  3. I'm new so please forgive my ignorance. HELP
9 Posts 2 Posters 2.4k Views 1 Watching
  • Y Offline
    Y Offline
    youngst123
    I have 2 arduinos with nrf24l01+ radios attached to each arduino. I uploaded the "relay with button" sketches onto each arduino. on arduino1 I have wired a momentary on button to pin 3 through switch to ground. on arduino2 I have a relay attached to pin 4. I have made no changes to code and everything is wired correctly. whenever i push the button on arduino1 the state of arduino2 pin 4 never changes. Am i missing something here? Thank you in advance.
    S 1 Reply Last reply
    • Y youngst123
      Sparkman
      @youngst123 MySensors is designed to work with a gateway and central controller. I believe it's possible for direct sensor node to sensor node communications, but does not work that way by default.
      http://www.mysensors.org/build/select_gateway
      http://www.mysensors.org/controller/
      Cheers
      Al
      Y 1 Reply Last reply
      • Y Offline
        Y Offline
        youngst123
        OK thank you for replying. so for this to work i wound need to purchase some sort of controller like a "middle man"
        • Y youngst123
          Sparkman
          @youngst123 You don't need to purchase one as there are a number of free ones available, but all need some type of hardware to run on. The gateway is simply another Arduino with NRF radio and a sketch specific for it.
          Cheers
          Al
          • S Sparkman
            Cheers
            Al
            Y Offline
            Y Offline
            youngst123
            @Sparkman I think i was supposed to use the reply. Sorry. so for this to work i wound need to purchase some sort of controller like a "middle man"
            • S Sparkman
              Cheers
              Al
              Y Offline
              Y Offline
              youngst123
              @Sparkman ok i have another arduino what sketch do you recommend i use on it?
              • Y youngst123
                Sparkman
                @youngst123 The easiest is the serial gateway sketch: http://www.mysensors.org/build/serial_gateway#upload-the-serialusb-gateway-sketch. For an easy controller to test things with, try MysController: http://www.mysensors.org/controller/myscontroller. You will need a Windows PC for it.
                Cheers
                Al
                • S Sparkman
                  Cheers
                  Al
                  Y Offline
                  Y Offline
                  youngst123
                  @Sparkman ok i think its starting to sink in thanks for your help..
                  • Y youngst123
                    Sparkman
                    @youngst123 No problem. Let us know how you make out.
                    Cheers
                    Al
                    12.1k
