  3. Connecting a sensor to pc with usb
3 Posts 2 Posters 1.4k Views 1 Watching
  • B
    B
    benno
    Just build my first sensor (temperature) ...
    Can I test it without building the gateway? ie using usb and a pc?
    THX :)
    luca
    • L
      L
      LastSamurai
      Yes you can. Enable debugging (should be default I think) and/or add some output lines in your code and get a usb to serial converter. Connect that one the the RX/TX/GND pins on your sensor and to the usb port of your pc. Or just use something like an arduino uno for your first tests.
      • B
        B
        benno
        I'll try it, thx!
        luca
