  3. An Esp8266 Nextion Scene controller??
38 Posts 12 Posters 25.5k Views 18 Watching
  • F Offline
    F Offline
    fets
    I totally zapped this thread. @alexsh1 where did you order this pcb ?
    • DidiD Offline
      DidiD Offline
      Didi
      @David-Vitrant said:
      Hmm hey sorry for dumb question especially since it's a super old post but I don't seem to find a link to the eagle/cad documents or a way to buy this shield. I have Nextion 2.4, 3.2" and some enhanced version too.
      Let me know if I missed the buy button or a way to get the fritzing/eaglecad I can change myself and maybe adapt to my sousvide and thermostat project :).
      Help Please,
      DV
      Here is the nextion pcb
      if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
      • David VitrantD Offline
        David Vitrant
        @Didi same as one on Scargill site ? I just saw that one a few minutes ago. Did you do your own or pick and place it ;)
        Seems like fun.
        • DidiD Offline
          DidiD Offline
          Didi
          It´s from his blog and i think the pcb is updated
          • David VitrantD David Vitrant
            Help Please,
            DV
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            #25
            @fets @David-Vitrant as @Didi pointed out this is Peter Scargill's board. I suggest you read this link if you want to set it up - http://tech.scargill.net/home-control-2016/ It does require MQTT and Node-red knowledge though
            I uploaded the latest version on oshpark
            F 1 Reply Last reply
            • alexsh1A Offline
              alexsh1A Offline
              alexsh1
              https://www.youtube.com/watch?v=aljm6vH3a5I - this is a video explaining functionality (this is the older version of the board)
              • alexsh1A alexsh1
                F Offline
                F Offline
                fets
                I'm a fan of scargill work. I saw this article a while ago but I didn't use ESP8266 at the time, so I didn't pay attention.
                Now after several tests with ESP, I'm more interested in this PCB, but I can't find a link to oshpark in the article.
                Can you provide a link please.:clap:
                • alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @fets Sure -> https://oshpark.com/shared_projects/UDRPebht
                    David Vitrant
                    @alexsh1 Ha thanks for the osh link :). Saved me the trouble. I find myself building many similar projets and exploring similar avenues as Scargill.
                    Have to use my SMD workstation and go blind for this. But will try anyway.
                    • alexsh1A alexsh1
                      F Offline
                      F Offline
                      fets
                      @alexsh1 :+1:
                      • ? Offline
                        ? Offline
                        A Former User
                        @scalz : What software did you used to create these 3d pics of your board?
                        Thanks!
                        • S Offline
                          @ben5en
                          solidworks, sketchup
                          • A Offline
                            A Offline
                            artipi
                            Hi @alexsh1 ,
                            did you finished your Enhanced Version? As i understood correctly the ESP8266 Board is used to send messages/touch commands over wifi - mqtt to a controller right? How it is programmed to send over mqtt?
                            So if i have this ESP - Board i do not need a arduino right?
                            Another question: Is it possible to run this board with a arduino pro mini or uno and nrf radio to send messages to my controller?
                            alexsh1A 1 Reply Last reply
                            • A Offline
                              A Offline
                              artipi
                              As i see, i can also take some of this ESP-Boards right?
                              https://www.aliexpress.com/item/1pcs-lot-NodeMcu-Lua-WIFI-Internet-of-Things-development-board-based-ESP8266-esp-12e-for-arduino/32775934156.html?spm=2114.01010208.8.10.eix0zH
                              • A artipi
                                Hi @alexsh1 ,
                                alexsh1A Offline
                                alexsh1A Offline
                                alexsh1
                                @artipi what is it you are trying to do?
                                You have to read more on the esp8266 forum.
                                There is a tool to upload binaries (it works on Windows 10) to esp8266. You have to compile binaries.
                                No, the board has not been designed to be run in the arduino environment. This is only esp8266.
                                @artipi said in An Esp8266 Nextion Scene controller??:
                                Hi @alexsh1 ,
                                • A artipi
                                  alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  @artipi no, for this board you only need esp-12
                                  • A Offline
                                    A Offline
                                    artipi
                                    Thanks,
                                    i try to make a small Wall scene controller that sends the commands to Domoticz over mqtt.
                                    I ordered now the Nextion Display an thinking now to buy a WeMos D1 Mini Pro. Is that the right way?
                                    • L Offline
                                      L Offline
                                      luma
                                      I stumbled across this thread while searching for something related and thought I'd resurrect it to mention my HASwitchPlate project, which utilizes an ESP8266 as a MQTT-to-Nextion gateway to act as a wall-mounted scene controller. The project includes code for the ESP8266, Nextion, and home automation platforms including Home Assistant and OpenHAB. A PCB has been developed to allow running from AC power, and 3D-printable models are provided to mount the project into a single-gang work box common in North America.
                                      The end result is a scene controller you can build yourself with all the necessary components (software, electronics, and physical enclosure) ready to download.
