  3. how to use repeater nodes
2 Posts 2 Posters 1.5k Views 2 Watching
  • n3roN
    n3roN
    n3ro
    Hey folks,
    what's the correct way to use repeating nodes?
    I have build 3 usb powered LED-Lights and one of them is out of range...
    Is it a good idea to enable repeating on every USB-powered node?
    https://github.com/n3roGit/MySensors_n3ro/blob/master/moodlight_extended/moodlight_extended.ino
    gw.begin(incomingMessage, NODE_ID, true);
    Regards,
    n3ro
    pimatic + MySensors + Homeduino + z-way
    • sundberg84S
      Hi @n3ro.
      You have written the correct command. You dont need the incomingMessage if the sensor doesnt expect that.
      Yes, atleast the nodes in strategic locations. I have some node in the outskirt of my network which is USB powered and not a repeater... no point how i see it.
      Dont use delay() or block code in any other way if you are using it as a repeater.
