can you give me a hint which 1000 to change out with my 2000?
          thanks!
          A 1 Reply Last reply
          • M Offline
            M Offline
            MarkV
            wrote on last edited by MarkV
            AWI I got it up and running with your new sketches!! :smiley:
            Great work!!!!! Domoticz recognizes that there are sensors in the network.
            But something is still wrong, the usage isn't going up..
            Whats wrong?
            Didn't connect a display and rotaryswitch and also didn't commented things out..
            Why does it show every sensor twice? One with subtype unknown and one with electric??
            I also seen that with the humidity temp sensor..
            The serial on the master arduino says:
            There's not more than a tiny plaster wall between the two arduinos, a total distance of one meter...
            • M MarkV
              Whats wrong?
              A Offline
              A Offline
              AWI
              @MarkV A few thing from what I read from the serial out:
              • The slave does not sense any pulses, all the values are at 0
              • The master gets a "fail" when sending data to the Gateway. Looks like a communication issue
              • Are you using an USB or LAN gateway. The Domoticz output show both.... I don't know if Domoticz can handle that.
              • You can try to delete the "old"/previous nodes and start the thing again. Domoticz should use a combined Usage/ Power sensor
              M 1 Reply Last reply
              • J jeti
                Hi, great work :+1:
                thanks!
                A Offline
                A Offline
                AWI
                @jeti You are right, I never thought about other meters than the 1 pulse = 1 Whr ones..sorry. There are a few ways of getting it changed:
                • You can keep leave most as it is and when you send/ or display the values divide the pulses by two and double the Watt values in the routines "LCD_local_display" and "sendPowerUpdate"
                • or: make the necessary calculations when the data comes in. This is a little more complicated in routine "storeMeterJSON" but if you understand the logic (including error corrrection) should be not too hard.
                • A AWI
                  M Offline
                  M Offline
                  MarkV
                  @AWI
                  I´m using a LAN GW, i disconnected the serial and made the LAN one of it.
                  Mmm, the comms error is strange, they're at max one meter apart, with a tiny plaster wall in between, both also got a cap between vcc and gnd.
                  Next weekend i´m going to have a look at the slave input, rather strange that it doesn´t receives pulses.
                  I connected the 5volt line to all the 6 pulse meters and connected their output to D2 - D8, through a cord of network cable.
                  Thanks for all your help so far!!!!!
                  • J Offline
                    J Offline
                    jeti
                    wrote on last edited by jeti
                    @AWI
                    thanks! as i do not have display (yet) i just did the calculations in the "sendPowerUpdate" -> now it works perfect :smile:
                    I just double check with a powermeter to see if everything is ok.
                    • M MarkV
                      @AWI
                      A Offline
                      A Offline
                      AWI
                      @MarkV just one tip for today... You should connect the common ground to the pulse meters. The inputs use a pull-up to vcc..
                      • M Offline
                        M Offline
                        MarkV
                        Dawm maybe thats the problem..
                        I connected the 5v as commen to the pulse + and the - to the digital inputs.
                        So to be sure i need to connect the pulse + to the digitale inputs and the pulse - to gnd????
                        • M MarkV
                          A Offline
                          A Offline
                          AWI
                          @MarkV I would depend on your S0 meters, but normal is "open collector" so you can connect '-' to ground and '+' to the input (= pull-up to Vcc).
                          (another way to connect is + to vcc and - to input, but then you need external "pull down" resistors and change the sketch)
                          • M Offline
                            M Offline
                            MarkV
                            Then thats the problem with the slave arduino getting no data. I connected the pulse output like you mentioned second and didn't changed the sketch.
                            Maybe i'm home tomorrow then i will give it a try.
                            Or is it hard to chsnge the sketch? And what should i change?
                            • M MarkV
                              A Offline
                              A Offline
                              AWI
                              @MarkV it is indicated in the sketch but you also need external resistors for pull-down. If you disable the internal pull-up resistors the levels are inverted. So you also need to'invert' the measurements or you are measuring the pulse width instead of the time between pulses.
                              • M Offline
                                M Offline
                                MarkV
                                Tonight i checked the wires and changed them and i believe your wright, the output is:
                                But it keeps giving a error, so i hangt them near each other with approx. 10cm space in between, why does it stil say fail after a good startup with ok and after 10a20sec it starts saying fail..
                                Is the readout correct?
                                And what more could cause the fail error?
                                • M MarkV
                                  A Offline
                                  A Offline
                                  AWI
                                  @MarkV In most of the cases "fail" is related to the power supply of the radio. Did you follow the instructions for connection of the radio?
                                  • A AWI
                                    // Licence: GNU GPL
                                    class PulseOutput
                                    private:
                                    //time in seconds;
                                      time = micros();
                                      if (la!=a || lb!=b)
                                    	curMeter++ ;
                                    		curMeter = 2;}
                                    // B00100100
                                         // Rate calculation
                                         lastTime = time;
                                         return 1;
                                       return 0;
                                     if (count > 1)
                                     } else
        //pulse width.
                                     return prate;
                                    F Offline
                                    F Offline
                                    FotoFieber
                                    @AWI
                                    Your measurement sketch is really nice. There is one line I do not understand.
                                    Is this prateAccum needed or couldn't it be left away? What is the meaning of 2000 in this context?
                                    Cu,
                                    FotoFieber
                                    • F FotoFieber
                                      @AWI
                                      Cu,
                                      FotoFieber
                                      A Offline
                                      A Offline
                                      AWI
                                      @FotoFieber To be honest .. a left over from some experiments. Just leave it out... you won't notice the difference.
                                      • J Offline
                                        J Offline
                                        jeti
                                        @AWI thanks again!
                                        I am using your sketches with only one S0 Meter (the 2000pulse/kwh one).
                                        *One thing i just found out, that as long as the master arduino is connected to the serial port of my pc it is running fine but when its not, it does not send.I have checked the voltage at the radio and it is the same... I also do not have any display or rotary encoder, as I do the visualisation with FHEM.
                                        Do you know why this is the case? * -> Voltage was to low... but the secon question remains:
                                        Any idea to use differen pulses/kwh S0 meters? for example one 2000pulse/kwh and one 800 pulse/kwh.
                                        thanks in advance!
                                        • M Offline
                                          M Offline
                                          marten
                                          Arduino: 1.6.5 (Windows 7), Board:"Arduino Nano, ATmega328"
                                          sketch_oct03e:128: error: 'V_TEXT' was not declared in this scope
                                          sketch_oct03e.ino: In function 'void setup()':
                                          sketch_oct03e:162: error: 'S_INFO' was not declared in this scope
                                          sketch_oct03e.ino: In function 'void loop()':
                                          sketch_oct03e:337: error: 'V_TEXT' was not declared in this scope
                                          sketch_oct03e.ino: In function 'void incomingMessage(const MyMessage&)':
                                          sketch_oct03e:364: error: 'V_TEXT' was not declared in this scope
                                          Dit rapport zou meer informatie hebben met
                                          "Tijdens de compilatie uitgebreide uitvoer weergeven"
                                          ingeschakeld in Bestand > Voorkeuren.
                                          M A 2 Replies Last reply
                                          12.1k
