  3. Arduino Library for Oregon sensors (433Mhz)
14 Posts 2 Posters 14.1k Views 5 Watching
    mickaelh51
    wrote on last edited by mickaelh51
    I developed (modify) the originale Oregon library to be able to decode these sensors and send results in MySensors.
    Tested with : THGR228N and THGN132N
    It's a beta version ... many enhancements must be necessary, but it works
    https://goo.gl/x4ifu4
    your comments are welcome ;)
    Controller: OpenVZ :: OpenHab 1.8.0 :: MQTT Broker
    Gateway: Arduino UNO :: W5100 :: MQTTClient
    Software: MySensors 1.6beta
      mickaelh51
      Just before my vacations, I added some features ;)
      • Auto discover Oregon sensors ID
      • Save ID on Arduino EEPROM
      • Add battery level to MySensors
      My GitHub: https://goo.gl/x4ifu4
      Results on My OpenHAB
        mickaelh51
        there is this issue when I want "verify code" in codebender (see below), but with arduino soft 1.6.7 it works fine
        MySensors_433Mhz_Oregon.ino:66:19: error: use of undeclared identifier 'digitalPinToInterrupt'
        CodeBender version
          Cool. Thank you for this nice addition!
            mickaelh51
            you're welcome ;)
            it's not finish,but after my vacations, I will finish it ;)
              mickaelh51
              Ha @hek I use EEPROM memory writing like database of Oregon's IDs.
              But your framework use also EEPROM memory.
              there is a potential issue (coflict) between them ?
              if yes, what other library can I use ? I'm thinking at that: http://playground.arduino.cc/Code/StackArray
              thanks in advance
                Yes, there might very well be a conflict unless us keep your writes above
                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MySensorCore.h#L55
                You can use the
                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MySensorCore.h#L159
                If you only need to save 255 bytes you can user the saveState/loadState functions. Othervise keep above thisl ;)
                  mickaelh51
                  @hek thanks for your answer.
                  If I understood, I can use save & load state if:
                  1. I start the ID from EEPROM_LOCAL_CONFIG_ADDRESS
                    Ex:
                  for (i=EEPROM_LOCAL_CONFIG_ADDRESS; i<COUNT_OREGON_SENSORS; i++){
                  1. I write <255 bytes
                  is it exact ?
                  thanks in advance
                  PS (10 mins after):
                  I don't understand, indeed with this variable:
                  EEPROM_CONTROLLER_CONFIG_ADDRESS (EEPROM_ROUTES_ADDRESS+256)
                  we are beyond the maximum ID (255) no ?
                    The usage of loadState/saveState looks fine in your sketch.
                    By using them you won't overwrite anything important in the EEPROM.
                    (You only need to roll your own thing if you need to save more than 255 bytes)
                      mickaelh51
                      Ok thanks.
                      I will do some enhancements before post my pool request.
                      bye
                        mickaelh51
                        Hi, I finished my first complete library Oregon.h with 2 examples (1 with MySensors / 2 without MySensors).
                        I will test it next week and I will post it here.
                        After many tests I post a pool request in official mysensors project on github.
                        Did you have time to test the first version ?
                        thanks in advance
                          mickaelh51
                          First version of my official arduino library : https://github.com/Mickaelh51/Arduino-Oregon-Library
                          I asked at Arduino software to put this new library (1.5 arduino format) in their official "libraries manager" ==> https://github.com/arduino/Arduino/issues/4371
                          If they ok to include my library, the arduino IDE will be able to check the available updates.
                          This 1.0.0 version has been tested with : Arduino UNO / 433Mhz receiver / Oregeon sensor THGR228N.
                          I'm already working on developement github branch with many enhancements.
                          Ex: Data Checksum / Others sensors (OWL Electricty Meter / WGR918 Annometer / RGR918 Rain Guage / UV138 / THGR918 Outside Temp-Hygro / BTHR918 Temp-Hygro-Baro)
                          if you want to test master or developement branch, I'm free to discuss with you.
                          good playing ;)
                            mickaelh51
                            Arduino has accepted my library ;)
                            it available in libraries manager on the arduino IDE
                              mickaelh51
                              Just for fun : https://youtu.be/2Um5PQ_tZXA
