  3. #define MY_PARENT_NODE_ID AUTO fails
3 Posts 2 Posters 2.1k Views 2 Watching
  • FotoFieberF
    FotoFieberF
    FotoFieber
    Playing with #define MY_RF24_ENABLE_ENCRYPTION I found a problem with
    It doesn't find a parent. (To reproduce, please clear the EEPROM first.)
    With
    #define MY_PARENT_NODE_ID 0
    it is working.
    It seems to write the parent in the EEPROM and is working after that with the AUTO-setting. If I then clear the EEPROM, it stops working again.
    Is this only a problem with encryption or is this a general problem?
      Encryptions is relatively untested. And you did enable encryption on both gateway and node?
      I can probably make some tests after work tonight.
      • FotoFieberF
        FotoFieberF
        FotoFieber
        Yes, I did enable that.
        My setup:
        • a ) ESP8266 gateway
        • b ) Sensebender Micro
        • c ) Mega2560
        Problem can be reproduced wiith both b and c. It is working with fixed PARENT_NODE_ID.
