  3. Can't get motion interrupt to work in my (combined temp, battery and motion) sketch
10 Posts 3 Posters 3.8k Views 3 Watching
  • B Offline
    B Offline
    BastienVH
    wrote on last edited by BastienVH
    Hi everyone,
    I've been having some trouble combining the temp, battery and motion sketch.
    I put the code together and battery level, temperature and motion info gets sent on the regular intervals, but I can't get the motion to trigger an interrupt.
    The code is below.
    I've tried flashing the the regular motion sketch and alter the names of the motion pin to MOTION_INPUT_SENSOR and that works.
    Also, I'm using a HC-SR501 on a 3.3V pro mini, but as I said, it acts correctly when using the regular sketch.
    Could someone take a look at my code and see what I might have missed?
    Here's my sketch:
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    // Include libraries
    #include <OneWire.h>
    // Define data
    #define CHILD_ID_TEMP 0              // Temp child ID
    #define CHILD_ID_MOTION 2            // MOTION child ID
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    #define MOTION_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define INTERRUPT MOTION_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    // Initialize mysensor
    // Initialize D_Temp
    // Variables
    unsigned long SLEEP_TIME = 20000; // Sleep time between reads (in milliseconds)
    int numSensors = 0;
    int node_id = 13;
    int oldBatteryPcnt = 0;
    boolean metric = true;
    // Initialize childs
    MyMessage msgMot(CHILD_ID_MOTION, V_TRIPPED);
      // Start up the OneWire library
      sensors.begin();
      analogReference(INTERNAL1V1);
    #else
      analogReference(INTERNAL);
      gw.begin(NULL, node_id);
      gw.sendSketchInfo("Temp en Motion sensor met batterij", "1.0");
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        gw.present(i, S_TEMP);
         pinMode(MOTION_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
      gw.present(CHILD_ID_MOTION, S_MOTION);
      // get the battery Voltage
    #ifdef DEBUG
      Serial.println(sensorValue);
      float batteryV  = sensorValue * 0.003363075;
    #ifdef DEBUG
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
      gw.process();
      gw.sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
    #if COMPARE_TEMP == 1
    #else
          gw.send(msgTemp.setSensor(i).set(temperature, 1));
          lastTemperature[i] = temperature;
          // Read digital motion value
      boolean tripped = digitalRead(MOTION_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      gw.sleep(SLEEP_TIME,CHANGE, SLEEP_TIME);
    I hope you don't lose your way in the sketch, because it's kind of cobbled together from other sketches I found, so it isn't well structured.
    Thanks in advance!
    Just a quick edit: this is the altered standard sketch that does work with the interrupt:
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    int node_id = 10;
    // Initialize motion message
      gw.sendSketchInfo("Motion Sensor", "1.0");
      gw.present(CHILD_ID, S_MOTION);
      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    A martinhjelmareM 2 Replies Last reply
    • B BastienVH
      Hi everyone,
      The code is below.
      Here's my sketch:
      // Define data
      // Variables
      int numSensors = 0;
      int node_id = 13;
        sensors.begin();
      #else
      #ifdef DEBUG
      #ifdef DEBUG
        gw.process();
      #else
      Thanks in advance!
      int node_id = 10;
      A Offline
      A Offline
      AWI
      @BastienVH
      Look at the line
      vs.
      B 1 Reply Last reply
      • A AWI
        @BastienVH
        Look at the line
        vs.
        B Offline
        B Offline
        BastienVH
        @AWI
        Thank you so much!
        I've been at this the entire morning and I just couldn't see it...
        Now the interrupt works perfectly!
        I'm just gonna find a way to only send the motion status on interrupt and not the battery level and motion temp.
        I think it'll be with some if statement.
        I'm off to mess around with the cvode some more!
        A 1 Reply Last reply
        • B BastienVH
          @AWI
          Thank you so much!
          A Offline
          A Offline
          AWI
          @BastienVH The return value of gw.sleep() show the cause of the wake-up. You can use that in your "if statement".. have fun..
          • B BastienVH
            Hi everyone,
            The code is below.
            Here's my sketch:
            // Define data
            // Variables
            int numSensors = 0;
            int node_id = 13;
              sensors.begin();
            #else
            #ifdef DEBUG
            #ifdef DEBUG
              gw.process();
            #else
            Thanks in advance!
            int node_id = 10;
            martinhjelmareM Offline
            martinhjelmare
            @BastienVH
            Hi! It looks as if you might possible get a conflict of child ids, between temp sensors and motion. You're presenting the temp sensors in the loop, and if they are more than 2, one temp sensor and the motion sensor will be presented as child id 2. Don't know what would happen in that case, if it's allowed to overwrite the id at presentation in that way, or not.
            • B Offline
              B Offline
              BastienVH
              Hi everyone,
              It's been a while but now I've received some more arduinos, I'm back in action with developing my sketches.
              After the last problem (everytime motion is detected, temp also gets updated and sent), I've been tinkering with my sketch and if-statements.
              At the moment, I've got this (migrated from dallas to DHT for testing purposes):
              #include <DHT.h>
              #define DIGITAL_INPUT_MOTION 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
              #define INTERRUPT DIGITAL_INPUT_MOTION-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
              #define CHILD_ID_HUM 0
              #define CHILD_ID_TEMP 1
              #define CHILD_ID_MOT 2
              #define HUMIDITY_SENSOR_DIGITAL_PIN 4
              unsigned long SLEEP_TIME = 15000; // Sleep time between reads (in milliseconds) - low for testing purposes
              DHT dht;
              float lastTemp;
              float lastHum;
              MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
              int node_id = 20;
              boolean lastTripped = false ;
                gw.sendSketchInfo("Humidity and motion", "1.0");
                pinMode(DIGITAL_INPUT_MOTION, INPUT);      // sets the motion sensor digital pin as input
                gw.present(CHILD_ID_MOT, S_MOTION);
              // OPTION 1: work with if statement
                 int wake;
                wake = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                 if (wake > 0) {
                   Serial.println("wake by motion");
                   Serial.println("reading motion");
                   motion();
                 else {
                   Serial.println("wake by timer");
                   motion();
                   Serial.println("reading temp/hum");
                   humTemp();
              //OPTION 2: NO IF-STATEMENT (commented out at the moment)
                motion();
                Serial.println("read temp / hum");
                humTemp();
                Serial.println("going to sleep now.");
                gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); //sleep a bit
              void motion() {
                boolean tripped = digitalRead(DIGITAL_INPUT_MOTION);
                if (lastTripped != tripped) {
                  gw.send(msgMot.set(tripped ? "1" : "0")); // Send tripped value to gw
                  lastTripped = tripped;
              void humTemp() {
                gw.wait(dht.getMinimumSamplingPeriod());
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
                  Serial.print("T: ");
                  Serial.println(temperature);
                if (isnan(humidity)) {
                  lastHum = humidity;
                  Serial.print("H: ");
                  Serial.println(humidity);
              Strange things are happening...
              If I use OPTION 2, without if, so temp is always checked, interrupt get triggered instantly as shown here and sends a 'deactivate'-message 0 when the sensors sets back to 0 after +- 8 sec:
              send: 20-20-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
              read temp / hum
              going to sleep now.
              send: 20-20-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,st=ok:0
              read temp / hum
              going to sleep now.
              If I use OPTION 1 (preferred because no unnecessary temp measurement), the interrupt seems to only occur when the motion signal goes back to 0 (low), which is late and doesn't provide me with a 1-signal (meaning it will not communicate presence, but only when the built-in timer of =- 8 seconds has passed).
              wake by motion
              reading motion
              going to sleep now.
              The use of wake comes from this topic and the API.
              Any suggestions or does someone see what I missed?
              Thanks alot!
              • B BastienVH
                Hi everyone,
                #include <DHT.h>
                DHT dht;
                float lastTemp;
                float lastHum;
                int node_id = 20;
                   int wake;
                   if (wake > 0) {
                     motion();
                   else {
                     motion();
                     humTemp();
                  motion();
                  humTemp();
                void motion() {
                void humTemp() {
                    if (!metric) {
                    lastHum = humidity;
                read temp / hum
                going to sleep now.
                read temp / hum
                going to sleep now.
                wake by motion
                reading motion
                going to sleep now.
                Thanks alot!
                martinhjelmare
                @BastienVH
                You have two calls to sleep function. You're checking the return value of the first call but not the second. So when waking after the second sleep, it will just go back to sleep again. If it wakes again, now it will check the return value and takeaction. Then it repeats in this way, every other wake doing nothing but sleeping again.
                Just remove the last call to sleep, if you're fine with going to sleep immediately in the loop.
                  @BastienVH
                  B Offline
                  B Offline
                  BastienVH
                  @martinhjelmare
                  Ok, I didn't know that declaring the int wake as the reply from gw.sleep would actually make the node go to sleep again.
                  I've now setup my loop like this and it appears to work:
                    int wake = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                    Serial.println(wake);
                    if (wake > 0) {
                      motion();
                    else {
                      motion();
                      humTemp();
                  Only thing is, I only get my first temp/hum/motion data AFTER the node has been in sleeping for SLEEPTIME.
                  Could I put a command to read motion and temp/hum in my setup or is that bad coding ettiquette?
                  PS: Thanks martin for being such a helpful member!
                  I feel like your everyones personal debugger!
                  • B BastienVH
                    @martinhjelmare
                      if (wake > 0) {
                        motion();
                      else {
                        motion();
                        humTemp();
                    martinhjelmare
                    @BastienVH
                    Yes you could call your sensor functions in the end of setup. Another way would be to move the sleep call to the end of the loop, but then you should initialize wake outside the loop before setup and give it a value that will make it call the sensor functions, when the program enters the loop.
                      @BastienVH
                      B Offline
                      B Offline
                      BastienVH
                      @martinhjelmare
                      Great, thanks.
                      The sketch now works as it should.
                      Below is the finished sketch.
                      I also added a counter so that after 10 consecutive interrupts from the motion sensor, the temp and hum get read and transmited. (motion-on generates an interrupt and motion-off generates an interrupt, so it's actually 5 motion triggers)
                      Otherwise if there is a lot of movement during a certain timeframe (mornings), hum and temp won't be measured.
                      Later I will edit the sketch to have all transmits together to save more battery power.
                      Here's the sketch:
                       * Version 1.0 - Henrik EKblad
                       * This sketch provides an example how to implement a humidity/temperature
                       * sensor using DHT11/DHT-22
                      #include <DHT.h>
                      unsigned long SLEEP_TIME = 150000; // Sleep time between reads (in milliseconds)
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      int node_id = 20;
                      int wake = 0;
                      int motionCount = 0;
                        gw.begin();
                        gw.sendSketchInfo("Humidity and motion", "1.1");
                        if (wake == 1 && motionCount <= 10) {
                          motion();
                          motionCount = motionCount + 1;
                          Serial.println(motionCount);
                        else {
                          motion();
                          humTemp();
                          motionCount = 0;
                          Serial.println("motionCount is reset");
                      void motion() {
                      void humTemp() {
                          if (!metric) {
                          lastHum = humidity;
