  3. Help with scetch relaywithbutton
3 Posts 2 Posters 1.5k Views 2 Watching
  • X
    X
    xypzo
    Hi, I am trying to have a double relay switching using FHEM controller.
    I took the code of scetch RelayWithButton and modified it for 2 relays.
    When I switch in FHEM, it will always switch both relays at the same time.
    I am a copy-pasting extreme code NOOB, so please be gentle!
    Thanks in advance
    xypzo
    #include <Bounce2.h>
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define RELAY1_PIN  3  // Arduino Digital I/O pin number for relay 1
    #define RELAY2_PIN  4  // Arduino Digital I/O pin number for relay 2
    #define BUTTON_PIN  7  // Arduino Digital I/O pin number for button
    #define CHILD_ID_R 1   // Id of the sensor child R1
    #define CHILD_ID_R2 2   // Id of the sensor child R2
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    MyMessage msg1(CHILD_ID_R, V_LIGHT);
    MyMessage msg2(CHILD_ID_R2, V_LIGHT);
      gw.sendSketchInfo("Relays & Button", "0.1");
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID_R, S_LIGHT);
      gw.present(CHILD_ID_R2, S_LIGHT);
      digitalWrite(RELAY1_PIN, RELAY_OFF);
      digitalWrite(RELAY2_PIN, RELAY_OFF);
      pinMode(RELAY1_PIN, OUTPUT);
      pinMode(RELAY2_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID_R);
      digitalWrite(RELAY1_PIN, state?RELAY_ON:RELAY_OFF);
      state = gw.loadState(CHILD_ID_R2);
      digitalWrite(RELAY2_PIN, state?RELAY_ON:RELAY_OFF);
      gw.process();
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          gw.send(msg1.set(state?false:true), true); // Send new state and request ack back
          gw.send(msg2.set(state?false:true), true);
      oldValue = value;
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID_R, state);
         gw.saveState(CHILD_ID_R2, state);
         // Write some debug info
         Serial.print(message.sensor);
    SparkmanS 1 Reply Last reply
    • X xypzo
      Thanks in advance
      xypzo
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue=0;
      bool state;
       // Setup the button
        gw.process();
        debouncer.update();
        oldValue = value;
      SparkmanS
      SparkmanS
      Sparkman
      @xypzo In your incoming message function, you need to check the message to see which relay it is for (message.sensor). You're not checking for that and you always switch both relays by issuing these two commands in a row:
      You need something like:
      if (message.sensor == CHILD_ID_R) {
      if (message.sensor == CHILD_ID_R2) {
      Cheers
      Al
      • X
        X
        xypzo
        Wow, thank you so much, it works like a charm!
