MYSBootloader 1.4 testing
@tekka
Hi Tekka, just to understand, the new release of MYSBOOTLOADER you are working on is 1.3 or 1.4?
Are source of one release available, even in beta?I have a setup with ~20 nodes ready to start, but I need an OTA Bootloader, no signing required.
If you already worked on that, it's a pitty to develop my own Bootloader.Thank for all your time spend on that project and hope we can enjoy using your MYSBOOTLOADER
Lorenzo
@Lorenzo 1.3 and 1.4 are variants with different optimizations.I suggest using MYSBootloader 1.1 (MySensorsBootloaderRF24) if you need a bootloader right now.
The source code / and .HEX can be found here: https://github.com/mysensors/MySensorsBootloaderRF24. Adjustments to channel and/or CE/CSN pins require you to recompile the code. -
