  3. MyController.org
  4. Change Time format
Change Time format
Scheduled Pinned Locked Moved MyController.org
5 Posts 2 Posters 2.3k Views 1 Watching
  • S Offline
    supagusti
    Is it possible to change the time format to 24 hours?
    I get 12 hours (AM/PM) time in the Graphical Report and would rather see 24hours.
    Using a RPi /w debian install and MyController 0.0.2 alpha5
    Thanks in advance,
    Thomas
    J 1 Reply Last reply
    • S supagusti
      Thanks in advance,
      Thomas
      J Offline
      J Offline
      jkandasa
      Thanks in advance,
      Thomas
      @supagusti Yes, 0.0.2-alpha5 changed to 12 hours format. Some people wants to see in 12 hours. Ok, I will add this 12 or 24 hours format in to users hand. I will add an entry in system settings.
      Created a feature request to track this. Kindly update your thoughts if you have any additional opinion on this.
      https://github.com/mycontroller-org/mycontroller/issues/46
      for now the workaround is to replace the attached file (charts.js) with your mycontroller/www/controllers/charts.js
      • S Offline
        supagusti
        @jkandasa This works fine now - Thank you.
        If it's not a big problem, I would add the the entry to user settings, so every user can decide which format to use.
        • S supagusti
          J Offline
          J Offline
          jkandasa
          Your contributions are most welcome!! We have a ticket to track this https://github.com/mycontroller-org/mycontroller/issues/46 Kindly update there.
          • J Offline
            J Offline
            jkandasa
            @supagusti Your request has been implemented. Changes will be available in 0.0.2-alpha6 release. Thank you!
