  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • Y yoshida
    Just FYI: I have ordered 20pcb in January, and even though they are 4.1rev (pcbway), the le33a voltage regulator's silk screen still points to the wrong direction (flat side outwards). Also the second picture here mentions 4.1 rev, but I think this is an older rev. flat side outwards will connect the le33a Vin 5V leg to the Vin for the NRF2.4 in the 4.1 rev. Or the other way is that the orientation is good, but then it should be on the other side of the board :) So if it would be on the same side like the capacitors, it would be ok. (I have realized this after the third node built up wrongly.. :) )
    Do you know if the le33a gets 5V to the 3v3 leg, will it survive? Other components?
    @yoshida - sorry, I will have a check. Either its the wrong files or it not been update at the factory.
    Im sorry, I dont know if it will survive. You have to test it.
    Y 1 Reply Last reply
    • sundberg84S sundberg84
      Y
      Y
      yoshida
      @sundberg84 alt text
      I was able to do a photo, so the dallas temp, and le33 "mask" is on the opposite side, I think this is the problem. (in your example pictures they are on the good side)
      No worries, I use currently the newbie pcbs for light switching,
