  3. Multiple Binary Switch Help
3 Posts 2 Posters 2.0k Views 1 Watching
  • P
    P
    punter9
    Hey all I am learning here and running into some issues. I have 3 binary switches I would like to have read for me. I have written code and they all show up as I would like. The issues I am having is only pin D5 seems to do anything and it turns ON/OFF all 3 switches. Any help as to why this is would really be appreciated.
    #include <Bounce2.h>
    #define CHILD_ID1 3
    #define BUTTON_PIN1  3  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID2 4
    #define BUTTON_PIN2  4  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID3 5
    #define BUTTON_PIN3  5  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
    MyMessage msg1(CHILD_ID1,V_TRIPPED), msg2(CHILD_ID2,V_TRIPPED),msg3(CHILD_ID3,V_TRIPPED);
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN1,INPUT);
      pinMode(BUTTON_PIN2,INPUT);
      pinMode(BUTTON_PIN3,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN1,HIGH);
      digitalWrite(BUTTON_PIN2,HIGH);
      digitalWrite(BUTTON_PIN3,HIGH);
      debouncer.attach(BUTTON_PIN1);
      debouncer.interval(5);
      debouncer.attach(BUTTON_PIN2);
      debouncer.attach(BUTTON_PIN3);
      gw.present(CHILD_ID1, S_DOOR);
      gw.present(CHILD_ID2, S_DOOR);
      gw.present(CHILD_ID3, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msg1.set(value==HIGH ? 1 : 0));
         gw.send(msg2.set(value==HIGH ? 1 : 0));
         gw.send(msg3.set(value==HIGH ? 1 : 0));
         oldValue = value;
    TheoLT 1 Reply Last reply
    • P
      P
      punter9
      did this, works! on to adding a couple soil moisture sensors and a relay
       * Simple binary switch example
       * Connect button or door/window reed switch between
       * digitial I/O pin 3 (BUTTON_PIN below) and GND.
       * http://www.mysensors.org/build/binary
      #define CHILD_ID1 3
      #define CHILD_ID2 4
      #define CHILD_ID3 5
      int oldValue1=-1;
      int oldValue2=-1;
      int oldValue3=-1;
        gw.begin();
       // Setup the button
        debouncer.update();
        int value1 = debouncer.read();
        int value2 = debouncer.read();
        int value3 = debouncer.read();
        value1 = digitalRead(BUTTON_PIN1);
        value2 = digitalRead(BUTTON_PIN2);
        value3 = digitalRead(BUTTON_PIN3);
        if (value1 != oldValue1) {
           gw.send(msg1.set(value1==HIGH ? 1 : 0));
           oldValue1 = value1;
        if (value2 != oldValue2) {
           gw.send(msg2.set(value2==HIGH ? 1 : 0));
           oldValue2 = value2;
        if (value3 != oldValue3) {
           gw.send(msg3.set(value3==HIGH ? 1 : 0));
           oldValue3 = value3;
      • P punter9
        #define CHILD_ID1 3
        #define CHILD_ID2 4
        #define CHILD_ID3 5
        int oldValue=-1;
          gw.begin();
         // Setup the button
          debouncer.update();
             oldValue = value;
        TheoLT
        TheoLT
        TheoL
        @punter9 You have to create a Debouncer for each switch. A debouncer will only debounce the assigned switch. Besides you have to check each switch separately. I adjusted your Sketch. It compiles but I haven't tested it. All of my breadboards are full with test circuits at the moment.
        Give this a try
        #define CHILD_ID1 3
        #define CHILD_ID2 4
        #define CHILD_ID3 5
        Bounce debouncer1 = Bounce();
        Bounce debouncer2 = Bounce(); // debouncer for the second switch
        Bounce debouncer3 = Bounce(); // debouncer for the third switch
        int oldValue1=-1;
        int oldValue2=-1; // second switch needs to have it's own old state
        int oldValue3=-1; // second switch needs to have it's own old state
          gw.begin();
         // Setup the button
          pinMode(BUTTON_PIN1,INPUT_PULLUP ); // You can assign pinmode and use pullup in one statement.
          pinMode(BUTTON_PIN2,INPUT_PULLUP);
          pinMode(BUTTON_PIN3,INPUT_PULLUP);
         // digitalWrite(BUTTON_PIN1,HIGH);
        //  digitalWrite(BUTTON_PIN2,HIGH);
        //  digitalWrite(BUTTON_PIN3,HIGH);
          // After setting up the button, setup debouncer1
          debouncer1.attach(BUTTON_PIN1);
          debouncer1.interval(5);
          debouncer2.attach(BUTTON_PIN2);
          debouncer2.interval(5);
          debouncer3.attach(BUTTON_PIN3);
          debouncer3.interval(5);
          // Check if the first switch state has changed
          debouncer1.update();
          int value = debouncer1.read();
          if (value != oldValue1) {
        //     gw.send(msg2.set(value==HIGH ? 1 : 0)); // this is where you turn the second switch in your controller
        //     gw.send(msg3.set(value==HIGH ? 1 : 0));  // this is where you turn the third switch in your controller
             oldValue1 = value;
          // Check if the 2nd switch state has changed
          debouncer2.update();
          value = debouncer2.read(); // no need to redeclare it (I removed int)
          if (value != oldValue2) {
        //     gw.send(msg1.set(value==HIGH ? 1 : 0));
             oldValue2 = value;
          // Check if the third switch state has changed
          debouncer3.update();
          value = debouncer3.read(); // no need to redeclare it (I removed int)
          if (value != oldValue3) {
             oldValue3 = value;
