  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 182.8k Views 23 Watching
  • S
    Samuel235
    I will upload this device to Openhardware.io as soon as i have it built up and the basic functionality working. Hopefully then it will become much easier for the starting MySensor budding builders to understand and follow. I may do a 'basic build instructions' that can be followed on how to get this working, including putting the hardware together.
    MySensors 2.1.1
    • S
      Samuel235
      Board Revision2 got delivered today and obviously i set about populating the board instantly!
      I have the board all completed and now I'm attempting to burn the bootloader on. Before i go ahead and screw my IC up (I read if you use the wrong fuse reading for the timing of the clock you can't Re-burn anything else to it) i would like some advice. I've detected the current/pre-set fuse readings through AVRDUDESS using a clock speed of 93.75KHz, so i know the connection between my computer and the board is working. The readings for the fuses are below:
      I'm currently using the fuse calculator here to workout the fuses needed. I'm also looking at Maniac's blog post here as he made a very low power module. The only thing i would question about his version/board is that his brownout is set to 2.7v. I've checked the nRF module and the lowest voltage it can go is 1.9, so maybe i should bring the BoD reading down even more or even disable it all together (I plan on reading the battery voltage from this module anyway).
      The below settings for the fuses are my own workings out with the fuse calculator linked above, I'm doubting myself here, i'm in territory that i'm not comfortable with so I'm more than likely making a mistake here but what do you think? The BoD is set to 1.8 here:
      Low: 0x62 | High: 0xD9 | Extended: 0xFE
      Once i have confirmed a fuse setting, Do I edit them into the board.txt config of Maniac's blog post or do I use that of @tekka's?
      MySensors 2.1.1
      • m26872M
        m26872M
        m26872
        I have a very brief guide here, under 'Software'. There are some links to other guides as well. I think you use (42, DE, 07/FF) together with that linked bootloader (important).
        I also think Maniacs guide is a little old. You should get a a lot lower power by using MySensors lib and other some other tricks and settings.
        S 1 Reply Last reply
        • m26872M m26872
          Samuel235
          @m26872 From having a quick look at your guide, you bring your clock speed right down to 1MHz, am i correct in thinking this? Do you have any timing issues at all, is the node still quick enough to respond to switching and sensor detecting or is there a delay in the signal sending?
          MySensors 2.1.1
          m26872M 1 Reply Last reply
          • S Samuel235
            m26872M
            m26872M
            m26872
            @samuel235 Yes, it's working. But you can't use some things like DS18B20s and DHTs at these low frequencies. Si7021 etc are used instead. Button switches and other simple things are exellent applications.
            • m26872M m26872
              Samuel235
              #106
              @m26872 - Well, I was planning on maybe having a temp sensor in there at some point, but not this revision. So if i went without that function at the moment it wouldn't be the end of the world, i would just revise even more for the next revision. I'm presuming that you have taken it to 1MHz for power saving or?
              This is the configuration i'm thinking:
              ######## settings for 8Mhz internal clock
              proMYSBL8.name=ATmega328 internal 8Mhz with MYSBootloader
              proMYSBL8.upload.tool=avrdude
              proMYSBL8.upload.protocol=arduino
              proMYSBL8.upload.maximum_size=30720
              proMYSBL8.upload.maximum_data_size=2048
              proMYSBL8.upload.speed=57600
              proMYSBL8.bootloader.tool=avrdude
              proMYSBL8.bootloader.low_fuses=0x42
              proMYSBL8.bootloader.high_fuses=0xDE
              proMYSBL8.bootloader.extended_fuses=0xFF
              proMYSBL8.bootloader.unlock_bits=0x3F
              proMYSBL8.bootloader.lock_bits=0x3F
              proMYSBL8.bootloader.file=MySensors/MYSBootloader.hex
              proMYSBL8.build.mcu=atmega328p
              proMYSBL8.build.f_cpu=8000000L
              proMYSBL8.build.board=AVR_UNO
              proMYSBL8.build.core=arduino
              proMYSBL8.build.variant=standard
              That would remove the brownout, enable SPI, and put the clock to 8MHz. What is your thoughts on this config?
              MySensors 2.1.1
              • S Samuel235
                m26872M
                m26872M
                m26872
                @samuel235
                • You'll need low MHz for ot to work when battery runs out and voltage decreases.
                • Those fuses are for 1MHz, not for 8MHz.
                • I've never used MYSBootloader. Someone else has to confirm the settings if you use this.
                • m26872M m26872
                  @samuel235
                  Samuel235
                  @m26872
                  Lower clock speed would last through the low power phase of the battery. Obviously, thank you for pointing that out! However, I'm looking at Maniacs battery testing graph and the battery is stable down to around 2.4v for around 150 hours, then it will rapidly drop off to 0v, so I'm thinking "is the lower clock speed really worth the extra 10 hours of use?".
                  The fuses, although I am going off of what you suggested, i entered them into my fuse calculator and its showing up at 8MHz, with no modification needed to the speed.... I'm a little confused at this part as you have now said that those fuses are for 1MHz.
                  I'm now wondering if its worth using MYSBootloader or the one you used, I can see that you used this and programmed through the Arduino IDE, from your post you said you're more comfortable with using the Arduino IDE (Which i am too, but can adapt if needed).
                  MySensors 2.1.1
                  • scalzS
                    scalzS
                    wrote on last edited by scalz
                    #109
                    @samuel235: don't worry about 1mhz...there is no big difference 1Mhz vs 8Mhz at 3V in deepsleep mode. In deepsleep mode, at 3V 8Mhz internal rc, you can get 140nA. So you can't have such interesting diff.
                    In other hand, if node is wake up, you are in mA range, and here it can be interesting to play between clock and voltage ;) you can do it on the fly in sketch and it's good to know that for timing things, atmel clock and voltage are linked.
                    So i would suggest you to stay with internal rc 8Mhz, BOD 1.8V and MYSBootloader. If I remember right it should be ok. Other thing good to know, you can disable BOD=0V when in deepsleepmode (this is done like this in lib I think), but it's not a good practice to disable it when wake up. Keep 1.8V limit, it can prevent some bugs..All is described in datasheet ;)
                    Another thing good to know, as I see lot of peope estimation for coincell...there are lot of chance that you can't get the full coincell capacity, depending on the application, the use. A common "prevision is to plan 80% of its capacity. It's due to the rate of discharge of battery and coincell's one is small..
                    There are lot of others resources on the subjects but here few links :
                    https://www.dmcinfo.com/Portals/0/Blog Files/High pulse drain impact on CR2032 coin cell battery capacity.pdf
                    http://www.embedded.com/electronics-blogs/break-points/4429960/How-much-energy-can-you-really-get-from-a-coin-cell-
                    http://www.ti.com/lit/wp/swra349/swra349.pdf
                    S m26872M 2 Replies Last reply
                    • scalzS scalz
                      Samuel235
                      #110
                      @scalz This is the information that was much needed. Right, so my settings are going to be:
                      proMYSBL8.bootloader.low_fuses=0x62
                      proMYSBL8.bootloader.high_fuses=0xD9
                      proMYSBL8.bootloader.extended_fuses=0xFE
                      At the moment the fuses are set using Hexadecimal notation, I'm sure that I read somewhere that to burn this using a Arduino IDE you need to use normal binary rather than Hex. Do you know if Hex is okay for Arduino IDE?
                      I've got those fuses set to enable 1.8v BoD, 8MHz clock with a 65ms delay on startup. This will use MYSBootloader too. Does this sound okay to now edit my boards.txt, and burn the MYSBootloader.hex file to the chip? I'm using a USBASP device connected to my ISP connection. Am i forgetting anything at all here? As far as I'm aware of, i now plug the board and USBASP into my computer, load the .hex file into arduino IDE and burn using the board config i have put into my boards.txt file. Then i can use my FTDI adapter to then burn sketches to the board through the arduino IDE?
                      I know that to some people I may be asking what seems like the same questions over and over but I'm starting to feel very confident with embedded chips now. Thank you!
                      MySensors 2.1.1
                      • scalzS
                        scalzS
                        no problem :) yes, it sounds ok...that's how I do too. But I don't use mysbootloader, i use dualoptiboot (sensebender bootloader). for the hex/bin fuse notation, I use hexa.
                        • S Samuel235
                          @m26872
                          m26872M
                          m26872M
                          m26872
                          @samuel235
                          • You could be rigth regarding the battery. I've no coin cell experience.
                          • You noticed the check mark by the 'divide clock by 8' ?
                          • If you by 'program' normal ftdi flash, then yes. I didn't program bootloader with Arduino.
                          • scalzS scalz
                            Samuel235
                            @scalz
                            Is there a reason to use dualoptiboot over MYSBootloader or is that just something you did for no reason?
                            Did you use Arduino IDE to burn your bootloader, if so then i can confirm its okay to use Hexa for my board with arduino IDE, if you didn't i will have to convert it to normal binary.
                            @m26872
                            I have just realised that you burn your bootloader with the check mark of 8MHz but then the board.txt is configured to set it to 1MHz, is that what you're trying to tell me? I'm not too sure on your last point, i don't get what you're trying to say if i'm honest, could you elaborate a little? Sorry.
                            MySensors 2.1.1
                            • scalzS
                              scalzS
                              @samuel235: yes, always good reasons ;) I have tried both. both works well. I like the "buffer style" of dualoptiboot. plus no mysensors lib in bootloader, few others reasons...but mysbootloader is very cool too and simple. So don't worry about this :) it's a matter of taste, each have their pros&cons.
                              Yes, use arduino ide to burn bootloader + hexa is ok.
                              • scalzS scalz
                                Samuel235
                                @scalz - Perfect. I will see how i get on with the MYSBootloader style. Soon as i get back i will burn these settings to my uC and see how i get on. I will come back with the results when i'm done. :)
                                MySensors 2.1.1
                                • scalzS scalz
                                  m26872M
                                  m26872M
                                  m26872
                                  #116
                                  @scalz
                                  • Don't know if good practice or not, but I run 328p + nRF down to 1.6V very stable. Could depend on a lot things and conditions of course. You said "some bugs" - do you know more what risks there are? Permanent damages etc?
                                  • Do you know if the 'Divide clock by 8" (8MHz or 1MHz) also can be changed on-fly-with code? If so, does it matter which speed set by fuse and thus used at start-up?
                                  • Great thanks for the coin cell info!
                                  • S Samuel235
                                    m26872M
                                    m26872M
                                    m26872
                                    @samuel235 I meant that you should untick this to use 8MHz. Provided that you don't change it on-the-fly somehow.
                                    • S Samuel235
                                      m26872M
                                      m26872M
                                      m26872
                                      @samuel235 Sorry for not elaborating. I've been mobile all day until now. And my phone also seems to have a few issues with the forum.
                                      • S
                                        Samuel235
                                        @m26872 Ahh right okay, good job i caught your reply before burning it haha! So if i set it to 8MHz internal with 64ms delay and untick that divide by 8 option, that'll be good?
                                        MySensors 2.1.1
                                        • S Samuel235
                                          m26872M
                                          m26872M
                                          m26872
                                          Yes. but don't forget to enable the boot reset vector.
