  3. Power/ Usage sensor - multi channel - local display
41 Posts 6 Posters 24.8k Views 7 Watching
  • M MarkV
    @AWI
    I´m using a LAN GW, i disconnected the serial and made the LAN one of it.
    Mmm, the comms error is strange, they're at max one meter apart, with a tiny plaster wall in between, both also got a cap between vcc and gnd.
    Next weekend i´m going to have a look at the slave input, rather strange that it doesn´t receives pulses.
    I connected the 5volt line to all the 6 pulse meters and connected their output to D2 - D8, through a cord of network cable.
    Thanks for all your help so far!!!!!
    AWIA
    AWIA
    AWI
    @MarkV just one tip for today... You should connect the common ground to the pulse meters. The inputs use a pull-up to vcc..
      MarkV
      Dawm maybe thats the problem..
      I connected the 5v as commen to the pulse + and the - to the digital inputs.
      So to be sure i need to connect the pulse + to the digitale inputs and the pulse - to gnd????
      AWIA 1 Reply Last reply
      • M MarkV
        AWIA
        AWIA
        AWI
        @MarkV I would depend on your S0 meters, but normal is "open collector" so you can connect '-' to ground and '+' to the input (= pull-up to Vcc).
        (another way to connect is + to vcc and - to input, but then you need external "pull down" resistors and change the sketch)
          MarkV
          wrote on last edited by MarkV
          Then thats the problem with the slave arduino getting no data. I connected the pulse output like you mentioned second and didn't changed the sketch.
          Maybe i'm home tomorrow then i will give it a try.
          Or is it hard to chsnge the sketch? And what should i change?
          • M MarkV
            AWIA
            AWIA
            AWI
            @MarkV it is indicated in the sketch but you also need external resistors for pull-down. If you disable the internal pull-up resistors the levels are inverted. So you also need to'invert' the measurements or you are measuring the pulse width instead of the time between pulses.
              MarkV
              Tonight i checked the wires and changed them and i believe your wright, the output is:
              But it keeps giving a error, so i hangt them near each other with approx. 10cm space in between, why does it stil say fail after a good startup with ok and after 10a20sec it starts saying fail..
              Is the readout correct?
              And what more could cause the fail error?
              • M MarkV
                AWIA
                AWIA
                AWI
                @MarkV In most of the cases "fail" is related to the power supply of the radio. Did you follow the instructions for connection of the radio?
                • AWIA AWI
                  the code for the measurement device::
                  // Arduino Pulse Counting Sketch for counting pulses from up to 12 pulse output meters.
                  // uses direct port manipulation to read from each register of 6 digital inputs simultaneously
                  // Licence: GNU GPL
                  // part of the openenergymonitor.org project
                  // Author: Trystan Lea
                  // AWI: adapted to produce JSON and error checking at client side.
                  // Pulse Counting Class - could be placed in seperate library...
                  class PulseOutput
                  public:                                 		 //AWI: access to all
                    boolean pulse(int,int,unsigned long);                  //Detects pulses, in pulseLib.ino
                    unsigned long rate( unsigned long );                   //Calculates rate
                    unsigned long count;                                   //pulse count accumulator
                    unsigned long countAccum;                              //pulse count total accumulator for extended error checking (only resets at startup)
                    unsigned long prate;                                   //pulse width in time
                    unsigned long prateAccum;                              //pulse rate accumulator for calculating mean.
                  private:
                    boolean ld,d;                                          //used to determine pulse edge
                    unsigned long lastTime,time;                           //used to calculate rate
                  // Variable declaration
                  //CHANGE THIS TO VARY RATE AT WHICH PULSE COUNTING ARDUINO SPITS OUT PULSE COUNT+RATE DATA
                  //time in seconds;
                  const unsigned long printTime = 1000000;	// delay between serial outputs in us (one meter at a time)
                  const int lastMeter = 7 ; 	 	// is number of meters + 1
                  byte curMeter = 2 ;				// current meter for serial output, wraps from 2 to lastMeter
                  PulseOutput p[14];            //Pulse output objects
                  int a,b,la,lb;                //Input register variables
                  unsigned long ltime, time;    //time variables
                   // take care: pull-up inverses state! line 155
                  	//setup input pins here with pull_up, else (default) float
                  	pinMode( 2, INPUT_PULLUP);
                  	pinMode( 3, INPUT_PULLUP);
                  	pinMode( 4, INPUT_PULLUP);
                  	pinMode( 5, INPUT_PULLUP);
                  	pinMode( 6, INPUT_PULLUP);
                  	pinMode( 7, INPUT_PULLUP);
                  	pinMode( 8, INPUT_PULLUP);
                  	pinMode( 9, INPUT_PULLUP);
                  	pinMode(10, INPUT_PULLUP);
                  	pinMode(11, INPUT_PULLUP);
                  	pinMode(12, INPUT_PULLUP);
                  	pinMode(13, INPUT_PULLUP);
                    Serial.begin(115200);       //standard serial
                    DDRD = DDRD | B00000000;
                    DDRB = DDRD | B00000000;
                    la = a;                    //last register a used to detect input change
                    lb = b;                    //last register b used to detect input change
                    // Read from input registers
                    a = PIND >> 2;             //read digital inputs 2 to 7 really fast
                    b = PINB;                  //read digital inputs 8 to 13 really fast
                    time = micros();
                    if (la!=a || lb!=b)
                      // Detect pulses from register A
                      p[2].pulse(0,a,time);                //digital input 2
                      p[3].pulse(1,a,time);                //    ''        3
                      p[4].pulse(2,a,time);                //    ''        etc
                      p[5].pulse(3,a,time);
                      p[6].pulse(4,a,time);
                      p[7].pulse(5,a,time);
                      // Detect pulses from register B
                      p[8].pulse(0,b,time);                //digital input 8
                      p[9].pulse(1,b,time);                //etc
                      p[10].pulse(2,b,time);
                      p[11].pulse(3,b,time);
                      p[12].pulse(4,b,time);
                      p[13].pulse(5,b,time);
                    // Spit out data every printTime sec (time here is in microseconds)
                    // build JSON: for all counters print Count (W), Count Accum(W), Average ms
                    // Format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                    if ((time-ltime)>(printTime))
                      ltime = time;                          	//Print timer
                        Serial.print("{\"m\":");
                        Serial.print(curMeter-1);           	//Print meter number
                        Serial.print(",\"c\":");
                        Serial.print(p[curMeter].count);    	//Print pulse count
                        Serial.print(",\"r\":");
                        Serial.print(p[curMeter].rate(time));	//Print pulse rate
                  	  p[curMeter].countAccum += p[curMeter].count;	//Increment and print count accumulator to allow for error checking at client side;
                  	  Serial.print(",\"cA\":");
                        Serial.print(p[curMeter].countAccum);
                        Serial.println("}");
                        p[curMeter].count = 0;                //Reset count (we just send count increment)
                        p[curMeter].prateAccum = 0;       	//Reset accum so that we can calculate a new average
                  	curMeter++ ;
                  	if (curMeter > lastMeter){				// wrap a around if passed last meter
                  		curMeter = 2;}
                  // library for pulse, originally in separate file
                  //Gets a particular input state from the register binary value
                  // A typical register binary may look like this:
                  // B00100100
                  // in this case if the right most bit is digital pin 0
                  // digital 2 and 5 are high
                  // The method below extracts this from the binary value
                  #define BIT_TST(REG, bit, val)( ( (REG & (1UL << (bit) ) ) == ( (val) << (bit) ) ) )
                  // Method detects a pulse, counts it, finds its rate, Class: PulseOutput
                  boolean PulseOutput::pulse(int pin, int a, unsigned long timeIn)
                     ld = d;                                    //last digital state = digital state
                     if (BIT_TST(a,pin,1)) d = 1; else d = 0;   //Get current digital state from pin number
                     // if (ld==0 && d==1)                      // no internal pull_up if state changed from 0 to 1: internal pull-up inverts state
                  	if (ld==1 && d==0)                         //pull_up f state changed from 0 to 1: internal pull-up inverts state
                       count++;                                 //count the pulse
                       // Rate calculation
                       lastTime = time;
                       time = timeIn ;						// correction to allow for processing
                       prate = (time-lastTime);// - 400;          //rate based on last 2 pulses
        //-190 is an offset that may not be needed...??
                       prateAccum += prate - 2000;                     //accumulate rate for average calculation
                       return 1;
                     return 0;
                  // Method calculates the average rate based on multiple pulses (if there are 2 or more pulses)
                  unsigned long PulseOutput::rate(unsigned long timeIn)
                   if (count > 1)
                     prate = prateAccum / count;                          //Calculate average
                   } else
                   if ((timeIn - lastTime)>(prate*2)) prate = 0;}         //Decrease rate if no pulses are received
        //in the expected time based on the last
        //pulse width.
                   return prate;
                  FotoFieberF
                  FotoFieberF
                  FotoFieber
                  @AWI
                  Your measurement sketch is really nice. There is one line I do not understand.
                  Is this prateAccum needed or couldn't it be left away? What is the meaning of 2000 in this context?
                  Cu,
                  FotoFieber
                  • FotoFieberF FotoFieber
                    @AWI
                    Cu,
                    FotoFieber
                    AWIA
                    AWIA
                    AWI
                    @FotoFieber To be honest .. a left over from some experiments. Just leave it out... you won't notice the difference.
                    • J
                      J
                      jeti
                      wrote on last edited by jeti
                      @AWI thanks again!
                      I am using your sketches with only one S0 Meter (the 2000pulse/kwh one).
                      *One thing i just found out, that as long as the master arduino is connected to the serial port of my pc it is running fine but when its not, it does not send.I have checked the voltage at the radio and it is the same... I also do not have any display or rotary encoder, as I do the visualisation with FHEM.
                      Do you know why this is the case? * -> Voltage was to low... but the secon question remains:
                      Any idea to use differen pulses/kwh S0 meters? for example one 2000pulse/kwh and one 800 pulse/kwh.
                      thanks in advance!
                        marten
                        Arduino: 1.6.5 (Windows 7), Board:"Arduino Nano, ATmega328"
                        sketch_oct03e:128: error: 'V_TEXT' was not declared in this scope
                        sketch_oct03e.ino: In function 'void setup()':
                        sketch_oct03e:162: error: 'S_INFO' was not declared in this scope
                        sketch_oct03e.ino: In function 'void loop()':
                        sketch_oct03e:337: error: 'V_TEXT' was not declared in this scope
                        sketch_oct03e.ino: In function 'void incomingMessage(const MyMessage&)':
                        sketch_oct03e:364: error: 'V_TEXT' was not declared in this scope
                        Dit rapport zou meer informatie hebben met
                        "Tijdens de compilatie uitgebreide uitvoer weergeven"
                        ingeschakeld in Bestand > Voorkeuren.
                        M AWIA 2 Replies Last reply
                        • M marten
                          marten
                          this is what i'll get when trying to upload the master sketch
                          • M marten
                            AWIA
                            AWIA
                            AWI
                            wrote on last edited by AWI
                            #22
                            @marten You need to use the "Development" branch of MySensors until the production version gets updated -or- you can uncomment the lines with "const int ..."
                            // new V_TEXT variable type (development 20150905)
                            //const int V_TEXT = 47 ;
                            // new S_INFO sensor type (development 20150905)
                            //const int S_INFO = 36 ;
                            • J
                              J
                              jeti
                              • J jeti
                                @AWI thanks again!
                                thanks in advance!
                                AWIA
                                AWIA
                                AWI
                                @jeti as mentioned in a previous post..
                                There are a few ways of getting it changed:
                                You can keep/ leave most as it is and when you send/ or display the values divide the pulses by two and double the Watt values in the routines "LCD_local_display" and "sendPowerUpdate"
                                or: make the necessary calculations when the data comes in. This is a little more complicated in routine "storeMeterJSON" but if you understand the logic (including error corrrection) should be not too hard.
                                I don't have the time at this moment to do it for you...
                                J 1 Reply Last reply
                                • AWIA AWI
                                  J
                                  J
                                  jeti
                                  @AWI: :smiley: nevermind I will start workin on it
                                  Thanks again for the great work!
                                  • J jeti
                                    J
                                    J
                                    jeti
                                    #26
                                    was not that much work :smiley:
                                    this is the modified master-sketch from AWI i am starting to use. The changes i made:
                                    -deletion of LCD and rotray part
                                    -deletion of accumulation part
                                    -modified meterType to meter800, meter1000 and meter2000 this reflects meters with 800imp/khw;1000imp/kwh;2000imp/kwh
                                    I am using this with only one meter (2000imp/kwh) for now and works pretty nicly second different meter type is on the way.
                                    As I am a beginner please be gentle with comments :-)
                                    #include <MySensor.h>                   // MySensors network
                                    #include <Time.h>
                                    #include <ArduinoJson.h>                // used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
                                    // Constants & globals
                                    const int NO_METERS = 1 ;               // actual meters used (max 12)
                                    const int NODE_ID = 152 ;                // fixed MySensors node ID
                                    const int JSON_LENGHT = 80 ;            // Maximum json string length
                                    char lastLCD1[21] = "--                  "; // LCD message line
                                    typedef enum meterTypes: int8_t {meter800, meter1000, meter2000} ;             // metertype meter800, meter1000, meter2000;
                                    const char METER_NAMES[NO_METERS][4] = {"PC"} ; // meter names
                                    const meterTypes METER_TYPES[NO_METERS] = {meter2000};
                                    const unsigned long idleTime = 10000 ;  // Delay time for any of the states to return to idle
                                    unsigned long idleTimer ;               // Delay timer for idleTime
                                    union {                                 // used to convert long to bytes for EEPROM storage
                                        long kWhLongInt;
                                        uint8_t kWhLongByte[4];
                                        } kWhLong ;
                                    // Possible states for the state machine.
                                    // Idle: default state, show totals for in/out nett
                                    // Browse: dive into meter details
                                    // Update: update meter value (Wh total)
                                    // Reset: reset day values
                                    enum States: int8_t {IDLE, BROWSE, UPDATE, RST} ;
                                    uint8_t State = IDLE;                   // current state machine state
                                    // meter class, store all relevant meter data (equivalent to struct)
                                    class pulseMeter
                                    public:
                                        long UsageWh;                       // last (current) usage (in W) from pulse counter
                                        long UsageAccumWh;                  // usage accumulator (to keep in sync) from pulse counter
                                        long PowerW;                        // actual power, calculated from pulse "rate"
                                        long DayUsageWh;                    // daily usage for display
                                        meterTypes Type;                    // metertype for addition in totals: meter800, meter1000, meter2000;
                                        char Name[4] ;                      // meter name for display
                                    pulseMeter pulseMeters[NO_METERS] ;     // define power meters
                                    //pulseMeter meter800, meter1000, meter2000; //  pulse/kWh
                                    unsigned long tempUsageWh ;             // temporary store while manually updating (state UPDATE)
                                    // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
                                    // example: "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}"
                                    char json[JSON_LENGHT] ;        // Storage for serial JSON string (init for example)
                                    // flags & counters
                                    bool timeReceived = false;              // controller time
                                    bool newDay = false;                    // reset at 00:00:00
                                    unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
                                    int updateMeter = 0;                    // current meter for update
                                    bool updateDisplayFlag = true ;         // indicate that display needs to be updated
                                    int currentMeter = 0;                   // active meter for update & check, cycles through meters (0..NO_METERS-1)
                                    int lastRotary = 0;                     // last rotary encoder position
                                    int updateIncrement = 1000 ;            // Interval multiplier for Update
                                    int errCount = 0 ;                      // error counter
                                    // *** Definition and initialisation
                                    // define the MySensor network
                                    MySensor gw;                            // pins used RFX24(default 9,10)
                                    // Initialize messages for sensor network
                                    MyMessage powerMsg(0,V_WATT);           // message to send power in W
                                    MyMessage usageMsg(0,V_KWH);            // message to send usage in kWH
                                    MyMessage textMsg(0,V_TEXT);            // message to send/receive text
                                    // function to reset the Arduino (jump to 0 address)
                                    void(* resetFunc) (void) = 0;//declare reset function at address 0
                                    void setup(void)
                                        gw.begin(incomingMessage, NODE_ID, false);              // this node is fixed, no repeat
                                        //Send the sensor node sketch version information to the gateway
                                        gw.sendSketchInfo("AWI-12ChannelPulse", "2.0");
                                        // Initialize the meter names
                                        // Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
                                        for (int x = 0; x < NO_METERS; x++){
                                            gw.present(x, S_POWER, METER_NAMES[x]);             // present power meters to gateway
                                            delay(10);                                          // give it some time to process
                                        delay(100);
                                        for (int x = 0; x < NO_METERS; x++){                    // initialize previous kWh values from EEPROM and init
                                            for (int y = 0; y < 4 ; y++){                       // convert from bytes
                                                kWhLong.kWhLongByte[y]= gw.loadState(x *4 + y) ;// EEPROM position = meter number * 4 bytes
                                                }                                               // controller is updated later automatically
                                            pulseMeters[x].UsageWh = kWhLong.kWhLongInt;
                                            strcpy(pulseMeters[x].Name, METER_NAMES[x] );       // copy string for meter names
                                            pulseMeters[x].Type = METER_TYPES[x];               // Set type
                                    void loop(void)
                                        // Before specific states, perform generic tasks
                                        unsigned long now = millis();                           // Timer in loop for "once in a while" events
                                        gw.process() ;                                          // process incoming messages
                                        // If no time has been received yet, request it every 10 second from controller
                                        if ((!timeReceived && (now-lastRequest > 10*1000)) ||
                                            (now-lastRequest > 3600000UL)){                     // request update every hour to keep in sync
                                            Serial.println(F("requesting time"));               // Request time from controller.
                                            gw.requestTime(receiveTime);
                                            lastRequest = now;
                                        // Check if new day has started (hour == 0) and reset day usage counters of meters
                                        if (hour()==0 && !newDay){
                                            newDay = true;
                                                pulseMeters[x].DayUsageWh = 0 ;                 // reset daily counters
                                                saveMeters(x);                                  // save meter values to EEPROM
                                        } else if(hour() != 0 && newDay)                        // reset newday flag if hour != 0
                                            { newDay = false;}
                                        // Every 10 seconds update one meter to controller to avoid traffic jams
                                        if (now-lastSyncKWH > 10000){
                                        //    printPulsemeter(updateMeter);
                                            sendPowerUpdate(updateMeter);                               // update the values for currentMeter
                                            updateMeter++ ;
                                            if (updateMeter >= NO_METERS){                              // increment and wrap current meter
                                                updateMeter = 0 ;}
                                            lastSyncKWH = now ;
                                        // Update sensors every 10 secs
                                        if (now-lastUpdate > 10000) {
                                            // get values to be displayed from controller
                                            lastUpdate = now;
                                        // get readings from serial (sent every 10s)
                                        // format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                                        // use JSON parser to process (could be replaced by simple split routine, but this works just fine)
                                        if(readLineJSON(Serial.read(), json, JSON_LENGHT) > 0 ){        //dummySerial(), Serial.read()
                                        // if(readLineJSON(dummySerial(), json, 80) > 0 ){              //dummySerial(), Serial.read()
                                            Serial.println(json);
                                            storeMeterJSON(json);                                       //store the meter reading
                                            //calcMeterTotals();                                          // update totals
                                        // Ok, set incoming time
                                        Serial.print(F("Time value received: "));
                                        setTime(controllerTime);                                        // set the clock to the time from controller
                                        timeReceived = true ;
                                    // This is called when a message is received
                                      // Expect few types of messages from controller, V_VAR1 for messages
                                        if (message.type==V_TEXT) {
                                            // if message comes in, update the kWH reading for meter with value since last update
                                            //Serial.print("Last reading for sensor: ");
                                            //Serial.print(message.sensor);
                                            //Serial.print(", Message: ");
                                            //Serial.println(message.getString());
                                    // save Meter to EEPROM when needed
                                    void saveMeters(int8_t meterNo){
                                        kWhLong.kWhLongInt = pulseMeters[meterNo].UsageWh ;                     // convert to separate bytes via struct
                                            gw.saveState(meterNo * 4 + y, kWhLong.kWhLongByte[y])  ;            // EEPROM position = meter number * 4 bytes
                                    void sendPowerUpdate(int meterNo)
                                    // Sends update to controller for current meter
                                        gw.send(powerMsg.setSensor(meterNo).set((long)pulseMeters[meterNo].PowerW));            // meterNo * 100 ));
                                        gw.send(usageMsg.setSensor(meterNo).set((float)pulseMeters[meterNo].UsageWh/1000L ,3)); // send in kWh!
                                    int storeMeterJSON(char *json)
                                    /* convert JSON to values and store in corresponding meter (if used)
                                     input: JSON string (can be wrong formatted), with length
                                     output: changed meter record number or -1 if error
                                     use JsonParser
                                      StaticJsonBuffer<50> jsonBuffer;                          // 4 object  -> 4 + 4*10 = 44
                                      // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
                                        JsonObject& root = jsonBuffer.parseObject(json);
                                      if (!root.success())
                                            Serial.println(F("JsonParser.parse() failed"));
                                            errCount++ ;
                                            return -1;
                                      int m = (long)root["m"];
                                      if (m > NO_METERS){                                       // meter value out of range for used meters (m starts at 1)
                                        return -1 ;
                                      } else {                                                  // update meter values, Power is momentary, Usage is cumulative
                                        long newAccumWh = (long)root["cA"] ;
                                        long newWh = (long)root["c"] ;
                                        long diffAccumWh = newAccumWh - pulseMeters[m-1].UsageAccumWh;  // check for missed pulses by comparing cA with last stored value
                                        if (diffAccumWh >= newWh){                              // no difference or missed pulses -> correct: add difference
                                            pulseMeters[m-1].UsageWh += diffAccumWh;
                                            pulseMeters[m-1].DayUsageWh += diffAccumWh;
                                        else {                                                  // negative diff, out of sync -> add pulses only (can be out of range or restart)
                                            pulseMeters[m-1].UsageWh += newWh;
                                            pulseMeters[m-1].DayUsageWh += newWh;
                                        pulseMeters[m-1].UsageAccumWh = newAccumWh;             // always update sync counter (only for sync and error correction(serial))
                                        if ((long)root["r"] == 0){                              // calculate power from pulse rate (ms) and truncate to whole Watts
                                          pulseMeters[m-1].PowerW = 0;                          // if overflow assume no Usage
                                        } else if (pulseMeters[m-1].Type == meter800){
                                          pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]*0.8); // rate in microseconds for 800 pulse/kWh
                                          else if (pulseMeters[m-1].Type == meter1000){
                                          pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]); // rate in microseconds for 1000 pulse/kWh
                                           else if (pulseMeters[m-1].Type == meter2000){
                                           pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]/2); // rate in microseconds for 2000 pulse/kWh
                                          else {
                                            Serial.println("geht nicht");
                                        return m ;
                                    int readLineJSON(int readch, char *buffer, int len)
                                    /* checks for JSON and when started append char tot buffer and checks for line completion
                                    usage:
                                      static char buffer[80];
                                      if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
                                      returns simple JSON
                                      static int pos = 0;
                                      int rpos;
                                      if (readch > 0) {
                                        switch (readch) {
                                          case '\n':                // Ignore new-lines
                                          case '\r':                // Return on CR
                                            rpos = pos;
                                            pos = 0;                  // Reset position index ready for next time
                                            return rpos;
                                          default:
                                            if (pos < len-1) {
                                              buffer[pos++] = readch;
                                              buffer[pos] = 0;
                                      // No end of line has been found, so return -1.
                                      return -1;
                                    int dummySerial()
                                    // Acts as a dummy JSON serial character generator for debugging
                                    // input: none
                                    // output: preset JSON string
                                      static int pos = 0;
                                      char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
                                      if (pos++ >= strlen(json)){
                                        pos = 0;
                                      return json[pos] ;
                                    void printPulsemeter(int meter)
                                    // prints the Pulsemeter record to serial out
                                      Serial.print("m:");
                                      Serial.print(meter);
                                      Serial.print("type:");
                                      Serial.print(pulseMeters[meter].Type);
                                      Serial.print(", power: ");
                                      Serial.print(pulseMeters[meter].PowerW);
                                      Serial.print(", usage: ");
                                      Serial.print(pulseMeters[meter].UsageWh);
                                      Serial.print(", day usage: ");
                                      Serial.println(pulseMeters[meter].DayUsageWh );
                                    //  Serial.print(", Ca: ");
                                    //  Serial.println(pulseMeters[meter].UsageAccumWh);
                                      MarkV
                                      Good evening,
                                      After a couple of weeks, again i'm busy with my arduino's, but now i have a rasberry with domoticz near my arduino, so i don't need to send it wireless.
                                      Is there a possibility to connect the master or slave arduino directly to my rasberry and read out the pulse meters???
                                      • mfalkviddM
                                        With MySensors version 1.6 (currently in development) you can connect the Arduino to the Raspberry Pi's USB port using a FTDI or CH340G. That type of connection is called a serial gateway. Before 1.6, the gateways do not support local sensors.
                                          MarkV
                                          #29
                                          So with 1.6 i can install the master software and connect my arduino master directly through usb without the rf24''s? ?
