  3. Presentation fails. MAX_RT bit set.
1 Posts 1 Posters 716 Views
  • S Offline
    Steve1
    Hello, I'm new to MySensors and the nrf24l01+. I'm having trouble getting the
    following configuration to work.
    ESP8266 Wifi Gateway:
    MySensors 1.5.1
    NodeMCU devkit 0.9
    Nrf24l01+pa+lna
    decoupling capacitor
    Arduino Sensor Node
    Arduino 1.6.5
    MySensors 1.5.1
    Using BinarySwitchSensor sketch
    Nrf24l01+
    I can telnet to the wifi gateway and I see...
    Trying 10.0.0.22...
    Connected to 10.0.0.22.
    Escape character is '^]'.
    When I start the sensor node, I see it trying to present itself, but something fails.
    send: 108-108-101-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.1
    The returned SPI status is 0x1E, which has the MAX_RT bit set. It appears this is
    what is causing the fail status.
    Other sensor node details:
    STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1	 0xa8a8e1fc6c 0xa8a8e1fc6c
    RX_ADDR_P2-5	 0xff 0xc4 0xc5 0xc6
    TX_ADDR		 = 0xa8a8e1fc65
    RX_PW_P0-6	 0x20 0x20 0x20 0x00 0x00 0x00
    EN_AA		 = 0x3b
    EN_RXADDR	 0x07
    RF_CH		 = 0x4c
    RF_SETUP	 0x07
    CONFIG		 = 0x0e
    DYNPD/FEATURE	 0x3f 0x06
    Data Rate	 = 1MBPS
    Model		 = nRF24L01+
    CRC Length	 = 16 bits
    PA Power	 = PA_MAX
    Any ideas? Is there something I else I can do to diagnose the problem? Thanks!
