  3. Start/stop sequence
Start/stop sequence
2 Posts 2 Posters 1.1k Views
  • T
    thomas1412
    I have an Arduino which controls a relay with 8 channels. The channels are switching on and off one after another. Just like this, very simple:
    digitalWrite(RELAY1,LOW);
    delay(2000);
    digitalWrite(RELAY1,HIGH);
    digitalWrite(RELAY2,LOW);
    delay(2000);
    digitalWrite(RELAY2,HIGH);
    Now I want to control this application over RF/MySensors so that I can send a signal over RF to the Arduino to start or stop the sequence.
    My first idea was just to extend the RelayActuator-code by an if-loop. I used gw.loadState to check whether the sequence should start or not, but this is truly wrong..
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    //MyTransportRFM69 radio;
    //MySigningNone signer;
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.process();
      if (gw.loadState(1)==1) {
        Serial.println("on");
        digitalWrite(RELAY_1,LOW);
      if (gw.loadState(1)==0) {
        Serial.println("off");
        digitalWrite(RELAY_1,HIGH);
      delay(100);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    Any idea how I get this working?
    Thanks!
    • ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      I dont have access to test your code now but what I see that could be wrong is using delay in your code. Delay will stop executing of the code for 100 ms. This is a lot.
      Search for non blocking delay examplew that uses timers to implement a delay. I guess also that there is a library for that which i saw in one of the examples of mysensors library.
