  3. Gateway as Node?
Gateway as Node?
2 Posts 2 Posters 998 Views
  • M Offline
    M Offline
    Maxxon
    Hello together!
    Is it possible to use the Ethernet Gateway as a sensor node as well? If i combine the sketches for the ethernet gateway and a simple sensor node i can't find a configuration option which would tell the sensor node that it can reach the gateway "locally", e.g. without using the NRF Radio.
    thanks in advance.
    Maxxon
    • Michel - ItM Offline
      Michel - It
      http://forum.mysensors.org/search/Ethernet Gateway?in=titlesposts
      12.2k
