  3. Why can't I assign a static NODE_ID in one sketch; but not the other?
7 Posts 4 Posters 2.5k Views 1 Watching
  • D Offline
    drock1985
    I'm trying to assign a static NODE_ID to the standard Motion Sensor Example sketch, but I am getting compile errors. The code I am using is
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    #define NODE_ID 6
    // Initialize motion message
      gw.begin (msg, NODE_ID) ;
      gw.sendSketchInfo("Motion Sensor", "1.0");
      gw.present(CHILD_ID, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    What I don't understand about all of this is, I have another sketch that I can and have manually set the NODE_ID for, and it is not that much different from what I have. The code for the working node I have with a set manual ID is:
     * Version 1.0 - 6-December-2015, Derrick Rockwell
     *This sketch uses two 30 bulb, 3mm LED holiday light strings. These
     *can usually be found in most dollar stores/hardware stores and are
     *battery powered. This sketch uses digital pins 3 and 4 to power two
     *a string of lights each. Ex, one can control white lights the other
     *could control multi-colour lights.
    #define SN "HolidayLEDDeskLights"
    #define SV "1.0"
    #define MLED_PIN 3      // Pin Multi-Coloured LED's will attached to
    #define WLED_PIN 5      // Pin White-Coloured LED's will attached to
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    #define NODE_ID 4
    #define CHILD_ID0 0
    #define CHILD_ID1 1
    static int currentLevelM = 0;  // Current dim level...
    static int currentLevelW = 0;  // Current dim level...
    MyMessage dimmerMsgM(MLED_PIN, V_DIMMER);
    MyMessage lightMsgM(MLED_PIN, V_LIGHT);
    MyMessage dimmerMsgW(WLED_PIN, V_DIMMER);
    MyMessage lightMsgW(WLED_PIN, V_LIGHT);
     * Dimmable LED initialization method
      Serial.println( SN );
      Serial.println( SV );
      gw.begin( incomingMessage, NODE_ID );
      gw.present( MLED_PIN, S_DIMMER );
      gw.present( WLED_PIN, S_DIMMER );
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      gw.request( MLED_PIN, V_DIMMER );
      gw.request( WLED_PIN, V_DIMMER );
     *  Dimmable LED main processing loop
      gw.process();
    //For Multi Coloured Lights
    if (message.type == V_LIGHT || message.type == V_DIMMER) {
          // if (message.sensor <= 2)
              //0: All Dimmers
              //1: LED 1
              //2: LED 2
              requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
              if ((message.sensor == CHILD_ID0) || (message.sensor == 0)){
                fadeToLevel ( requestedLevel, MLED_PIN, &currentLevelM );
                gw.send(lightMsgM.set(requestedLevel > 0 ? 1 : 0));
                gw.send(dimmerMsgM.set(requestedLevel) );
              if ((message.sensor == CHILD_ID1) || (message.sensor == 0)){
                fadeToLevel( requestedLevel, WLED_PIN, &currentLevelW );
                gw.send(lightMsgW.set(requestedLevel > 0 ? 1 : 0));
                gw.send(dimmerMsgW.set(requestedLevel) );
     *  This method provides a graceful fade up/down effect
     // For Multi Coloured Lights
    void fadeToLevel( int toLevel, int pin, int *currentLevel ) {
      int delta = ( toLevel - (*currentLevel) ) < 0 ? -1 : 1;
      while ( (*currentLevel) != toLevel ) {
        (*currentLevel) += delta;
        analogWrite( pin, (int)((*currentLevel) / 100. * 255) );
        delay( FADE_DELAY );
    can anyone help me? I checked out the API page when starting the library, but i'm still drawing blanks.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • dakkyD Offline
      dakkyD Offline
      dakky
      what is your error?
      Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
      Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
      Software: MySensors 2.0development
      • D Offline
        drock1985
        Hi @dakky
        This is the error I get from Arduino IDE:
        exit status 1
        invalid conversion from 'int' to 'void (*)(const MyMessage&)' [-fpermissive]
        My Projects
        2 Door Chime Sensor
        • mfalkviddM Offline
          You are sending a message (msg) instead of a function (incomingMessage) to gw.begin.
          • E Offline
            E Offline
            ericvdb
            In the first sketch change
            to
            gw.begin (NULL, NODE_ID) ;
            • D Offline
              drock1985
              Hi @ericvdb
              That did the trick, thanks. Just now to figure out the why.
              My Projects
              2 Door Chime Sensor
                In your first sketch, the node accepts incoming messages.
                The second sketch does not have a function for incoming messages, so you have no function to give gw.begin as argument. You tried giving ge.begin a message instead, but that's not what gw.begin expects so you got a warning.
                When you don't want to use incoming messages you simply give NULL to gw.begin, as ericvdb suggested.
