  3. Relay actuator + water meter pulse sensor sketch
7 Posts 4 Posters 4.7k Views 5 Watching
  • N
    N
    niccodemi
    I would like to combine relay actuator and water meter pulse sensor sketch . I merged the code from original examples, I can upload sketch but something must be wrong because only one device gets created in Vera. Gateway is version 1.5 and arduino 1.6.5
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define DIGITAL_INPUT_SENSOR 5                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
    #define SENSOR_INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
    #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
    #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
    #define CHILD_ID 1                              // Id of the sensor child
    unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
    MyMessage flowMsg(CHILD_ID,V_FLOW);
    MyMessage volumeMsg(CHILD_ID,V_VOLUME);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
    MyHwATMega328 hw;
    double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
    volatile double flow = 0;
    boolean pcReceived = false;
    unsigned long newBlink = 0;
    double oldflow = 0;
    double volume =0;
    double oldvolume =0;
    unsigned long lastSend =0;
    unsigned long lastPulse =0;
     gw.begin(incomingMessage);
     // initialize our digital pins internal pullup resistor so one pulse switches from high to low (less distortion)
     pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
     gw.sendSketchInfo("Watermeter-Relay", "1.0");
     // Register this device as Waterflow sensor
     gw.present(CHILD_ID, S_WATER);
     pulseCount = oldPulseCount = 0;
     gw.request(CHILD_ID, V_VAR1);
     lastSend = lastPulse = millis();
     attachInterrupt(SENSOR_INTERRUPT, onPulse, FALLING);
     // Fetch relay status
       gw.present(sensor, S_LIGHT);
       pinMode(pin, OUTPUT);
       digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
     gw.process();
     unsigned long currentTime = millis();
     if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY))
       lastSend=currentTime;
       if (!pcReceived) {
         //Last Pulsecount not yet received from controller, request it again
         return;
       if (!SLEEP_MODE && flow != oldflow) {
         oldflow = flow;
         Serial.print("l/min:");
         Serial.println(flow);
         // Check that we dont get unresonable large flow value.
         // could hapen when long wraps or false interrupt triggered
         if (flow<((unsigned long)MAX_FLOW)) {
           gw.send(flowMsg.set(flow, 2));                   // Send flow value to gw
       // No Pulse count received in 2min
       if(currentTime - lastPulse > 120000){
         flow = 0;
       // Pulse count has changed
       if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
         oldPulseCount = pulseCount;
         Serial.print("pulsecount:");
         Serial.println(pulseCount);
         gw.send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
         double volume = ((double)pulseCount/((double)PULSE_FACTOR));
         if ((volume != oldvolume)||(!SLEEP_MODE)) {
           oldvolume = volume;
           Serial.print("volume:");
           Serial.println(volume, 3);
           gw.send(volumeMsg.set(volume, 3));               // Send volume value to gw
     if (SLEEP_MODE) {
       gw.sleep(SEND_FREQUENCY);
     if (message.type==V_VAR1) {
       unsigned long gwPulseCount=message.getULong();
       pulseCount += gwPulseCount;
       flow=oldflow=0;
       pcReceived = true;
     if (message.type==V_LIGHT) {
        // Change relay state
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
    void onPulse()
     if (!SLEEP_MODE)
       unsigned long interval = newBlink-lastBlink;
       if (interval!=0)
         if (interval<500000L) {
           // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
           return;
         flow = (60000000.0 /interval) / ppl;
       lastBlink = newBlink;
     pulseCount++;
    SparkmanS 1 Reply Last reply
    • N niccodemi
      MyHwATMega328 hw;
      double oldflow = 0;
      double volume =0;
       gw.process();
         if (!pcReceived) {
           return;
           oldflow = flow;
           flow = 0;
             oldvolume = volume;
       if (SLEEP_MODE) {
         flow=oldflow=0;
         pcReceived = true;
      void onPulse()
       if (!SLEEP_MODE)
         if (interval!=0)
             return;
       pulseCount++;
      SparkmanS
      SparkmanS
      Sparkman
      @niccodemi Looks like you are using 1 as the child id for both. It probably easiest to change the child id of the pulse sensor to 10 or something like that in case you add more relays in the future.
      Cheers
      Al
      • T
        tbully
        I built an identical sketch. (Control a valve if water is flowing and shouldn't be - busted pipe, stuck sprinkler, etc)
        I'm posting to remind myself to send you my sketch when I have access to my IDE at home.
        • T
          tbully
          Here's my code in case you're interested:
          // Use this sensor to measure volume and flow of your house watermeter.
          // You need to set the correct pulsefactor of your meter (pulses per m3).
          // The sensor starts by fetching current volume reading from gateway (VAR 1).
          // Reports both volume and flow back to gateway.
          // Unfortunately millis() won't increment when the Arduino is in
          // sleepmode. So we cannot make this sensor sleep if we also want
          // to calculate/report flow.
          // Sensor on pin 3
          #define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
          //#define PULSE_FACTOR 12500                       // Nummber of blinks per m3 of your meter (One rotation/liter)
          #define PULSE_FACTOR 288000
          #define MAX_FLOW 25                             // Max flow (l/min) value to report. This filetrs outliers.
          #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
          #define CHILD_ID 0                              // Id of the sensor child
          #define RELAY_1  4  // Arduino Digital I/O pin number for first relay
          #define RELAY_ON 1
          #define RELAY_OFF 0
          unsigned long SEND_FREQUENCY = 10000;              // Minimum time between send (in miliseconds). We don't want to spam the gateway.
          double oldflow = 0;
          double volume;
          double oldvolume;
          unsigned long lastSend;
          unsigned long lastPulse;
          unsigned long currentTime;
          boolean metric;
            //gw.begin(incomingMessage, AUTO, true);
            //gw.begin(incomingMessage, AUTO, false, AUTO, RF24_PA_LOW);
            gw.begin(incomingMessage, AUTO, false, AUTO);
            //  gw.send(pcMsg.set(0));
            //  gw.send(volumeMsg.set(0.000, 3));
            //Water meter setup
            //Serial.print("PPL:");
            //Serial.print(ppl);
            gw.sendSketchInfo("Water Meter and Valve", "1.0");
            //pulseCount = oldPulseCount = 0;
            //Serial.print("Last pulse count from gw:");
            //Serial.println(pulseCount);
            attachInterrupt(INTERRUPT, onPulse, RISING);
            lastSend = millis();
            //RELAY SETUP
            gw.process();
            bool sendTime = currentTime - lastSend > SEND_FREQUENCY;
            if (pcReceived && (SLEEP_MODE || sendTime)) {
              // New flow value has been calculated
                //Serial.print("g/min:");
                // Serial.println(flow);
                oldflow = flow;
              // No Pulse count in 2min
              if(currentTime - lastPulse > 20000){
                flow = 0;
              if (pulseCount != oldPulseCount) {
                gw.send(pcMsg.set(pulseCount));                  // Send  volumevalue to gw VAR1
                double volume = ((double)pulseCount/((double)PULSE_FACTOR)*264.172);
                //double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                if (volume != oldvolume) {
                  oldvolume = volume;
              lastSend = currentTime;
            else if (sendTime) {
              // No count received. Try requesting it again
            if (SLEEP_MODE) {
          void onPulse()
            if (!SLEEP_MODE) {
              if (interval < 2080) {       // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)  WAS 2080
                return;
              flow = ((60000000.0 /interval) / ppl)*.264172;
              //flow = ((60000000.0 /interval) / ppl);
              // Serial.print("interval:");
              // Serial.println(interval);
              // Serial.println(flow, 4);
            pulseCount++;
              pcReceived = true;
          N 1 Reply Last reply
          • T tbully
            // Sensor on pin 3
            #define RELAY_ON 1
            #define RELAY_OFF 0
            double oldflow = 0;
            double volume;
            double oldvolume;
            boolean metric;
              //Water meter setup
              //RELAY SETUP
              gw.process();
                  oldflow = flow;
                  flow = 0;
                    oldvolume = volume;
              if (SLEEP_MODE) {
            void onPulse()
              if (!SLEEP_MODE) {
                  return;
              pulseCount++;
                pcReceived = true;
            N
            N
            niccodemi
            @tbully thanks, just what I was looking for.
            • T
              thumper
              @tbully thank you for the code, can you hardware you are using. What are you using to monitor the flow of your pipes (flow meter or pulse monitor). Thanks in advance and sorry if you already mentioned this elsewhere.
              • T
                tbully
                Hey there. Sorry for the delay. I never get notifications on this board for some reason.
                I'm using one of these:
                http://www.amazon.com/dp/B00EVKVM02/ref=pe_385040_30332190_TE_3p_dp_1
                And one of these for my sprinkler 3/4 line:
                http://www.amazon.com/dp/B00EVKOK6A/ref=pe_385040_30332190_TE_3p_dp_2
                http://www.amazon.com/gp/product/B009YVCMX4?psc=1&redirect=true&ref_=oh_aui_search_detailpage
                I couldn't find the 1" valve to go with the sensor but you get the idea. I'm just switching those with normal relays tied to the appropriate pins.
                Funny you should ask about this, however. I'm actually not overly thrilled with the flow sensors (especially the 1" model). It doesn't seem to detect low flow rates. Either my sketch isn't sensitive enough (maybe my debounce is screwed up) or it doesn't pulse for lower speeds.
                I'm considering another type of flow meter but 1) haven't found one yet 2) not looking forward to re-plumbing everything.
