  3. Vera
  4. MySensors and Vera UI7
22 Posts 11 Posters 18.2k Views 5 Watching
  • jeylitesJ
    jeylitesJ
    jeylites
    A trick I learned right after creating devises is to click on " Reload Luup". Then give it a couple of minutes and you should see the created devices on DEVICES on VERA.
    " Reload Luup". could be access from Apps -> Develop apps -> Serial Port configuration -> Reload Luup
    • BobCB
      BobCB
      BobC
      I've learnt the same trick. Reload Luup from the serial config screen.
      After a couple of trials and then finding the UI7 on Github - all's working fine with my first light sensor.
      Now to building my solar HWS sensors. Thanks Hek for all your work and patience with everyone, a donation is on the way for you to buy a UI7 device. Cheers!
