  3. Rechargeable Lithium Ion Sensor Custom PCB
71 Posts 12 Posters 36.4k Views 8 Watching
  • H Heizelmann
    If the module also should be operated while charging and the DHT11 sits directly on the board close to the battery charger the sensor would show significantly higher temperatures caused by the TP4056 battery charger which becomes really hot during charging.
    On an experiment on a breadboard with comparable distance I measured a temperature of the TP4056 of about 70 degree Celsius in the first phase of charging and the sensor reading rises from about 20 to 22 degrees.
    H Offline
    H Offline
    HenryWhite
    wrote on last edited by HenryWhite
    #41
    @Heizelmann you're right, the module gets pretty warm.
    Here I found some more measurements for the Tp4056: http://lygte-info.dk/review/Review Charger TP4056 UK.html
    Although the board is designed to bend the DHT22 over the prototyping area so that it is horizontal and not vertical aligned, I think I could swap positions of the prototyping area and the mounting point for the DHT22.
    To keep the Tp4056 cooler, you could add a small heatsink to it or replace the resistor so that it charges with lower current.
    • A akumar
      So if I sum up, powering this node with a single Lipo cell will work by connecting the Lipo to the raw pin on the arduino. This will work from 4.2v to 3.4v. This is not that good for the battery life.
      Using 2*AA batteries with a boost converter seems a lot easier...
      I'm almost giving up on this idea : I liked the flat form factor of the lipos and they were solar pannel friendly. Is there a way to use a voltage regulator from 4.2v to 3.4v and then switch the circuit to a boost converter from 3.3v to 2.8v ?
      F Offline
      F Offline
      flopp
      wrote on last edited by flopp
      #42
      Maybe this can be used. But I use 0.1mA when "sleeping"
      https://www.pololu.com/product/2122
      • F Offline
        F Offline
        flopp
        http://www.aliexpress.com/item/10pcs-2-in-1-Tinysine-Charge-Pump-Step-Down-Step-Up-Boost-Buck-2-5V-3V/32366514629.html?spm=2114.01020208.3.1.FuE3W9&ws_ab_test=searchweb201556_2,searchweb201644_2_10001_10002_10005_10006_10003_10004_62,searchweb201560_2,searchweb1451318400_6148
        • A Offline
          A Offline
          akumar
          @flopp : cool module ! This could do the trick. The 0.1 mA could be taken care of by powering the module via a MOSFET controlled by the arduino. It would then power the sensors and the radio only when needed.
          • H Offline
            H Offline
            HenryWhite
            Again, to prove my point that you don't need to go below 3.3V (at least with modern smartphone batteries), I just measured my Galaxy S5's battery at 4% battery state. The measured voltage is 3.65V.
            F 1 Reply Last reply
            • H HenryWhite
              F Offline
              F Offline
              flopp
              @HenryWhite
              Wow, what are your low/max limit?
              4% seems to be very low if your low limit is 3.3.
              H 1 Reply Last reply
              • F flopp
                @HenryWhite
                H Offline
                H Offline
                HenryWhite
                #47
                @flopp said:
                @HenryWhite
                I must admit i didn't understand that :smile:
                At 2% battery state (according to what is shown in the android UI) the s5 battery still outputs 3.43V (measured with multimeter and compared to android app "Ampere")
                Even at 1% the voltage is still above 3.3V:
                But: I just discovered that the galaxy s5's battery is a 3.85V li-ion battery with a charging voltage of 4.4V instead of 4.2V..
                But even then, the 3.8V S4 battery which I'm going to use for my sensors will approximately reach less than 3.3V not before the battery is under 5% charging state I think.
                • H HenryWhite
                  Hi!
                  Since a bunch of people already made a custom MySensors PCB, I decided to get used to Eagle and create my own board to fit my needs :smiley:
                  The key difference compared to other custom PCBs is the Lithium Ion Charging Circuit with micro USB connector. So you can just grab a flat smartphone battery with 1000 mAh or more and stick it under the PCB! This way you never have to worry about changing batteries, and even if your configuration consumes a lot of power, you can quickly recharge your sensor through the micro USB connector of the Li-Ion Charging Module.
                  The board is currently only designed to work with the Arduino Pro Mini 3.3V version.
                  Version 0.1 is tested, I received the PCBs on 01/26/2016. Everything works fine (good radio range), there is only one little problem with the connection of the battery (but it is fixable; see post 52 in this thread for a fix)
                  So here are the specifications and features of my board:
                  • designed for cheap 3.3V Arduino Pro mini clones from china, for example this one
                  • 5x5cm
                  • uses jumper bridge to simply connect and disconnect the battery
                  • easy attaching of motion sensor (use 3.3V mod), DHT22 for Temp and Humidity Measurement and one switch (for example button- or reedswitch)
                  • small prototyping area on the backside
                  • uses TP4056 Li-Ion single cell Micro USB 1A charging circuit with battery protection (disconnects the power automatically if voltage drops below 2.4V
                    ------> make sure you get the NEW version of the TP4056 with battery protection circuit!
                    remember to charge your li-ion 1-cell rechargeable battery with maximum 1C, so if you want to use a battery below 1000 mAh you need to make modifications to the module or the charging current will be way to high, which could result in an explosion (worst case)
                  • I suggest to use the board with a smartphone battery, as they usually are very small and flat and have a high capacity for small money. I will use the galaxy s4 battery because it fits nearly perfect under the board and has 2600 mAh.
                  • Now with additional relay, properly connected using 2N2222A transistor, flyback diode, 1kΩ resistor and terminal block for easy attaching of "switchable things" to the relay
                  Schematics (Rev 1.0)
                  Board view (Rev 1.0)
                  3D board view (Rev 1.0)
                  Build files
                  Rev 1.0:
                  • proper alignment of DHT22
                  Eagle files: 0_1453762986505_Sensorboard_v1.0.zip
                  Gerber files: 0_1453763061782_Sensorboard_v1.0_Gerber.zip
                  Rev 0.3: swapped footprints of DHT22 and prototyping area to prevent false temp measurements when charging the battery; connected TP4056 OUT to arduino's RAW instead of VCC_IN (so the internal voltage regulator is used)
                  sensorboard_v0.3.sch
                  sensorboard_v0.3.brd
                  Rev 0.2: added footprint for 47uF SMD capacitor standard 1210 (i guess many other smd caps will fit too)
                  sensorboard_v0.2.sch
                  sensorboard_v0.2.brd
                  Rev. 0.1
                  untitled.sch untitled.brd
                  H Offline
                  H Offline
                  HenryWhite
                  #48
                  I just added revision 0.3 to the first post:
                  • H Offline
                    H Offline
                    Heizelmann
                    Thanks for Rev 03. Another optimization would be to turn the DHT22 180 degrees. Then the open front would face outside. Better for air circulation if put into a case with only a small open slot for the DHT.
                    • H Offline
                      H Offline
                      HenryWhite
                      This post is deleted!
                      • H Offline
                        H Offline
                        HenryWhite
                        #51
                        Here it is: Revision 1.0
                        Changes:
                        Build files
                        • H Offline
                          H Offline
                          HenryWhite
                          I just received my ordered PCBs (Revision 0.1) from Elecrow. The PCBs are very well made for that low price! (I got 14PCBs for 14$)
                          It fits nicely in a 75x75mm electric box (not the prettiest housing, but very cheap and easily processable for drilling holes for the connections; plus you can paint it to make it more beautiful :smile: )
                          Since it is revision 0.1, I had to cut one pcb trace (V+ from POWER to Arduino's V_IN) and connect V+ from POWER manually with Arduino's RAW input.
                          Soldering directly to the battery went better than I thought!
                          • M Offline
                            M Offline
                            m26872
                            Nice, but I think R3 =330k would give you a better battery voltage monitoring divider ratio (Vmax 4.43V). Maybe a little higher total resistance would limit current loss though (even 10M+3M would work).
                            Maybe something useful here.
                            • M m26872
                              H Offline
                              H Offline
                              HenryWhite
                              Good point! :) Didn't thought about that.
                              • alexsh1A Offline
                                alexsh1A Offline
                                alexsh1
                                @HenryWhite Did you make any estimates how long your node is running on the fully charged battery?
                                • alexsh1A alexsh1
                                  H Offline
                                  H Offline
                                  HenryWhite
                                  #56
                                  I'm just testing it :)
                                  The Version without relay (Rev. 0.3) should be good for at least two months, assuming you want to read temp/humidity every 60 seconds and you have a 2600mAh (smartphone) battery.
                                  I think you can improve the battery life much further, for example with the following:
                                  • a better sketch, e.g. bigger sleep time
                                  • removing the power LED on the arduino
                                  • higher battery capacity
                                  The DHT22 is also drawing much current, i think i will replace it in a next version with a Si7021.
                                  PS: The version with relay could never run very long, because you need to keep the node awake in order to send a command to switch the relay. But even if you use the relay version, you could just attach a bigger battery.
                                  • alexsh1A Offline
                                    alexsh1A Offline
                                    alexsh1
                                    #57
                                    @HenryWhite Thanks - I was gonna make this suggestion about the DHT22:
                                    1. you do not need temp/hum every 60 sec. 5 -10 mins should be enough
                                    2. Power LED has a negligible consumption if you have DHT22 onboard.
                                    3. I have Si7021 (powered by two batteries) and DHT22 (powered from 240V via AC/DC adapter). Si7021 is more accurate and less power hungry. My suggestion would be Si7021 or BMP280 as they are working the best with batteries.
                                    Just out of curiosity, what do you do when the battery is flat? Take out the node and charge it? Or charging is automated?
                                    • alexsh1A alexsh1
                                      H Offline
                                      H Offline
                                      HenryWhite
                                      You don't have to take anything apart. Just plug in a micro usb loading cable in the Tp4056 and the battery will be charged. Plus, you never need to shutdown the node, charging works simultaneously.
                                      • H Offline
                                        H Offline
                                        HenryWhite
                                        A little update in terms of battery lifetime: all nodes are still running, I think they will last at least for 10 months before you have to recharge them.
                                        • D Offline
                                          dakipro
                                          I've been looking for some time for similar module/board,
                                          (was too lazy to make it myself) and somehow i never found this board.
                                          If I understood you are now on half the battery (after a six months) ?
                                          Did you had any tests with the Relay version on battery power?
                                          I guess it will consume quite some power if it needs to keep relay on from the battery?
                                          If it relay doesn't consume a lot of power then it could be very very useful to have it there (or if it is switched for short period of time and not that often)
                                          Project looks very good, it has all it needs for generic module, thank you for making it.
