  3. cc1101 rf433mhz with mysensors
3 Posts 3 Posters 3.5k Views 2 Watching
  • B
    B
    betonishard
    Hello all,
    First of all great project, I have been using mysensors for a year now and collected quite a nice rig.. So may thanks to this project.
    I have a question, recently I purchased a cc1101 transceiver to use with mysensors. However I cannot seem to make it work as a node (to use with RCswitch library). I would like to know if there is someone already tried this or is using this. I don't want to use it as a gateway, just as a node to collect data from my cheap 433mhz door/window contacts. I hope someone can push me into the right direction.
    Regards
    • E
      E
      ericvdb
      I don't think the RCSwitch library is compatible with the CC1101. It uses the dirt cheap RF TX/RX modules that require just 1 pin each, while the CC1101 uses SPI. That also implies you will need to use SoftSPI on your sensor node.
      • I
        I
        insomnia
        Maybe you van use this http://blog.gummibaer-tech.de/cul-stick-868433-im-selbstbau/
        I have buildthis one also and use it in fhem (www.fhem.de)
