  3. Get Relay State
Get Relay State
4 Posts 2 Posters 3.4k Views 1 Watching
    mikeones
    Is there an options to get the state of a relay? The API shows there is a light status option but it looks like it only sets the state.
    V_LIGHT 2 Light status. 0=off 1=on
    Here is the part of the relay sketch I am looking at.
    void setRelayStatus(message_s message) {
    if (message.header.messageType==M_SET_VARIABLE &&
     message.header.type==V_LIGHT) {
     int incomingRelayStatus = atoi(message.data);
     // Change relay state
     digitalWrite(message.header.childId,  incomingRelayStatus==1?RELAY_ON:RELAY_OFF);
      // Write some debug info
      Serial.print("Incoming change for relay on pin:");
      Serial.print(message.header.childId);
      Serial.println(incomingRelayStatus);
    Is there something similar to the lock status variable for a relay?
    V_LOCK_STATUS 36 Set or get lock status. 1=Locked, 0=Unlocked
    • epierreE
      epierreE
      epierre
      you should write the last k own status in a var and request the var on startuo
      z-wave - Vera -> Domoticz
      M 1 Reply Last reply
      • epierreE epierre
        mikeones
        wrote on last edited by mikeones
        @epierre What would that look like? I was thinking of sending back the status on request. Something like this.
        		if incomingRelayStatus == 2 {
        			gw.sendVariable(message.header.childId, V_LIGHT, digitalRead(message.header.childId));
        		} else {
        • epierreE
          epierreE
          epierre
          I don't know why you use a telay. Look at thr watermeter code, it uses the pattern I described above
