  3. Button Actuated relay with Motion
2 Posts 2 Posters 1.9k Views 3 Watching
  • DrJeffD
    DrJeffD
    DrJeff
    I'm trying to make a Relay with a Switch and Motion. Here is my sketch it works from the controler fine (Vera). The problem if I make changes at the switch the controller does not update. Also I can not get the motion to work. I put the motion inside of a void section. I also tried the motion code inside of the loop also. Any help?
    // Example sketch för a "light switch" where you can control light or something
    // else from both vera and a local physical button (connected between digital
    // pin 4 and GND).
    // This node also works as a repeater for other nodes
    // Added Motion detection
    // Modified by DrJeff On 10/18/15
    #include <Bounce2.h>
    #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
    #define LIGHT_CHILD_ID 1   // Id of the sensor child
    #define RELAY_ON 0
    #define RELAY_OFF 1
    #define MOTION_SENSOR 5   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define INTERRUPT MOTION_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define MOTION_LIGHT_CHILD_ID 2   // Id of the sensor child
    #define NODE_ID 4
    uint8_t lastMotion = 0;
    unsigned long previousMillis = 0; // last time update //see http://stackoverflow.com/questions/10773425/performing-a-function-after-x-time for more details on this
    unsigned long motionDelay = 10000; // interval at which to keep motion sensor trippped (milliseconds).  Used to prevent too frequent updates to Vera.
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    MyMessage msgLIGHT(LIGHT_CHILD_ID,V_LIGHT);
    MyMessage msgMOTION(MOTION_LIGHT_CHILD_ID, V_TRIPPED);
      gw.begin(incomingMessage, NODE_ID, true);
      gw.sendSketchInfo("Relay, Motion, & Button", "1.1");
      //Motion
     pinMode(MOTION_SENSOR, INPUT);      // sets the motion sensor digital pin as input
      gw.present(MOTION_LIGHT_CHILD_ID, S_MOTION);
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(LIGHT_CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(LIGHT_CHILD_ID);
      gw.process();
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          gw.send(msgLIGHT.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
     void MotionStatus (){
       // Read digital motion value
         if(currentMillis - previousMillis > motionDelay){
          uint8_t motionDetect = digitalRead(MOTION_SENSOR);
      if(motionDetect != lastMotion){
      gw.send(msgMOTION.set(motionDetect?"1":"0"));
      if(motionDetect == 1){
        previousMillis = currentMillis;
      else{
        previousMillis = currentMillis - motionDelay + 1000;
      lastMotion = motionDetect;
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(LIGHT_CHILD_ID, state);
         // Write some debug info
         Serial.print(message.sensor);
    I'm sure I'm doing something wrong just not sure what and were. Thanks for the help.
    • TheoLT
      TheoLT
      TheoL
      Maybe this will help you a bit http://forum.mysensors.org/topic/2106/reinventing-the-motion-controlled-outside-lamp
