  3. Dallas 1W-Sketch- something must be wrong ?
3 Posts 2 Posters 1.5k Views
  • K
    K
    kr0815
    I tried to build another few sensors the last days, with Dallas DS18B20 and battery .
    My old Sketches don´t work anymore because of the V1.5, they always complain about GW_beginn....
    So i tried the new one from here, it never finds a 1W Device. i had this before, when making some test Setups.
    A DHT-22 is working fine, also if i use the original Arduino-Samples for DS18B20, they work as exected
    Is there maybe a fault in the sample script ? Does anybody have a working (under1.5) script for 1Wire+Battery ?
      malarcy
      I have a coupe of 1wire/DS18B20 working under 1.5.1 - can you post your sketch and confirm which pins things are connected to (and if you have the appropriate resistor in place for the DS18B20 ?
      My sketch was pretty much a cut and past from the sample code - so I think that works fine.
      • K
        K
        kr0815
        I tried it with the Dallas 1Wire example from this page here.
        A friend reported the same, didn´t get it to work.
        It´s not the wiring, as it works with other scripts
        I converted my old scripts now to 1.5, it´s working
